Old 10th September 2010, 01:37   #2561  |  Link
Autocrop works fine on your sample. Did you try it?
I will wait to look at the audio problem until you assure me the reported problems happen *with the sample you uploaded*.
Also, can you please give me the command line to demux the track using eac3to so that I can do a binary compare? Thanks.
Old 10th September 2010, 01:54   #2562  |  Link
Using your sample, I demuxed PID 1100 using Manzanita Muxer and DGIndexNV. The resulting files were binary identical.
Please advise.
Old 10th September 2010, 06:39   #2563  |  Link
Shevek
Originally Posted by mastrboy View Post
By the way, the autocrop buttons totally fails, pressing autocrop to mod16 results in the following:...
You need to find a frame in the video which has the most contrast between the black bars and content, i.e. as much white as possible.
If you try to autocrop on the first (usually all black) frame it will crop all of it and give you the result you saw.
Shevek is offline   Reply With Quote
Old 10th September 2010, 07:49   #2564  |  Link
mastrboy
Please advise.
Well i forgot to include some information, after checking it out i remember i cut the original within DGNVIndex so that the OP and ED of the episode was cut out and only the episode itself remained.
So it only happens of you change start and end in DGNVIndex, example output from eac3to:
X:\Video_Encoding\Apps\eac3to-3.24>eac3to.exe x:\test_cut_track.ac3 x:\del.m4a
AC3, 5.1 channels, 0:00:45, 448kbps, 48kHz, dialnorm: -29dB
The Nero decoder doesn't seem to work, will use libav instead.
Removing AC3 dialog normalization...
Decoding with libav/ffmpeg...
Remapping channels...
Reducing depth from 64 to 32 bits...
Encoding AAC <0.50> with NeroAacEnc...
This track is not clean.
eac3to processing took 1 second.
Done.
X:\Video_Encoding\Apps\eac3to-3.24>eac3to.exe x:\uncut.ac3 x:\del.m4a
TrueHD/AC3, 5.1 channels, 48kHz, dialnorm: -29dB
(embedded: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -29dB)
Extracting TrueHD stream...
Removing TrueHD dialog normalization...
The original audio track has a constant bit depth of 24 bits.
Done.
See image so there is no misunderstanding:
The auto-crop "issue" only happened when on the first frame, i assume that is because the entire first frame is pure black?
Edit: and yes, the audio issue also occurs on the sample i sent. The eac3to output above is from the sample.
mastrboy is offline   Reply With Quote
Old 10th September 2010, 07:55   #2565  |  Link
Yes, you must navigate to a frame showing a distinction between the video and the black bars, because the software scans in from the edge looking for the first non-black pixels. The users manual says this:
"For best results, navigate to a frame with high contrast between the video and the black bars before entering the cropping dialog."
A fully black frame will have rather low contrast.
Regarding the audio issue... You cut the sample you gave me or you cut from a larger sample? If the latter, then I'll need that larger sample, please.
Old 10th September 2010, 09:49   #2566  |  Link
mastrboy
i cut from the sample i gave you.
Old 10th September 2010, 15:00   #2567  |  Link
LigH
LigH's Avatar
I decided to give ivfenc a try and make some WebM video. Downloaded the Blender movie 1080 PNGs (ED: 21 GB / BBB: 30 GB), created an AviSynth script with ImageSource ... but the reading of the source PNGs was already the slowest part of the recoding. So I created intermediate AVC files with very low compression and then used DGDecNV to read those as "good enough semi-original" to be delivered to ivfenc.
Funny result: For each of the 2 passes, I got a Windows XP error message that the encoder crashed, but it kept running and finished with an acceptable result. The console window (I called a "start *.bat" command for a batch file running both passes in a row) closed after closing both crash dialogs.
Is that related to the issue e.g. stax76 mentioned - about "programs which open AviSynth scripts only briefly and close them without reading even one frame" which seems to crash one instance of DGDecNV?
New German Gleitz board
Old 10th September 2010, 15:37   #2568  |  Link
Hard to say. It could be, or they could be using Avisynth incorrectly like we fixed in HCEnc. Or it could be some new bug unique to what they are doing. Without their source code it's hard to say. Is the code available?
@mastrboy
OK, thank you. I will try to duplicate it.
Old 10th September 2010, 15:59   #2569  |  Link
Groucho2004
It appears to be a common problem. For example, Procoder 3 and CCE 2.7 crash as well. I only fixed this recently in my programs that process scripts after I started using DGDecodeNV.
Apparently, nobody seems to know if this is a problem with Avisynth, DGDecodeNV or the Nvidia API.
Old 10th September 2010, 16:05   #2570  |  Link
It should be possible to debug it with the source code for all the pieces. If somebody can give me source for a simple app that invokes the problem I can at least determine if it is in Nvidia or not. If not, then we could fix it. If it's in Nvidia, we could contact them. My problem is I don't have a simple app that invokes the issue. Don't even mention .NET to me.
Old 10th September 2010, 16:12   #2571  |  Link
LigH
LigH's Avatar
I believe Nic has the sources available for his AviSynth mod of ivfenc.
And stax76 mentioned that something happened to him too because he used to open the Script in StaxRip only to obtain the dimensions and frame count first. But when not reading even one frame, and closing, DGDecNV used to crash ... if I remember correctly.
Old 10th September 2010, 16:26   #2572  |  Link
Groucho2004
VC6 project here: Here
Set your breakpoint on "delete env;" at the end of _tmain.
If you want to reproduce the problem, comment out these lines:
"frame = clip->GetFrame(0, env);" (line 63)
and
"frame = clip->GetFrame(i, env);" (line 68)
Have fun
Old 10th September 2010, 16:32   #2573  |  Link
You should not be doing delete env!
That is the big no-no that we fixed in HCEnc and elsewhere.
I'll look at it though and see if anything else is going on. Thanks for providing it.
Old 10th September 2010, 16:37   #2574  |  Link
Groucho2004
That was actually not supposed to be there. Too much experimenting...
Edit: Funny thing is - now I can't reproduce it anymore.
Old 10th September 2010, 16:41   #2575  |  Link
I'm a that gets lucky now and again.
BTW, just looking at the CUVID API and knowing from experience what I do about the behavior of CUVID I can't even imagine a mechanism by which this could be caused by the CUVID code.
Old 10th September 2010, 16:58   #2576  |  Link
Groucho2004
I'll send you a program with which you can reproduce the problem later.
I just checked and double-checked. I wasn't dreaming after all.
Old 10th September 2010, 17:32   #2577  |  Link
Groucho2004
Don, check your inbox.
Old 10th September 2010, 17:45   #2578  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
ok, probably found a bug. Source: MKV file with x264 video and Vorbis (aoTuV b5) audio. DGIndexNV (2025) correctly indexes the MKV but even if the option is set it doesnt demux the audio.
mkvextract correctly extracts the audio track. is it a known problem or you need a clip?
Old 10th September 2010, 17:47   #2579  |  Link
@Groucho2004
Thanks. Investigating...
@Sharktooth
I never saw Vorbis audio and would have to add support, so if you can provide a clip it would be helpful.
Old 10th September 2010, 17:54   #2580  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
sure. ill upload it as soon as i finish sending the list (it may take a while... about 32.000 emails)
