Old 13th May 2015, 04:36   #29821  |  Link
JarrettH
Where does NEDI image doubling fall in terms of quality? As good as NNEDI3? Better than Jinc? It's certainly fast
Old 13th May 2015, 04:50   #29822  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
Thanks for the feedback, guys. But I do want to clear up debanding first, before moving to the other new options. FWIW, Shiandow is still working on maybe improving his debanding algorithm further. So let's give him a couple of days, and then retest, and then decide whether we keep his algorithm in madVR or not. And no, it will not stay as an option. It will either replace the current "high" preset, or it will go.
Shiandow made the following post in the MPDN thread, so he may have something new for madVR to integrate soon:
http://forum.doom9.org/showthread.ph...56#post1721756
Settings on the new debanding uses settings of threshold: 0.2 and detail level: 1
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Anime Viewer is offline   Reply With Quote
Old 13th May 2015, 04:56   #29823  |  Link
Asmodian
don't forget my source was lossless RGB a normal 4:2:0 like 99 % of all videos needs to use nnedi3 on chroma first and that means the chroma doubling will lose even more of it's power.
The improvement in that image comparison is very minimal.
A trade quality for performance checkbox that forces Catmull-Rom chroma scaling would make sense. NNEDI3 is meant to be the best of the best scaling algorithm. If the opposite logic was used, place a checkbox next to Image Doubling that allows for Jinc3 chroma scaling. Either way, it is only one checkbox.
Oh I fully agree, this isn't a use case I personally think needs supporting and I like madshi's current method. Catmull-Rom AR is great, no need for anything else.
But if users did want the slightly improved quality for similar rare sources madshi would need to allow NNEDI3 or similar, Jinc3 isn't what gave the minor improvement.
I don't find image doubling too complex or confusing in its current iteration. It is Image Enhancements and Upscaling Refinement that require simplification.
I agree and based on my limited early testing I would be happy to have all the sub options in both of those pages removed and simply have check boxes for FineSharp, LumaSharpen, and SuperRes (with its 3 presets). The defaults work pretty well for me and I have not found other settings I would rather use. However, I haven't tested a wide variety of sources yet and I am sure others like tuning for particular videos.
I think it is our job to play with all those options and a wide variety of sources to come up with some simple presets. Maybe we could agree on decent values for "low", "medium", and "high" presets or similar?
madVR options explained
Old 13th May 2015, 06:40   #29824  |  Link
cca
Anime Otaku
I've done some digging and hacking and raping Direct3D, I think I have the refresh rate problems sorted out. Give this build a try:
http://madshi.net/madVR885refreshRateFix.zip
Should work for D3D9 and D3D11 now, and also for 64bit. Once again, I've spent a lot of time to fix Microsoft's stupidity. They actually *intentionally* use 59.940Hz (23.976Hz) even if you ask for 60.000Hz (24.000Hz). There's no way to convince Direct3D to use 60.000 (24.000), except by going behind their back and twisting and binding their fingers, like I've done. I wonder if there's any other software besides madVR which can switch FSE mode to 24.000/60.000? I kinda doubt it...
Doesn't work here either, it always switches to 59.92 or 23.97 respectively instead of 60 or 24Hz. My current workaround is to run the desktop in 59 or 23Hz for now.
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit
cca is offline   Reply With Quote
Old 13th May 2015, 08:09   #29825  |  Link
edcrfv94
image quadrupling with SuperRes still not fix
edcrfv94 is offline   Reply With Quote
Old 13th May 2015, 08:21   #29826  |  Link
cvrkuth
This build work for me in D3D9/32bit scenario only. Unfortunately, it does not work in other scenarios (D3D11/32bit, D3D9/64bit, D3D11/64bit)
Intel Core i7-4790 CPU @ 3.60GHz, RAM 32 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24),
Panasonic TX-P42G20E, NVIDIA GeForce GTX 970, Win 10 Pro x64,
PotPlayer 1.7.16291 64-bit, madVR v0.92.17
cvrkuth is offline   Reply With Quote
Old 13th May 2015, 09:56   #29827  |  Link
madshi
Originally Posted by XMonarchY View Post
With build 87.21 (new 88.5 features not available in this build, Image Upscaling is set to Lanczos 3 tap, and FSE to disabled):
- Rendering times are about 20-22ms when I set Chroma Upscaling to NNEDI3 32 neurons, and Image (BOTH LUMA AND CHROMA) Doubling + Quadrupling to NNEDI3 32 neurons. No frames are dropped.
- Rendering times are about 18-20ms when I set Chroma Upscaling to NNEDI3 32 neurons, and Image (ONLY LUMA) Doubling + Quadrupling to NNEDI3 32 neurons. No frames are dropped.
- I do not get the same results with build 88.5. Please see below.
A) With build 87.21 (new 88.5 features not available in this build, Image Upscaling is set to Lanczos 3 tap, and FSE to disabled):
Original Settings
B) With build 87.21 (new 88.5 features not available in this build, Image Upscaling is set to Lanczos 3 tap, and FSE to disabled):
Chroma Doubling + Quadrupling disabled
C) With build 88.5 (ALL new features turned off, Image Upscaling is set to Lanczos 3 tap, and FSE to disabled):
- Rendering times are about 18-20ms when I set Chroma Upscaling to NNEDI3 32 neurons, and Image Doubling + Quadrupling to NNEDI3 32 neurons. No frame drop this time!
I even went back and set Image Upscaling to Jinc 3 tapm, enabled the Shiandow's Deband Algorithm, and enabled SuperRes filter for Chroma Upscaling and it produced no frame drops! Quadrupling issue is SOLVED with 88.5! . Using SuperRes fot Image Refinment in addition to settings above resulted in frame drops, but as you said - those settings are only for testing.
Ok, good to hear. Is this with Jinc3 AR selected for image upscaling?
BTW, there's one difference between v0.87.x and v0.88.x that I forgot to mention: The setting for image quadrupling is now also applied for "octadrupling" and "hexadrupling". Meaning, NNEDI3 doubling is used as long as upscaling is needed. v0.87.x used NNEDI3 max twice, v0.88.x doesn't have this limit. Is it possible that NNEDI3 is used with v0.88.x on your PC more than twice? You can see that in the debug OSD (Ctrl+J). E.g.:
> Nnedi32 > Nnedi32 > Jinc3 AR (NNEDI3 was used twice)
> Nnedi32 > Nnedi32 > Nnedi32 > Jinc3 AR (NNEDI3 was used thrice)
Originally Posted by AngelGraves13 View Post
Will you be adding 60 frames to render ahead for Windowed and Fullscreen now that D3D11 can sync to the VSYNC rate? Or am I misunderstanding the whole D3D11 mode that was recently added?
I've found setting Windowed and Fullscreen to 16 and GPU que to 16 with CPU que at 20 provides very low ms (10-20 ms) playback.
I'm not sure I understand what you're asking/saying. What is a "low ms playback"? You mean low rendering times?
Direct3D maxes out at 16 frames presented in advance.
Originally Posted by agustin9 View Post
With this build it switches to 59.93, and leave the screen in that refresh rate even after I go back to windowed. Previously when going back to windowed it switched to 59.99. Windows 8.1 here
Originally Posted by pirlouy View Post
No. As i said earlier, I already had this problem with 0.87.21 (no D3D11 if I understood correctly).
I noticed the problem with x64 build since the 64 build switches to 59Hz.
I never noticed the problem with x86 builds before because in fact the x86 build auto switches to 60Hz and I was already in 60Hz.
refreshratefix doesn't fix the issue and yes the issue is there with normal FSE mode too.
only 32 bit FSE works fine interesting.
Stupid me. I forgot that the refresh rate fix also needs new madHcNetXx.dlls. You'll find them here:
http://madshi.net/madVR885refreshRateFix2.zip
These files together with the modified madVR(64).ax should make the refresh rate work again.
ok quadrupling is not that huge sorry but placebo? not sure.chroma doubling is quiet something!
chroma upscale
jinc3AR: http://abload.de/img/nnedi3jinc3arx2syl.png
nnedix2: http://abload.de/img/nnedi3chromax2posri.png
nnedix4: http://abload.de/img/nnedi3chromax424swl.png
and with some more jinc3ar scaling on top:
jinc3AR: http://abload.de/img/nnedi3jinc3arg2sj3.png
nnedix2: http://abload.de/img/nnedi3chromax2rtsql.png
nnedix4: http://abload.de/img/nnedi3chromax4z7ssj.png
i wouldn't be shock if scaling to UHD would show some more potential for quadrupling on this source. but this source is just ...
Thanks! Could you add one screenshot with Catmull-Rom AR instead of Jinc3AR? That was the original question: Whether Catmull-Rom AR looked worse than Jinc3AR for chroma doubling.
After some tests, here is what I've noticed with 2-3 minutes from the same movie.
From best config to worst
madVR x86, No Fullscreen exclusive (windowed), No D3D11 (D3D9): 0 frames dropped/glitches
madVR x64, No Fullscreen exclusive (windowed), No D3D11 (D3D9): 2 frames dropped/glitches
madVR x86, Fullscreen exclusive, No D3D11 (D3D9): 5 frames dropped/glitches
After, all configs have problems, did not really count, but D3D11 adds dropped frames/glitches, not as much as FullScreen Exclusive+64 bits though.
And so the worst config is:
madVR 64 bits, Fullscreen exclusive, D3D11: 50 frames dropped/glitches
Some comparison with madVR 0.87.21:
madVR x86, No Fullscreen exclusive (windowed): 0 frames dropped/glitches
madVR x64, No Fullscreen exclusive (windowed): 0 frames dropped/glitches
madVR x86, Fullscreen exclusive: 1 frame dropped/glitche
madVR x64, Fullscreen exclusive: 10 frames dropped/glitches
Do these frame drops occur just when switching modes or seeking or something? Or do these drops increase during playback? If so, when those frame drops during playback occur, are the queues full or empty? Obviously, if the refresh rate fix fails to work, and your movie frame rate is really 60fps, then there *MUST* be framedrops in FSE mode, in order to keep audio and video in sync. This problem should go away once the refresh rate is correctly set to 60.000Hz.
It's too early to talk about that. Feedback is concentrated around debanding for now.
NVidia, right?
Originally Posted by detmek View Post
No problem. Like I said, I wanted to try Windows 10. I guess I should tried fresh install as Win 8.1 > Win 10 didn't work for me.
Anyway, I created 2 clips, one with Bandicam and one with my compact digicam.
Euwh, that's ugly! I can see that presentation glitches are increasing like crazy. But this problem only occurs for a few seconds after each windowed <-> FSE switch and afterwards the problem is gone and playback is smooth, without any presentation glitches etc?
Are you using madVR default settings? No custom flush settings, right?
Old 13th May 2015, 10:24   #29828  |  Link
edcrfv94
NVidia, right?
right ,NVidia GTX670 344.75
Old 13th May 2015, 10:47   #29829  |  Link
Dogway
Originally Posted by Asmodian View Post
If you only have one setting madVR will switch to that setting.
madVR should only switch to 1080p24 for 24fps sources, anyway. So what else do you want?
I have a 60fps video and I don't want madvr to do anything if source framerate is not 24p.
edit: And to answer before you ask, no, I don't want to add 1080p60 since that switches to 60p screen mode, and I want to play the file at "1080 @ 60Hz" screen mode (aka in PC mode).
Old 13th May 2015, 10:47   #29830  |  Link
detmek
No custom flush settings. I tried with defaults, disabling FSE, changing queues, scaling algorithms... Problem remains. Its worse if I activate Smooth Motion and disable FSE and its a bit worse on Windows 7. Then it stutters the all the time in full screen windowed mode. In FSE it stops after few seconds because presentation queue goes full after few seconds.
Another thing, presetation gliches do not rise always. Sometimes those do not change even if video stutters with out of order frames.
Intel Pentium G3220, Asus H81M-K, 4GB DDR3@1600MHz (1333MHz working), LG W1934S, Windows 8.1 Pro x64
detmek is offline   Reply With Quote
Old 13th May 2015, 11:00   #29831  |  Link
cvrkuth
Yes, madvr display modes work correctly now. Thanks!
Old 13th May 2015, 12:06   #29832  |  Link
added in the post
i would say catmull-rom is better for this source.
but this isn't a perfect x4 upsacale so it is used for image scaling too. simply not a perfect comparison.
edit: madVR885refreshRateFix2.zip works fine
Old 13th May 2015, 12:41   #29833  |  Link
pirlouy
_
Stupid me. I forgot that the refresh rate fix also needs new madHcNetXx.dlls. [...]
Confirmed ! It really works !
It is during playback. Each time I enter Fullscreen, I wait 2-3 seconds then press Ctrl+R to reset stats.
They are full. Then 1 frame dropped, and they are full just after.
I was testing on a monitor which does not have 59Hz, only 60 (even if it's 59,88 in reality). The video was 25Hz interlaced, with smooth motion. So indeed, 50 does not match 60, but with smooth motion, it should be ok. And I managed to have 0 dropped frame/glitche during these 2-3 minutes.
If I take a classic 23,976 Hz video, I have the same dropped frames/glitches ratio.
Old 13th May 2015, 12:56   #29834  |  Link
aufkrawall
added in the post
Hard to say what is caused by luma or chroma upscaling.
But with C-R, the blue robe of "Mangust" is clearly more aliased than with Jinc.
Old 13th May 2015, 13:19   #29835  |  Link
yes agree. but look at the icon on the right jinc3ar is blurring them like crazy. for example look at the person in the red robe with the "sparkles" on top of it catmull-rom is a lot sharper there and shows more "details" for more aliasing. the icon in the top right with the blue dots is clearly better with catmull-rom ar.
this is not even the same frame i try to fix this.
Old 13th May 2015, 14:00   #29836  |  Link
Werewolfy
Well in this picture catmull-rom ar is even better than Jinc... Look at the picture on top of the men around the fire. The blue part is blurry with Jinc and Nnedi3.
Edit : Ok I didn't notice you edited your post
Windows 8.1 and 10 x64 - Intel Core i5-4670K (4.2 GHz) - 8 GB DDR3 - MSI Geforce GTX 1080 8 GB - Sony KD-55A1 - Denon AVR-X3600H
Werewolfy is offline   Reply With Quote
Old 13th May 2015, 14:15   #29837  |  Link
kalston
Originally Posted by mark0077 View Post
madshi, this is a question, not specifically related to the newer versions of madVR so absolutely no priority in a reply to this (FYI using the latest 0.88.5 version)
I just got a GTX 980 and have it overclocked as much as I can push it, so I have been experimenting with NNEDI 32 neurons for image doubling / quadrupling. Quadrupling seems to be working fine at 32 neurons on very low resolution files. I'm now testing of a movie which is 1280 x 720, so to get to 1920 x 1080 I can see the following is being used in Ctrl-J stats
chroma > Jinc3 AR
luma > Nnedi32 < Catmull-Rom AR
chroma > Catmull-Rom AR
This seems to be alot more demanding than the quadrupling of the lower resolution files, which is fine, so in gpu-z I can see GPU Load hitting ~90% but my question is.
I don't see any dropped frames, delayed frames or presentation glitches, however the queues are as follows
decoder queue 15-16 / 16
upload queue 7-8 / 8
render queue 1-2 / 8
present queue 0-2 / 8
My question is, although I know my gpu is literally at its absolute limits, how come some of the queues seem full, while others are nearly empty all the time, yet my gpu isn't under enough pressure to drop frames. Absolutely very low priority question, just thought it was worth mentioning as I'm not sure if the render and present queues not being full in this scenario may be something madVR is controlling and could potentially be improved to have them more full seeing as frames aren't being dropped.
Those stats blow, do you have a gsync monitor maybe? I get stats like that (including the GPU usage) only when I go FSE with gsync enabled (it's a bug FYI but I think it's nvidia's and not madvr's fault - by using less demanding settings you can fix the queues and get smooth playback). Otherwise I do NNEDI13 128 or 256 easily for 720p to 1440p on a gtx 970 (assuming 24/25 fps content - might have to go down to 32 for 60fps for example).
kalston is offline   Reply With Quote
Old 13th May 2015, 14:16   #29838  |  Link
cca
Anime Otaku
Yay, it works perfectly now!
Old 13th May 2015, 14:44   #29839  |  Link
madshi
chroma upscale
editv2: catmull-rom AR http://abload.de/img/nnedi3catv2misgl.png
edit2:added the right frame
Ok, Jinc has less aliasing but is also softer than Catmull-Rom. At least we can see that there *is* a difference. However, there's zero difference I can see between enabling and disabling chroma quadrupling. Which may suggest that only the first chroma upsampling operation is important. For 4:2:0 that would be 4:2:0 -> 4:4:4 upsampling. After that, probably chroma doubling would show no visible differences.
So I'm somewhat torn now: With this PC game, chroma doubling helps, and also Jinc looks "different" to Catmull-Rom. So maybe I should put both chroma doubling and Jinc back in? But with a 4:2:0 source maybe there's no difference at all. However, "upscaling refinement" could result in sharpening the chroma channel so much that doubling after refinement might make a difference, once again. So maybe that's a good argument for putting it all back in? Opinions?
What is the difference between 60p screen mode and "1080 @ 60Hz PC mode"?
Ok, I have a guess at what might be wrong. I'll create a test build for you or two to test my theory. I really wish I could reproduce it myself, but for some reason I can't...
At the moment when the frame drop occurs, are the queues near empty or are they still full right at that moment? In any case, a log file might clear this up. With smooth motion enabled, there really should not be any frame drops, as long as your GPU is fast enough.
Old 13th May 2015, 15:04   #29840  |  Link
Shiandow
So I'm somewhat torn now: With this PC game, chroma doubling helps, and also Jinc looks "different" to Catmull-Rom. So maybe I should put both chroma doubling and Jinc back in? But with a 4:2:0 source maybe there's no difference at all. However, "upscaling refinement" could result in sharpening the chroma channel so much that doubling after refinement might make a difference, once again. So maybe that's a good argument for putting it all back in? Opinions?.
Not sure if it helps, but have you tried using SuperChromaRes for the extra chroma scaling? It should be quite good at making the chroma match the luma, and however many passes you need it's probably still going to be faster than NNEDI3. Of course there's not much point if the quality is worse, but I think it could work quite well.
