12th March 2012, 18:15 | #43 | Link |
Ok
With this one http://jumbofiles.com/68n2f1y2d7wp after going to "SETUP" I'm stuck, I can't go / navigate anywhere else Let me know how jumbofiles works for you P.S. Check your PM EDIT: Can't build rev 42 missing time.h ? Code:
2>ClCompile: 2> graphics_controller.c 2>c:\dslibbluray\libbluray\src\libbluray\decoders\graphics_controller.c(29): fatal error C1083: Cannot open include file: 'util/time.h': No such file or directory 2> 2>Build FAILED.
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 12th March 2012 at 19:54. |
13th March 2012, 08:10 | #45 | Link |
This one seems different (but I'm not sure ) also no start (SVN Rev 45)
Case 3 Code:
c:\dslibbluray\libbluray\src\libbluray\bluray.c:695: BDSVM/00000.svm not found. No BD+ protection (04E435C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:876: BLURAY initialized! (04E435 C8) c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR16 ( AUDIO_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR17 ( PG_AND_SUB_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\register.c:391: bd_psr_write(): PSR18 ( PSR_MENU_LANG) 0xffffff -> 0x656e67 c:\dslibbluray\libbluray\src\libbluray\bluray.c:2079: PSR change: psr3 = 1 (04E4 35C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2079: PSR change: psr4 = 65535 ( 04E435C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2079: PSR change: psr0 = 1 (04E4 35C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2079: PSR change: psr1 = 255 (04 E435C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2079: PSR change: psr2 = 2683740 15 (04E435C8) c:\dslibbluray\libbluray\src\libbluray\bluray.c:2079: PSR change: psr14 = 65535 (04E435C8) c:\dslibbluray\libbluray\src\libbluray\register.c:389: bd_psr_write(4, 65535): n o change in value c:\dslibbluray\libbluray\src\libbluray\bluray.c:2048: PSR write: psr4 = 65535 (0 4E435C8) ERROR: transport error 202: connect failed: Connection refused ERROR: JDWP Transport dt_socket failed to initialize, TRANSPORT_INIT(510) c:\dslibbluray\libbluray\src\libbluray\register.c:389: bd_psr_write(4, 65535): n o change in value c:\dslibbluray\libbluray\src\libbluray\bluray.c:2048: PSR write: psr4 = 65535 (0 4E435C8) 800 200 205 207 1004 800 java.lang.NoSuchMethodError: java.lang.Integer: method valueOf(I)Ljava/lang/Inte ger; not found at org.havi.ui.event.HKeyCapabilities.<clinit>(HKeyCapabilities.java:48) at java.lang.Class.runStaticInitializers(Compiled Method)(Class.java:164 3) at java.lang.Class.runStaticInitializers(Compiled Method)(Class.java:162 9) at a.a.g.b.c(Compiled Method)(Unknown Source) at a.a.g.b.<init>(Compiled Method)(Unknown Source) at a.a.b.at.<init>(Compiled Method)(Unknown Source) at a.a.b.v.a(Compiled Method)(Unknown Source) at a.a.c.a.c(Compiled Method)(Unknown Source) at netblender.DoXlet.startXlet(Compiled Method)(Unknown Source) at org.videolan.BDJAppProxy.doStart(Compiled Method)(BDJAppProxy.java:17 0) at org.videolan.BDJAppProxy.run(Compiled Method)(BDJAppProxy.java:279) at java.lang.Thread.run(Compiled Method)(Thread.java:714) at java.lang.Thread.startup(Compiled Method)(Thread.java:785)
Intel UHD Graphics 750; Win 10 22H2 |
13th March 2012, 10:46 | #46 | Link | |
try libbluray.jar in just renewed test0313.zip.
13th March 2012, 11:04 | #47 | Link |
It's still not working
Also I have a problem with TrueHD Code:
f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:450: _preload_ m2ts(): loaded 7231488 bytes from 00006.m2ts f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:1361: _find_ig _stream(): current IG stream pid 0x1400 sub-path 0 [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] Lossless check failed - expected f3, calculated b7. [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] Lossless check failed - expected 14, calculated a3. [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] Lossless check failed - expected e7, calculated 50. [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] Lossless check failed - expected 14, calculated e7. [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] Lossless check failed - expected 00, calculated 44. [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] Lossless check failed - expected a3, calculated 44. [truehd @ 0003d5a0] Invalid nonrestart_substr. [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] Lossless check failed - expected 44, calculated f3. [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] Lossless check failed - expected 00, calculated 50. [truehd @ 0003d5a0] mlpparse: Parity check failed. [truehd @ 0003d5a0] mlpparse: Parity check failed. Here is the sample http://jumbofiles.com/3fhy4bsvhjcy you need to add it to my previous sample http://www.rayfile.com/zh-cn/files/d...-0015c55db73d/ EDIT: also I have no sound with any LPCM stream no matter what decoder I'm using FFD or LAV
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 13th March 2012 at 11:13. |
13th March 2012, 11:30 | #48 | Link |
TrueHD is special, the Blu-ray source filter needs to remove the embedded AC3 or it won't work properly.
13th March 2012, 17:41 | #49 | Link |
try libbluray.jar in test0314.zip. I think there should be no java.lang.*error. last one is not properly compiled. I clean and rebuild it.
decoder compatible is not so high priority, I won't fix it now, maybe someother can help to improve it. Last edited by cb2000; 13th March 2012 at 17:43. |
13th March 2012, 18:17 | #50 | Link | |
Anyway with test0314 LPCM it's working but just with FFD LAV it's failing with this one too Code:
[pcm_bluray @ 1c398e20] unsupported channel configuration (0) Code:
f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:853: libbluray version 0.2.2 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:569: AACS/Unit _Key_RO.inf not found. No AACS protection (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:695: BDSVM/000 00.svm not found. No BD+ protection (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:876: BLURAY in itialized! (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR16 (AUDIO_LANG) 0xffffff -> 0x656e67 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR17 (PG_AND_SUB_LANG) 0xffffff -> 0x656e67 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR18 (PSR_MENU_LANG) 0xffffff -> 0x656e67 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr3 = 1 (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr4 = 65535 (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr0 = 1 (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr1 = 255 (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr2 = 268374015 (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr14 = 65535 (049D31D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:389: bd_psr_ write(4, 65535): no change in value f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2048: PSR writ e: psr4 = 65535 (049D31D8) ERROR: transport error 202: connect failed: Connection refused ERROR: JDWP Transport dt_socket failed to initialize, TRANSPORT_INIT(510) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:389: bd_psr_ write(4, 65535): no change in value f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2048: PSR writ e: psr4 = 65535 (049D31D8) 800 200 205 207 1004 800 java.lang.Error: Not implemented at java.awt.BDGraphics.drawLine(Compiled Method)(BDGraphics.java:324) at a.a.b.ba.<init>(Compiled Method)(Unknown Source) at a.a.b.c.<init>(Compiled Method)(Unknown Source) at a.a.b.at.<init>(Compiled Method)(Unknown Source) at a.a.b.v.a(Compiled Method)(Unknown Source) at a.a.c.a.c(Compiled Method)(Unknown Source) at netblender.DoXlet.startXlet(Compiled Method)(Unknown Source) at org.videolan.BDJAppProxy.doStart(Compiled Method)(BDJAppProxy.java:17 0) at org.videolan.BDJAppProxy.run(Compiled Method)(BDJAppProxy.java:279) at java.lang.Thread.run(Compiled Method)(Thread.java:714) at java.lang.Thread.startup(Compiled Method)(Thread.java:785)
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 13th March 2012 at 18:25. |
14th March 2012, 02:01 | #51 | Link |
"java.lang.Error: Not implemented" is sothing not implemented, other is a bug
java.lang.NoSuchMethodError has gone, that is cause by not correct compile compilation. I want to know as many as "java.lang.Error: Not implemented" and what cause it (the next line), such as "at java.awt.BDGraphics.drawLine(Compiled Method)(BDGraphics.java:324) ", so that I can implement them first. Pleast post it if u find another. Last edited by cb2000; 14th March 2012 at 02:05. |
14th March 2012, 08:32 | #53 | Link |
Yes it seems OK for me too
f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:853: libbluray version 0.2.2 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:569: AACS/Unit _Key_RO.inf not found. No AACS protection (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:695: BDSVM/000 00.svm not found. No BD+ protection (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:876: BLURAY in itialized! (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR16 (AUDIO_LANG) 0xffffff -> 0x656e67 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR17 (PG_AND_SUB_LANG) 0xffffff -> 0x656e67 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR18 (PSR_MENU_LANG) 0xffffff -> 0x656e67 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr3 = 1 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr4 = 65535 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr0 = 1 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr1 = 255 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr2 = 268374015 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr14 = 65535 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:389: bd_psr_ write(4, 65535): no change in value f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2048: PSR writ e: psr4 = 65535 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2351: HDMV eve nt: 7 0 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR11 (MENU_PAGE_ID) 0x0 -> 0xff f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr11 = 255 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2351: HDMV eve nt: 3 17 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:389: bd_psr_ write(11, 255): no change in value f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2048: PSR writ e: psr11 = 255 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR4 (TITLE_NUMBER) 0xffff -> 0x11 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr4 = 17 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2351: HDMV eve nt: 7 0 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:389: bd_psr_ write(11, 255): no change in value f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2048: PSR writ e: psr11 = 255 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2351: HDMV eve nt: 4 97 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:389: bd_psr_ write(11, 255): no change in value f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2048: PSR writ e: psr11 = 255 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR6 (PLAYLIST) 0x0 -> 0x61 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr6 = 97 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:389: bd_psr_ write(3, 1): no change in value f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2048: PSR writ e: psr3 = 1 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR5 (CHAPTER) 0xffff -> 0x1 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr5 = 1 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:389: bd_psr_ write(7, 0): no change in value f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2048: PSR writ e: psr7 = 0 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR8 (TIME) 0x0 -> 0x7fff8 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr8 = 524280 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:190: Selected stream 0 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\register.c:391: bd_psr_ write(): PSR1 (PRIMARY_AUDIO_ID) 0xff -> 0x1 f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:2079: PSR chan ge: psr1 = 1 (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:1595: Title 00 097.mpls selected! (049131D8) f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bluray.c:1529: Playback rate change to 1.000000 ! (049131D8)
14th March 2012, 11:46 | #55 | Link | |
Another problem this one I can play it but in the menu I can't see the buttons http://jumbofiles.com/b1et3hqywezc & http://jumbofiles.com/l973wfnfle33 P.S. I'm using Revision 52 EDIT: And if you have some time I have some crashing too Code:
Unhandled exception at 0x7072036c (bluray.dll) in demo_player.exe: 0xC0000005: Access violation reading location 0x0000001c. Call Stack > bluray.dll!bd_read(bluray * bd, unsigned char * buf, int len) Line 1223 + 0x17 bytes C++ Code:
Unhandled exception at 0x6ffd14db (bluray.dll) in demo_player.exe: 0xC0000005: Access violation reading location 0xddddde19. Call Stack > bluray.dll!_find_pg_stream(bluray * bd, unsigned short * pid, int * sub_path_idx) Line 1400 + 0x8 bytes C++
Intel UHD Graphics 750; Win 10 22H2 Last edited by Mercury_22; 14th March 2012 at 16:09. |
15th March 2012, 11:57 | #56 | Link |
Software Developer
I'd be interested in adding support for this filter in Zoom Player once it's a bit mature. Please don't lock it to a specific EVR custom presenter, It would be much friendlier if the filter was self-contained and did the mixing itself as-needed rather than relying on a custom EVR presenter to do the mixing. Last edited by Blight; 15th March 2012 at 12:09. |
15th March 2012, 14:41 | #57 | Link |
It's not locked to a specific EVR custom presenter. In theory it can can made to work with any. But there are a few things you must do to make it work. It has to be thread safe with regards to direct 3d. The custom evr presenters in MPC-HC are not thread safe. But it's not much work to make them so.
15th March 2012, 21:16 | #59 | Link |
http://dslibbluray.svn.sourceforge.n...bbluray/trunk/
Give cb2000 a message, I'm sure he add you to the project |
