Old 24th July 2015, 20:25   #41  |  Link
TCmullet
Originally Posted by Reel.Deel View Post
video = FFVideoSource("sample.flv")
audio = FFAudioSource("sample.flv")
AudioDub(video, audio)
or LSmash
video = LWLibavVideoSource("sample.flv")
audio = LWLibavAudioSource("sample.flv")
Reel,
I have to install LSMASH on a different machine. I am totally lost, as the machine I was using before had had lots of various installs of video stuff beforehand, and this additional machine today has nothing. Is there a step-by-step list somewhere to help me install LSMASH including all dependencies? I did install the newest (I believe) ffmpeg.exe, but it doesn't install it anywhere after I extract it from the .7z file. Putting the LSMASHSource.dll into the plugins folder of Avisynth isn't enough.
TCmullet is offline   Reply With Quote
Old 24th July 2015, 20:31   #42  |  Link
sneaker_ger
Read "Requirements":
http://avisynth.nl/index.php/LSMASHSource
Old 24th July 2015, 20:42   #43  |  Link
TCmullet
Originally Posted by sneaker_ger View Post
I did. VC++ for 32-bit is in place. (I ran the installer twice. 2nd time I did repair; all is good.) And Avisynth version says 2.60 (via script). The version on the avisynth.dll in c:\windows\system32 says 2.6.0.5.
Old 24th July 2015, 20:51   #44  |  Link
sneaker_ger
Try:
https://www.dropbox.com/sh/3i81ttxf0...bit-XP.7z?dl=0
Or maybe that version, I see you already discussed it some time ago:
http://forum.doom9.org/showthread.ph...99#post1710899
(I assume you are still on XP)
Old 24th July 2015, 21:31   #45  |  Link
TCmullet
Thank you, Sneaker. Yes, this additional system is also XP and I had forgotten about that thread. It was simply having the correct LSMASHSource.dll, the one with the XP switch compiled into it. Nice that we now have r783-xp (almost new) instead of the old r768-xp. I hadn't picked "old". But when I did, I saw that r783-xp, which must be the link you gave here.
Again, thanks.
Old 25th July 2015, 06:19   #46  |  Link
TCmullet
More trouble now.
LSMASH is working fine on that 2nd XP system, now that I have the XP version of r783 in the plugins folder.
However, I have a 3rd XP system, and copying LSMASHSource.dll from the r783-xp version to IT'S Avisynth folder STILL results in:
"there is no function named "LWLibavVideoSource".
Any ideas as to what could be wrong in this system??
Old 25th July 2015, 08:46   #47  |  Link
Groucho2004
Originally Posted by TCmullet View Post
More trouble now.
This may help.
Old 26th July 2015, 03:15   #48  |  Link
TCmullet
This may help.
Wow, that's a nifty utility you wrote and refined over time! Thanks!
Now will you please help me decipher where to proceed? I have done "Tools", "Plugin Info", and when it hits LSMASHSource.dll, it says:
LoadPlugin: unable to load "C:\Program Files\AviSynth 2.5\plugins\LSMASHSource.dll", Module not found. Install missing library?
DLL dependencies for this file:
MSVCR120.dll, KERNEL32.dll, ADVAPI32.dll
One or more dependencies for this file may be unresolved.
Use Dpendency Walker (http://www.dependencywalker.com/) to rectify the problem.
Obviously if left to myself, I should get and run that Walker thingy. But may I ask you what the above info tells you off hand?
Then immediately another message, except it was:
LSMASHSource.r783-xp.dll
with everything else about the message, the same.
Old 26th July 2015, 03:30   #49  |  Link
TCmullet
I did get and run DependencyWalker. Said MSVCR120.dll is missing. Google tells me that's the C/C++ MS runtime.
I guess I'm wondering why it was not included in the LSMASH distribution file.
Old 26th July 2015, 04:06   #50  |  Link
TCmullet
I think I could have downloaded MSVCR120.dll from numerous places. But I ran Agent Ransack (a cool tool I love) and found I had one as part of an installation of Firefox. Properties showed it was from Visual Studio 2013, so I figure it's current enough.
I copied to system32 folder of the Windows folder, rebooted, and LSMASH works FINE.
Thanks for the pointers, Groucho.
Old 26th July 2015, 07:30   #51  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
You probably should just install the VS2013 runtime, where that DLL comes from. Copying MSVCR120.dll (or any runtime dlls) is known to cause problems; you won't get security and bugfix updates and it can get overwritten or removed accidentally.
Old 26th July 2015, 13:40   #52  |  Link
TCmullet
I googled and found vcredist_x86.exe. Installed okay. Thanks, Foxy. (My script had work w/just the dll, but I'm doin as you say.)
