Old 14th December 2009, 06:16   #1  |  Link
BillyWilly
BillyWilly's Avatar
Quicktime Subtitles
Hi guys! I'm converting a movie to mp4 for playback on my ipod touch, but I've hit one problem. The video comes out fine and plays great on VLC, but when I open it in Quicktime, I have this problem: the text is really big and if there are too many words on the screen, they all overlap each other. I've attached pictures.
Thanks in advance for your help!
BillyWilly is offline   Reply With Quote
Old 14th December 2009, 18:40   #2  |  Link
b66pak
b66pak's Avatar
read this:
http://forum.doom9.org/showthread.php?t=147494
_
L.E. After viewing the images i say you need to break the subtitle line in two!
_
Old 18th December 2009, 04:08   #3  |  Link
BillyWilly
BillyWilly's Avatar
The encoder I'm using automatically encodes them. How would I edit the code to allow it to break the line in two?
Old 18th December 2009, 05:49   #4  |  Link
Inspector.Gadget
Is the source a DVD?
Inspector.Gadget is offline   Reply With Quote
Old 18th December 2009, 06:24   #5  |  Link
BillyWilly
BillyWilly's Avatar
Yes, and I'm using the new update of Handbrake for the soft subtitle encoding.
Old 18th December 2009, 06:32   #6  |  Link
Inspector.Gadget
I would go the normal DGIndex->Avisynth->x264 route and make your softsubs using Subrip so you can set line widths before muxing (worst case, edit the longest line by hand, although I've never had this problem).
I realize this is inconvenient from the perspective of direct DVD->iPod using Handbrake, so if you can find a way to do your normal thing with Handbrake and rip softsubs separately with Subrip and then mux, I'd do that.
Old 18th December 2009, 06:39   #7  |  Link
BillyWilly
BillyWilly's Avatar
Yeah, I'm trying to add the subtitles post-rip. In the end, I may try that. Is there a way for Subrip to output in .SRT? If so, I can use Mp4box to mux them in.
Old 18th December 2009, 06:44   #8  |  Link
Inspector.Gadget
Subrip does do SRT (among many other formats); google around for the ai4spam character matrix to save you a LOT of time on English subs.
Old 18th December 2009, 06:55   #9  |  Link
BillyWilly
BillyWilly's Avatar
I was hoping there was a setting or a quick fix to get the perfectly functioning subtitles to work with Quicktime. Accursed Apple! Anyways, thanks everyone for all your help! I'll just try and set the line length.
Old 18th December 2009, 09:10   #10  |  Link
setarip_old
setarip_old's Avatar
Hi!
It looks like you have to reduce the font size by about half...
setarip_old is offline   Reply With Quote
Old 18th December 2009, 20:10   #11  |  Link
BillyWilly
BillyWilly's Avatar
That made sense to me, until I watched the file in Quicktime. For some reason it's just these beginning subtitles that are tripping up Quicktime, because about halfway through the movie I saw a part where the text started closer to the left side of the screen and resized itself so it would fit. Why doesn't it do that consistently throughout the movie, though?
ipod, mp4, playback, quicktime, subtitles
