Old 5th September 2013, 00:32   #21  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Originally Posted by Stereodude View Post
Well, that certainly hasn't been my experience with it. Aside from a lack of 64-bit plugins I haven't found it to be any less robust or more problematic than the 32-bit version. Heck, I was even able to get QTGMC working in 64-bit. I pretty much use 64-bit AVIsynth + MP Pipeline (for 32-bit filters that aren't available in 64-bit and enhanced "multithreading") exclusively.
Memory. AVISynth x64 (and most likely its plugins too) problem is memory cap of 4GB. When it reaches this cap - it crashes. That makes it pretty much less useful than x32 version due to the mentioned lack of plugins.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 5th September 2013, 08:30   #22  |  Link
Groucho2004
If there were a memory limit of 4 GB in Avisynth 64 there would be no point in using it.
Groucho's Avisynth Stuff
Old 5th September 2013, 22:51   #23  |  Link
Mystery Keeper
Beyond Kawaii
That IS the case.
...desu!
Old 5th September 2013, 23:05   #24  |  Link
Groucho2004
That IS the case.
OK, but then it should probably be named Avisynth 32+1 bit.
Old 6th September 2013, 01:35   #25  |  Link
Motenai Yoda
Motenai Yoda's Avatar
Yep but x86-32 crash when reach 2 GB, I don't know why, but my setup has huge temporary memory leak that reach 2gb very often, especially with setmtmode (adding setmemorymax do nothing).
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 6th September 2013, 07:45   #26  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
Avisynth 32-bit can reach 4GB memory (in theory) on Windows 64-bit when piping with applications that compiled with LARGE_ADDRESS_AWARE flag (actually this flag doesn't need to be set at compile time, there're some ultilities can modify binaries to enable it).
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain
the_weirdo is offline   Reply With Quote
Old 6th September 2013, 07:55   #27  |  Link
Groucho2004
Makes sense since the user address space for 32 bit apps on 32 bit OS is 2 GB.
Old 6th September 2013, 08:21   #28  |  Link
Mystery Keeper
Beyond Kawaii
As the_weirdo said, you need to use AviSynth with large address aware programs. If yours crashes - try using this program on it.
...desu!
Old 6th September 2013, 14:48   #29  |  Link
Motenai Yoda
I'm using tMod x264, avs4x264mod from Astrataro too, Sherpya mencoder and all of these have laa on true.
Old 12th November 2013, 13:16   #30  |  Link
TurboPascal7
TurboPascal7's Avatar
I just released a new version of FTurn. Another optimization (doing things less wrong) release, no interface changes.
In other good news: these optimizations will be integrated into Avisynth+ core in the next version, finally making this plugin obsolete. It will still work though.
Me on GitHub | AviSynth+ - the (dead) future of AviSynth
TurboPascal7 is offline   Reply With Quote
Old 13th November 2013, 12:53   #31  |  Link
PetitDragon
Hi TP7,
Please keep updating the FTurn plugin untill it is integrated into Avisynth MT for realtime playing.
PetitDragon is offline   Reply With Quote
Old 13th November 2013, 12:59   #32  |  Link
wOxxOm
Oz of the zOo
He's already integrated it in avisynth-PLUS, but avisynth-MT is an area of SEt's expertise, so SEt's the only person who can do it.
wOxxOm is offline   Reply With Quote
Old 13th November 2013, 12:59   #33  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Why you think it will ever be integrated into the Avisynth MT? And how this is related to realtime playing?
TurboPascal7
Can we possibly have RGB support? Since this will be integrated into Avisynth+, support for it will be added too right? So this is just a matter of copy-pasting. Unless with RGB there will be no speed gains...
Old 13th November 2013, 13:05   #34  |  Link
TurboPascal7
I could just redirect it to internal avisynth functions if specified colorspace is not supported or backport optimizations from avs+ to this plugin, but I don't exactly see the point. (since soon enough everyone will be using avs+ anyways, muahahaha)
We'll see how it goes, I guess, but I won't do anything right now.
Old 13th November 2013, 13:11   #35  |  Link
PetitDragon
Got it. Hope SEt will consider it. I have no problem to keep using plugin version tho.
Why you think it will ever be integrated into the Avisynth MT? And how this is related to realtime playing?...
Please refer to the link:
http://forum.doom9.org/showthread.php?p=1639044#post1639044
Old 13th November 2013, 13:16   #36  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
I agree that not that often we need to turn RGB, but I just was working with avisynth where I had to re-assemble some fragmented picture, so ended up using turns quite a lot. The reason I asked is that I thought adding RGB support will come essentially for free once it added into avisynth+ (don't see the reason to use avisynth+, maybe after some years when there will be some new awesome avisynthplus-only plugins)
Old 27th November 2013, 17:09   #37  |  Link
real.finder
hi TurboPascal7
Why not putting the original sangnom function together with the existing sangnom2, as SEt did in aWarpSharp2 in order to keep the compatibility in the old scripts with performance improvements
thanks
Old 27th November 2013, 22:21   #38  |  Link
TurboPascal7
Originally Posted by real.finder View Post
hi TurboPascal7
thanks
Will probably do with the next version (together with x64 build) some time soon. I'm not sure about the parameters though: should it use one thread? Should it have more parameters than the original sangnom? Do note that threading is going to be removed at some point once avs+ gets internal threading support.
Old 10th January 2014, 19:27   #39  |  Link
DrZine
Since FTurn is now in the core of avs+, making it obsolete, Maa2.avsi needs to be updated to not need the plugin.
DrZine is offline   Reply With Quote
Old 19th January 2014, 19:02   #40  |  Link
list
list's Avatar
Good work.
Now using the 0.2 pre-release in avisynth 2.58, works great.
You forgot to mention the new interface is Sangnom2(int order,int aa). Didn't notice that until looking at the src.
UnsharpHQ Avisynth plugin
list is offline   Reply With Quote
