5th October 2008, 00:54 | #501 | Link | ||
5th October 2008, 03:02 | #502 | Link |
I'm experiencing a bug. X264 hangs at 99.9% with VirtualDubMod and ASXGui 1.9.4. I'm not sure why it's not closing? The two programs use different builds of X264 and it's happening in both XP and Vista.
5th October 2008, 03:13 | #503 | Link | |
Software Developer
BTW: x264 + VDubMod means you use x264 VfW, which probably is not the best idea...
5th October 2008, 04:25 | #504 | Link |
I just use the Nvidia Pure Deinterlace option:
loadplugin("Z:\dgavcdecnv102\DGAVCDecodeNV.dll") avcsource("__vid__", deinterlace=true) VFW for virtualdub is correct, but ASXGui 1.9.4 uses CLI. I'll use a different CLI of X264 with it and see what happens. I just thought it was weird that it hangs with both programs in two different operating systems. I'm sure the problem is on my end because no one else seems to be experiencing it. |
5th October 2008, 18:11 | #511 | Link |
This isn't looking good for me. It behaves exactly the same in XP, Vista 32 and Vista 64. It will get to around 99% and not close. It's more than likely something about my system:
Q6600 Gigabyte p35-ds3r EVGA 9800gt 512mb 4gb ram 1.5tb raid 0 array. It's done this from day one, but I assumed it was virtualdub. I'd never tried to do a complete encoding with another program until the other day. That's when I realized it wasn't virtualdub. The memory and video card are brand new so I suppose I should run a memory check. It's not overclocked either. Last edited by meatwad; 5th October 2008 at 18:28. |
5th October 2008, 18:38 | #514 | Link |
My memory test is at 50% with no errors and I'm suspecting my GPU. I can transplant the GPU into another PC and install the necessary software, but you'd have to send me a new key for it or a test version with expiration.
GPU: EVGA 512-P3-N975-AR 9800GT 512M I can also do a bare install of XP with the necessary software to test the decoder in case it's something I have installed in all three OS that's causing the problem. Last edited by meatwad; 5th October 2008 at 18:46. |
5th October 2008, 22:51 | #516 | Link |
It still hangs even with a clean minimal install. The only codec I installed was YV 12.
@ReferenceDivx I've tested several builds and the results are the same. I don't have the sdk or the toolkit installed this time. Just the Cuda Driver. I'm going to put the card in a different machine and see if it still hangs. I hate to ask DG for another key. |
5th October 2008, 22:53 | #517 | Link | |
Software Developer
But it certainly doesn't start to encode and then decides to stall at 99.9%
5th October 2008, 22:59 | #519 | Link |
meatwad, what do you mean by cuda driver? This one?
http://www.nvidia.com/object/winxp_178.13_whql.html |
5th October 2008, 23:04 | #520 | Link |
Software Developer
What if you open the AVS script in VirtualDub and seek all the way to the end?
