2nd August 2008, 15:42 | #61 | Link |
Software Developer
Yes, I did some more changes to MPUI. For example I exchanged the MPlayer logo and I added code to center the MPUI window on your screen.
Also note that CPU usage in Taskmanger alone doesn't say much about the actual performance of an application. For example higher CPU usage can also mean that there are less situations in which the application has to wait idly, so the performance might actually be better. Especially on multi-core (multi-processor) systems a higher CPU usage usually (but not always!) indicates better performance due to better multi-threading. However if you feel the older build works better on your machine, feel free to use it...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 2nd August 2008 at 15:57. |
2nd August 2008, 16:22 | #62 | Link |
Many thank's for your reply, mate
Yes, i had noticed the collor change and center window placement and that was actually also what i meant about "small UI changes" Yes, about the cpu usage, then i understand what you say, but i was just very puzzled about the newer P4 optimized build did use about the double amount of cpu resources and about 7MB more in ram consumption, and as i only have a P4 1.7GHz with 256mb ram and where 32mb's of that is shared with the on-board graphics, then i will use your MPUI compile together with the MPlayer build from the official MPUI package(dev-SVN-r26251-3.4.2 compiled with CPU runtime-detection)... Again, many thanks for your work and reply CU, Martin. |
2nd August 2008, 16:47 | #63 | Link |
Software Developer
Time for a RAM upgrade! You can get 4 GB of RAM for 60€ these days ...
http://www.alternate.de/html/product...R2-800/229135/
2nd August 2008, 17:12 | #64 | Link |
Yeah, i know, but instead of upgrading my system because of bloated and resource hungry apps, then i just instead preffer to use effecient apps instead...
That's also the reason for me using Win2K with Fred Vorck's IE/Junk removal fileset, instead of XP or Vista and hence, my commit is just 34MB |
14th August 2008, 10:41 | #65 | Link |
A hollow voice says
I just tried out this windows mplayer package; nice. I've noticed two items, common to both front-ends, that I hope someone can shed light on.
1) When I add the -benchmark option, the output it is supposed to generate does not appear in the log files. 2) A "-vf screenshot" filter is being added somewhere (which causes a software scalar to be invoked for yv12 to rgb24 on my system). I couldn't find it in any of the gui options, and ended up having to add a -vf-del to undo it. Comments? TIA! |
15th August 2008, 15:56 | #67 | Link |
Hi Mulder!!Its really sad,i can no longer use your versions,when i try start a avi file,it tries to start it,it can take maybe up to 1min.And sometimes it crashes the exit code 62097.
Ive tried to post this to Sherpya with no luck. The SMPlayer Standalone package i can use,so it must be something else.Im really sad i like your builds. Here is a log below,before the exit code. Code:
C:/Program Files/MPlayer for Windows/MPlayer.exe -noquiet -nofs -sub-fuzziness 1 -identify -slave -vo gl -ao dsound -zoom -nokeepaspect -priority abovenormal -framedrop -subfont-autoscale 1 -subfont-text-scale 5 -subcp ISO-8859-1 -subpos 100 -cache 2000 -osdlevel 1 -vf-add screenshot -channels 6 -af equalizer=0:0:0:0:0:0:0:0:0:0 -sws 9 C:\Users\Hogge\Desktop\WWESUM~1.XVI\KYR-WW~1.AVI MPlayer Sherpya-SVN-r27323-4.2.4 (C) 2000-2008 MPlayer Team CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ (Family: 15, Model: 107, Stepping: 1) 3DNow supported but disabled 3DNowExt supported but disabled CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 Setting process priority: abovenormal Playing C:\Users\Hogge\Desktop\WWESUM~1.XVI\KYR-WW~1.AVI. Cache fill: 0.00% (0 bytes) AVI file format detected. ID_VIDEO_ID=0 [aviheader] Video stream found, -vid 0 ID_AUDIO_ID=1 [aviheader] Audio stream found, -aid 1 VIDEO: [XVID] 512x384 12bpp 29.970 fps 940.8 kbps (114.8 kbyte/s) Clip info: Software: VirtualDubMod 1.5.10.2 (build 2540/release) ID_CLIP_INFO_NAME0=Software ID_CLIP_INFO_VALUE0=VirtualDubMod 1.5.10.2 (build 2540/release) ID_CLIP_INFO_N=1 ID_FILENAME=C:\Users\Hogge\Desktop\WWESUM~1.XVI\KYR-WW~1.AVI ID_DEMUXER=avi ID_VIDEO_FORMAT=XVID ID_VIDEO_BITRATE=940760 ID_VIDEO_WIDTH=512 ID_VIDEO_HEIGHT=384 ID_VIDEO_FPS=29.970 ID_VIDEO_ASPECT=0.0000 ID_AUDIO_FORMAT=85 ID_AUDIO_BITRATE=128616 ID_AUDIO_RATE=0 ID_AUDIO_NCH=0 ID_LENGTH=1798.63 ID_SEEKABLE=1 [gl] using extended formats. Use -vo gl:nomanyfmts if playback fails. Opening video filter: [screenshot] ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4) ========================================================================== ID_VIDEO_CODEC=ffodivx ========================================================================== Opening audio decoder: [mp3lib] MPEG layer-2, layer-3 AUDIO: 48000 Hz, 2 ch, s16le, 128.0 kbit/8.33% (ratio: 16000->192000) ID_AUDIO_BITRATE=128000 ID_AUDIO_RATE=48000 ID_AUDIO_NCH=2 Selected audio codec: [mp3] afm: mp3lib (mp3lib MPEG layer-2, layer-3) ========================================================================== AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample) ID_AUDIO_CODEC=mp3 Starting playback... VDec: vo config request - 512 x 384 (preferred colorspace: Planar YV12) Could not find matching colorspace - retrying with -vf scale... Opening video filter: [scale] VDec: using Planar YV12 as output csp (no 0) Movie-Aspect is 1.33:1 - prescaling to correct movie aspect. ID_VIDEO_ASPECT=1.3333 [swscaler @ 0pecdba4]using unscaled yuv420p -> rgb32 special converter VO: [gl] 512x384 => 512x384 BGRA [zoom] |
15th August 2008, 16:11 | #68 | Link |
Software Developer
Try this from the commandline:
"C:\Program Files\MPlayer for Windows\MPlayer.exe" -noquiet "C:\Users\Hogge\Desktop\WWESUM~1.XVI\KYR-WW~1.AVI" If it still crashes, than it's a problem in the MPlayer, either in MPlayer itself or in Sherpya's build. I have some problem with the latest MPlayer builds too and I tried to report these in the MPlayer IRC channel. But with "unofficial" Win32 builds they aren't willing to give support...
15th August 2008, 19:13 | #69 | Link | |
Software Developer
http://www.mediafire.com/?pl2m9lohwvr Feedback from Vista users welcome
17th August 2008, 04:20 | #72 | Link |
Hogge there is no problem with the current build....
mplayer has issues with Vista and Direct Draw, try changing the Video Out driver to gl:yuv=3 or gl:yuv=2:force-pbo:ati-hack i've found these 2 to give the best performance. |
17th August 2008, 07:58 | #73 | Link |
Hi dat!Ive tried that,its the latest 3-4 builds that i have problem with.Mplayer,Smplayer tries to start a video [avi] it can take up to a minute,and sometimes it doesnt.And dat do you now what exit code 62097 is?Thanks every body for trying to help,RVM Smplayer i can run.But i prefer Mulders.
18th August 2008, 03:22 | #77 | Link | |
As said its not a large amount of money and still about the best power/speed upgrade for any OS.
EncodingBox DFI-LP RDX200 CF-DR AMD4200x2 @2.5GHz 2GB G.Skill HZ's x1650XT Corsair HX620 Eclipse62 LG GSA-H42N Lite0n SHM-165P6S Asus CRW-5232A Optiarc AD-5170A Sony e500's & Ducky 1087 via KVM |
19th August 2008, 20:42 | #78 | Link |
@Lenny_Nero:
Thank's for your reply, mate Yeah, i see your point, but as i'm not using background-running stuff like anti-virus/malware(i just re-image every 7-14 days, or if having a problem and simply use common-sence), and are just using apps like Opera, ImgBurn,7-Zip, foobar2000, SumatraPDF and MPUI etc, then i'm actually alright with 256mb, but if running big apps and doing e.g. video encoding and such, then it would of course be a big bottleneck, but anyway, thanks again for your reply, and i apologise to Mulder for the off-topic'ness... |
19th August 2008, 22:52 | #80 | Link | |
Software Developer
BUT: The latest MPlayer builds for Win32 date back to 2008-07-18, so you might need to wait for fresh builds or compile your own MPlayer.exe ...
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 19th August 2008 at 22:55. |
mplayer, mpui, player, smplayer, win32 |
