Old 23rd October 2019, 16:44   #17581  |  Link
byteshare
ByteShare
byteshare's Avatar
Would it be possible in a future update to change some of the EncodingClient behavior so that it can stay minimized (if you minimize it) or not steal focus when a new job comes up?
This isn't urgent but it was less noticeable for me before some of the fixes that sped up my encodes. While working on other things, the EncodingClient is either popping up in-front of things and/or taking focus.
(similar to how the main RB window can stay minimized or the encoding servers)
Old 23rd October 2019, 17:07   #17582  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
If Ripbot264.exe is minimized then EncodingClient.exe will also start as minimized (focus is not stolen). Works fine on my win7.
Old 23rd October 2019, 20:29   #17583  |  Link
skylinekiller
Originally Posted by Pauly Dunne View Post
Are you sure you have that folder ??
I got the latest update earlier today, and there was a problem downloading that item.
There's an ssatosrt folder, but not the srttossa..
Yes, please see the pic I posted. That is the folder with the files inside of it. no Default file though
skylinekiller is offline   Reply With Quote
Old 23rd October 2019, 23:57   #17584  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
Got the latest update this morning, but something went wrong (tried it twice)
2019-10-23 10:00:25 : New section [SRTtoSSA] detected
2019-10-23 10:00:25 : Downloading file http://atak-snajpera.5v.pl/ripbot264update/SRTtoSSA.zip to D:\RipBot264v1.25.0\Updates\SRTtoSSA.zip
2019-10-23 10:00:25 : [ERROR] File http://atak-snajpera.5v.pl/ripbot264update/SRTtoSSA.zip could not be downloaded!
2019-10-23 10:00:25 : Downloading finished.
And how do you access what this does ??
(edit), so another auto update today, and this time, this DID come in...
Not poorly done, just doin' it my way !!!
Live every day like it's your last, because one day, it will be !! (M$B)
Pauly Dunne is offline   Reply With Quote
Old 23rd October 2019, 23:59   #17585  |  Link
Pauly Dunne
Grumpy Old Man.
Cannot open your attachment, you need to post them some other way.
See if you can get the very latest auto update !!
Old 24th October 2019, 05:56   #17586  |  Link
byteshare
ByteShare
byteshare's Avatar
Ah, okay. I usually keep RB (main window) up to see where in the queue I am but like the Client minimized. If I keep everything minimized it all stays minimized.
Old 25th October 2019, 02:28   #17587  |  Link
Pauly Dunne
Grumpy Old Man.
Are you really sure about that, byteshare ??
Mind you, doesn't the Client maximise, when it start's a new Job ?!?
I can have ANY combo I like open, either both minimized, both maximized, or either one, min. &/or max. (Windows 10 1903 19h1 & Windows Server 2019).
Old 25th October 2019, 14:11   #17588  |  Link
Pauly Dunne
Grumpy Old Man.
That said, if you are using filters like MDGrain2, IMO you shouldn't worry about the bitrate because you're going to be chopping out a lot with that so you should just use CRF12 or so from what it I'm guessing you like.
Just wanted to say that I did a 1080p x264 to 1080p x265 conversion today, 10 bit Profile, Tune set to Grain, and using CRF 16 (didn't know how to get any lower).
It came out with a lower bitrate, approx 2Gb smaller than original, but it was pretty damn good, a lot more defined & sharper.
I am going to compare it to the same settings, BUT 1 pass @ 30Mp/s, and see if I can tell the difference.
Old 25th October 2019, 14:27   #17589  |  Link
Atak_Snajpera
Use keyboard.
Old 25th October 2019, 16:02   #17590  |  Link
brumsky
@atak_snajpera
Could you please add an option for AAC 7.1?
thanks for the great software!
brumsky is offline   Reply With Quote
Old 25th October 2019, 16:27   #17591  |  Link
byteshare
ByteShare
byteshare's Avatar
Yes, on Win10, if I have both minimized they both stay minimized but if I have one open the client comes back when a new job starts.
Now that I realize the behavior I just keep the RB window minimized after looking at it.
Old 25th October 2019, 18:28   #17592  |  Link
Pauly Dunne
Grumpy Old Man.
Use keyboard.
Old 26th October 2019, 03:57   #17593  |  Link
Pauly Dunne
Grumpy Old Man.
Like I said, if you can afford buy Samsung 970 PRO (MLC)... Adata sx8200 also looks good until 60GiB mark.
OK, so I now have my 2 ADATA SX8200's installed, and I just did your IO tester on them..so I'm sure you're interested in the numbers, so could you kindly suss out the .csv's, and post the graphs & comment
https://www.mediafire.com/file/ifcds...sktop.rar/file
Old 26th October 2019, 12:30   #17594  |  Link
Atak_Snajpera
I would return them ASAP. SLC cache only 5 GiB?!?
Read speed looks good though...
Old 26th October 2019, 12:55   #17595  |  Link
Pauly Dunne
Grumpy Old Man.
WOW, that is EXTREMELY disappointing !!!, mind you, not too sure what that SLC cache means
I doubt I will return them, but I certainly wouldn't buy then again, but as they are WAY better than anything else I have.
I did a test on a RAID-0 of Seagate 3Tb 7200rpm spinners, and it was surprising fast...
So, with these being 512Mb NVME's, the performance must be down on the 1Tb that everyone seems to write about.
Could it be the adapter's...could it be the "slot" I have them in ??
The adapters I got are a full x16 type, and I have them in a x16 slot.
Would it be better or worse if they were in a x8 slot, even though I would think they would only use the speed they need.
Old 26th October 2019, 13:06   #17596  |  Link
Atak_Snajpera
You may try doing RAID-0 to at least get consistent 1 GiB/s write speed...
Old 26th October 2019, 13:11   #17597  |  Link
Pauly Dunne
Grumpy Old Man.
So you don't think it would change anything using different PCI-e slots ??
And the only way to create a RAID-0 would be in Windows Disk Management.
I will suss that out, seeing I haven't really used them yet, and I will send you the results.
BTW, were there different results in the 60Gb test ??
Old 26th October 2019, 13:15   #17598  |  Link
Atak_Snajpera
Read speed clearly shows that everything is ok with your setup
No. 60GiB test is basically a truncated 120GiB test. Write speed sucks because you bought TLC drive instead of MLC.
Old 26th October 2019, 13:20   #17599  |  Link
Pauly Dunne
Grumpy Old Man.
OK, fair enough, thanks for this.
I guess I'll have to do a bit more "research", but I guess I should just "man up" and get the 970 Pro's that you suggested in the first place.
I will have to reach out to byteshare to test his NVMe's, and see what results he gets.
Old 26th October 2019, 13:23   #17600  |  Link
Atak_Snajpera
yeah. If your workflow requires high consistent write speed then TLC/QLC is a big no no.
