Old 6th September 2015, 11:58   #21  |  Link
stax76
stax76's Avatar
sorry I missed it
Old 26th January 2016, 20:46   #22  |  Link
tObber166
import vapoursynth as vs
import finesharp
core = vs.get_core()
clip = core.lsmas.LWLibavSource(source = r'c:\test4.mts')
clip = finesharp.sharpen(clip)
clip.set_output()
"AttributeError: module 'finesharp' has no attribute 'sharpen"
What am I missing here?
tObber166 is offline   Reply With Quote
Old 26th January 2016, 20:50   #23  |  Link
sl1pkn07
Pajas Mentales...
import finesharp as finesharp
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 26th January 2016, 21:12   #24  |  Link
tObber166
Nope, I've tried that, same error output.
I'm using portable version x64, with finesharp.py in root folder, if thats matter?
EDIT: Never mind, it's working now
Old 29th January 2016, 12:21   #25  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
For future reference, this line would be:
from finesharp import finesharp
Then you can use finesharp.sharpen(). Otherwise you're stuck with finesharp.finesharp.sharpen(), and nobody likes that.
Old 21st February 2016, 11:36   #26  |  Link
Selur
Selur's Avatar
put it to python3.3/Lib/site-packages as 'finesharp.py'.
Is there a way to load the script from a custom path? (for example "G:\Hybrid\Vapoursynth\scripts\finesharp.py"?
Is
core.avs.LoadPlugin('/path/to/RemoveGrain.dll')
core.avs.LoadPlugin('/path/to/Repair.dll')
still necessary or could RemoveGrainVS be used instead?
Old 21st February 2016, 11:42   #27  |  Link
sl1pkn07
Pajas Mentales...
try with https://gist.github.com/4re/8676fd350d4b5b223ab9
Old 21st February 2016, 11:58   #28  |  Link
Selur
Selur's Avatar
# Imports
import os
import sys
# Include Scripts
scriptPath='G:/Hybrid/Vapoursynth/scripts'
sys.path.append(os.path.abspath(scriptPath))
# Import finesharp.py
# Loading Plugins
core.std.LoadPlugin(path="G:/Hybrid/Vapoursynth/vapoursynth64/plugins/SourceFilter/FFMS2/ffms2.dll")
# Loading Source: F:/TestClips&Co/Test-AC3-5.1.avi
clip = core.ffms2.Source(source="F:/TESTCL~1/TEST-A~1.AVI",cachefile="H:/Temp/avi_54a4199c1a3d3b1476ea1d15dc267332_491.ffindex",fpsnum=25)
# Sharpen
# Output
clip.set_output()
gives me:
Failed to evaluate the script:
Python exception: module 'finesharp' has no attribute 'sharpen'
Traceback (most recent call last):
  File "src\cython\vapoursynth.pyx", line 1489, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:26885)
  File "H:/Temp/tempPreviewVapoursynthFile11_07_39_848.vpy", line 16, in <module>
    # Output
AttributeError: module 'finesharp' has no attribute 'sharpen'
Old 21st February 2016, 12:10   #29  |  Link
Are_
There is a super-easy way to load from a custom place. In your site-packages folder create a file with ".pth" extension, in linux it will be something like for example:
/usr/lib/python3.5/site-packages/vapoursynth_modules.pth
Now inside that file put the custom path where the .py modules will be placed, you can add many, just one per line.
About your error I think you are using the original script from this thread, not the one sl1pkn07 linked to you. The original is somewhat dated, it does not use vapoursynth native plugins and supports only 8bit.
Are_ is offline   Reply With Quote
Old 21st February 2016, 12:15   #30  |  Link
Selur
Selur's Avatar
finesharp.py script I use is:
# finesharp.py - finesharp module for VapourSynth
# Original author: Didee (http://forum.doom9.org/showthread.php?t=166082)
# Requirement: VapourSynth r25 or later
# Rev: 2016-01-09
def spline(x, coordinates):
    def get_matrix(px, py, l):
        matrix = []
        matrix.append([(i == 0) * 1.0 for i in range(l + 1)])
        for i in range(1, l - 1):
            p = [0 for t in range(l + 1)]
            p[i - 1] = px[i] - px[i - 1]
            p[i] = 2 * (px[i + 1] - px[i - 1])
            p[i + 1] = px[i + 1] - px[i]
            p[l] = 6 * (((py[i + 1] - py[i]) / p[i + 1]) - (py[i] - py[i - 1]) / p[i - 1])
            matrix.append(p)
        matrix.append([(i == l - 1) * 1.0 for i in range(l + 1)])
        return matrix
    def equation(matrix, dim):
        for i in range(dim):
            num = matrix[i][i]
            for j in range(dim + 1):
                matrix[i][j] /= num
            for j in range(dim):
                if i != j:
                    a = matrix[j][i]
                    for k in range(i, dim + 1):
                        matrix[j][k] -= a * matrix[i][k]
    if not isinstance(coordinates, dict):
        raise TypeError('coordinates must be a dict')
    length = len(coordinates)
    if length < 3:
        raise ValueError('coordinates require at least three pairs')
    px = [key for key in coordinates.keys()]
    py = [val for val in coordinates.values()]
    matrix = get_matrix(px, py, length)
    equation(matrix, length)
    for i in range(length + 1):
        if x >= px[i] and x <= px[i + 1]:
            break
    j = i + 1
    h = px[j] - px[i]
    s = matrix[j][length] * (x - px[i]) ** 3
    s -= matrix[i][length] * (x - px[j]) ** 3
    s /= 6 * h
    s += (py[j] / h - h * matrix[j][length] / 6) * (x - px[i])
    s -= (py[i] / h - h * matrix[i][length] / 6) * (x - px[j])
    return s
def clamp(x, maximum):
    return max(0, min(round(x), maximum))
def sharpen(clip, mode=1, sstr=2.0, cstr=None, xstr=0.19, lstr=1.49, pstr=1.272, ldmp=None):
    """Small and relatively fast realtime-sharpening function, for 1080p,
    or after scaling 720p -> 1080p during playback
    (to make 720p look more like being 1080p)
    It's a generic sharpener. Only for good quality sources!
    (If the source is crap, FineSharp will happily sharpen the crap.) ;)
    Noise/grain will be enhanced, too. The method is GENERIC.
    Modus operandi: A basic nonlinear sharpening method is performed,
    then the *blurred* sharp-difference gets subtracted again.
    Args:
        clip (clip): vs.YUV or vs.GRAY video.
        mode (int): 1 to 3, weakest to strongest. When negative -1 to -3,
                a broader kernel for equalisation is used.
        sstr (float): strength of sharpening, 0.0 up to ??
        cstr (float): strength of equalisation, 0.0 to ? 2.0 ?
                (recomm. 0.5 to 1.25, default AUTO)
        xstr (float): strength of XSharpen-style final sharpening, 0.0 to 1.0
                (but, better don't go beyond 0.249 ...)
        lstr (float): modifier for non-linear sharpening
        pstr (float): exponent for non-linear sharpening
        ldmp (float): "low damp", to not overenhance very small differences
                (noise coming out of flat areas, default sstr+1)
    Example:
    .. code-block:: python
            import finesharp
    bd = clip.format.bits_per_sample
    max_ = 2 ** bd - 1
    mid = (max_ + 1) // 2
    scl = (max_ + 1) // 256
    x = 'x {} /'.format(scl)
    y = 'y {} /'.format(scl)
    src = clip
    if src.format.color_family != vs.YUV and src.format.color_family != vs.GRAY:
        raise ValueError('clip must be YUV or GRAY color family.')
    if bd < 8 or bd > 16:
        raise ValueError('clip must be 8..16 bits.')
    mode = int(mode)
    if abs(mode) > 3 or mode == 0:
        raise ValueError('mode must be 1, 2, 3, -1, -2 or -3.')
    sstr = float(sstr)
    if sstr < 0.0:
        raise ValueError('sstr must be larger than zero.')
    if src.format.color_family != vs.GRAY:
        clip = core.std.ShufflePlanes(clips=clip, planes=0, colorfamily=vs.GRAY)
    if cstr is None:
        cstr = spline(sstr, {0: 0, 0.5: 0.1, 1: 0.6, 2: 0.9, 2.5: 1, 3: 1.09,
                             3.5: 1.15, 4: 1.19, 8: 1.249, 255: 1.5})
        if mode > 0:
            cstr **= 0.8
    cstr = float(cstr)
    xstr = float(xstr)
    if xstr < 0.0:
        raise ValueError('xstr must be larger than zero.')
    lstr = float(lstr)
    pstr = float(pstr)
    if ldmp is None:
        ldmp = sstr + 0.1
    ldmp = float(ldmp)
    rg = 20 - (mode > 0) * 9
    if sstr < 0.01 and cstr < 0.01 and xstr < 0.01:
        return src
    if abs(mode) == 1:
        c2 = core.rgvs.RemoveGrain(clip=clip, mode=[11]).rgvs.RemoveGrain(mode=[4])
    else:
        c2 = core.rgvs.RemoveGrain(clip=clip, mode=[4]).rgvs.RemoveGrain(mode=[11])
    if abs(mode) == 3:
        c2 = core.rgvs.RemoveGrain(clip=c2, mode=[4])
    if bd in [8, 9, 10]:
        def expr(x, y):
            d = x - y
            absd = abs(d)
            e0 = ((absd / lstr) ** (1 / pstr)) * sstr
            e1 = d / (absd + 0.001)
            e2 = (d * d) / (d * d + ldmp)
            return clamp(e0 * e1 * e2 + mid, max_)
        diff = core.std.Lut2(clipa=clip, clipb=c2, function=expr)
    else:
        expr = '{x} {y} - abs {lstr} / log 1 {pstr} / * exp ' \
            '{sstr} * {x} {y} - {x} {y} - abs 0.001 + / * {x} {y} - log 2 * exp ' \
            '{x} {y} - log 2 * exp {ldmp} + / * 128 + {scl} *'
        expr = expr.format(x=x, y=y, lstr=lstr, pstr=pstr, sstr=sstr, ldmp=ldmp, scl=scl)
        diff = core.std.Expr(clips=[clip, c2], expr=expr)
    shrp = clip
    if sstr >= 0.01:
        shrp = core.std.MergeDiff(clipa=shrp, clipb=diff)
    if cstr >= 0.01:
            def expr(x):
                return clamp((x - mid) * cstr + mid, max_)
            diff = core.std.Lut(clip=diff, function=expr)
        else:
            expr = 'x {mid} - {cstr} * {mid} +'.format(mid=mid, cstr=cstr)
            diff = core.std.Expr(clips=diff, expr=expr)
        diff = core.rgvs.RemoveGrain(clip=diff, mode=[rg])
        shrp = core.std.MakeDiff(clipa=shrp, clipb=diff)
    if xstr >= 0.01:
        if bd in [8, 9]:
            def expr(x, y):
                return clamp(x + (x - y) * 9.9, max_)
            xyshrp = core.std.Lut2(clipa=shrp, clipb=core.rgvs.RemoveGrain(clip=shrp, mode=[20]), function=expr)
        else:
            expr = 'x x y - 9.9 * +'
            xyshrp = core.std.Expr(clips=[shrp, core.rgvs.RemoveGrain(clip=shrp, mode=[20])], expr=expr)
        rpshrp = core.rgvs.Repair(clip=xyshrp, repairclip=shrp, mode=[12])
        shrp = core.std.Merge(clipa=rpshrp, clipb=shrp, weight=[1 - xstr])
        shrp = core.std.ShufflePlanes(clips=[shrp, src], planes=[0, 1, 2], colorfamily=src.format.color_family)
    return shrp
and it's location on my system is ''G:/Hybrid/Vapoursynth/scripts/finesharp.py"
-> WORKS NOW!! Had to restart VapourSynth Editor,...
Old 22nd February 2016, 00:28   #31  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Yes, Python quirk. It caches (compiles?) the saved scripts, so editing them while Python is running does nothing until you close whatever process used Python.
...desu!
Mystery Keeper is offline   Reply With Quote
Old 18th June 2016, 16:51   #32  |  Link
hydra3333
thank you.
Now of to find the latest versions of these
RemoveGrain.dll
Repair.dll
beginner query -
I assume they could go into the root folder of embedded python where VS was also extracted to ? or a "DLLs" subfolder to be safer.
Old 18th June 2016, 19:36   #33  |  Link
Reel.Deel
Originally Posted by hydra3333 View Post
thank you.
Now of to fund the latest versions of these
RemoveGrain.dll
Repair.dll
beginner query -
I assume they could go into the root folver of embessed python where VS was also extracted to ? or a "DLLs" subfolder to be safer.
Read the documentation: http://www.vapoursynth.com/doc/autoloading.html
Also RemoveGrain and Repair already come included with VapourSynth. If you're looking for anything else take a look at this list here: http://www.vapoursynth.com/doc/pluginlist.html
Old 19th June 2016, 04:19   #34  |  Link
hydra3333
OK. Thank you.
Ah, good oh.
Old 21st August 2016, 02:32   #35  |  Link
hydra3333
So, which of these lines is the "right" way ?
import finesharp
to then use
Old 21st August 2016, 03:29   #36  |  Link
hydra3333
Downloaded the latest finesharp from post #1, but I must be doing something wrong, to receive the error message, but can't see what ... suggestions welcomed.
T:\HDTV\WDTVlive\MP4-VS\1>"C:\SOFTWARE\Vapoursynth\VSPipe.exe" "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.21.11.50.29.84.vpy" - --y4m   | "C:\SOFTWARE\ffmpeg\0-homebuilt-x64\x264-mp4.exe" - --stdin y4m --thread-input --frames 45810 --profile high --level 4.1 --preset slow --interlaced --tff --no-cabac --crf 16 --sar 64:45 --colormatrix bt470bg -o "s:\HDTV\WDTVlive\MP4-VS\1\test-temp.2016.08.21.11.50.29.84.h264"
Script evaluation failed:
Python exception: There is no function named RemoveGrain
  File "src\cython\vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:26897)
  File "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.21.11.50.29.84.vpy", line 458, in <module>
    main()
  File "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.21.11.50.29.84.vpy", line 151, in main
    video = fs.FineSharp().sharpen(video)
  File "C:\SOFTWARE\Vapoursynth\finesharp.py", line 71, in __init__
    self.rgrain = self.core.avs.RemoveGrain
  File "src\cython\vapoursynth.pyx", line 1264, in vapoursynth.Plugin.__getattr__ (src\cython\vapoursynth.c:23480)
AttributeError: There is no function named RemoveGrain
import havsfuncTS as haf # this version uses vanilla TemporalSoften instead of TemporalSoften2, as it will be "better" over time
import mvsfunc as mvs  # http://forum.doom9.org/showthread.php?t=172564
import finesharp as fs # http://forum.doom9.org/showthread.php?p=1755227#post1755227 http://avisynth.nl/index.php/FineSharp
core = vs.get_core(accept_lowercase=True) # leave off threads=8 so it auto-detects threads
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\AddGrain.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\d2vsource.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\Deblock.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\DFTTest.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\fmtconv.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\KNLMeansCL.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\libawarpsharp2.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\libmvtools.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\libnnedi3.dll') # the r'' indicates do not treat special characters and accept backslashes
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\scenechange.dll') # http://forum.doom9.org/showthread.php?t=166769
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\vsdctfilter.dll')  # http://vfrmaniac.fushizen.eu/works
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\vsfft3dfilter.dll')  # http://vfrmaniac.fushizen.eu/works
core.std.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\vapoursynth32\plugins\dll-to-choose-from\Yadifmod.dll') # the r'' indicates do not treat special characters and accept backslashes
core.avs.LoadPlugin(r'C:\SOFTWARE\Vapoursynth\DGIndex\DGDecodeNV.dll')
core.avs.LoadPlugin(r'C:\SOFTWARE\DGindex\DGDecode.dll')
def main():
    video = core.avs.MPEG2Source(r'T:\HDTV\WDTVlive\MP4-VS\1\test.d2v',info=0,iPP=True,cpu=6)  # DEBLOCK and DERING
    video = core.std.SeparateFields(video, tff=True)
    video = haf.Deblock_QED(video)
    video = haf.Weave(video, tff=True)
    video = mvs.AssumeTFF(video)
    video = haf.QTGMC(video, TFF=True, Preset="Very Slow", Sharpness=1.2, SLMode=2, EZKeepGrain=1.2, NoiseProcess=2)     # result is double framerate progressive, so re-interlate it later
    video = core.std.SelectEvery(video, cycle=4, offsets=[0, 3])     # looks like avisynth
    video.set_output()
    return True
#if __name__ == "__main__":
#    # execute main only if run as a script
#    main()
main()
Old 21st August 2016, 03:47   #37  |  Link
hydra3333
If I edit finesharp.py like this
        #self.rgrain = self.core.avs.RemoveGrain
        self.rgrain = self.core.rgvs.RemoveGrain
        #self.repair = self.core.avs.Repair
        self.repair = self.core.rgvs.Repair
I receive
T:\HDTV\WDTVlive\MP4-VS\1>"C:\SOFTWARE\Vapoursynth\VSPipe.exe" "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.21.12.13.34.49.vpy" - --y4m   | "C:\SOFTWARE\ffmpeg\0-homebuilt-x64\x264-mp4.exe" - --stdin y4m --thread-input --frames 45810 --profile high --level 4.1 --preset slow --interlaced --tff --no-cabac --crf 16 --sar 64:45 --colormatrix bt470bg -o "s:\HDTV\WDTVlive\MP4-VS\1\test-temp.2016.08.21.12.13.34.49.h264"
Python exception: RemoveGrain: Too many unnamed arguments specified
  File "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.21.12.13.34.49.vpy", line 458, in <module>
    main()
  File "T:\HDTV\WDTVlive\MP4-VS\1\test.mpg.2016.08.21.12.13.34.49.vpy", line 151, in main
  File "C:\SOFTWARE\Vapoursynth\finesharpmod20160821.py", line 136, in sharpen
    c2 = self.rgrain(self.rgrain(clip, 11, -1), 4, -1)
  File "src\cython\vapoursynth.pyx", line 1353, in vapoursynth.Function.__call__ (src\cython\vapoursynth.c:24744)
vapoursynth.Error: RemoveGrain: Too many unnamed arguments specified
So I'm a bit stuck.
Old 21st August 2016, 04:02   #38  |  Link
hydra3333
Tried Selur's version from http://forum.doom9.org/showthread.ph...55#post1757955 which looks different and is called differently, and it doesn't crash (don't know how functionally equivalent it is).
import finesharpmod20160821 as finesharp
video = finesharp.sharpen(video)
Old 21st August 2016, 10:21   #39  |  Link
~SimpleX~
This script needs an upgrade, it uses avisynth functions instead of VS equivalents. Why do you even need finesharp? It's designed for realtime sharpening of upscaled (720 -> 1080) videos. Not quite suitable for video processing.
~SimpleX~ is offline   Reply With Quote
Old 21st August 2016, 10:27   #40  |  Link
feisty2
I'm Siri
feisty2's Avatar
because there's no other choice..?
feisty2 is offline   Reply With Quote
