Old 16th December 2009, 00:23   #41  |  Link
Brazil2
update microx264 added support for configuration file
create a file named microx264.ini in the same folder as microx264.exe
Great idea, that helps
There is a little annoyance though: I have added ColorMatrix to the filters and I have added a line to the INI like this:
Before Resize=ColorMatrix(mode="Rec.709->Rec.601")
But when I run the program a part of this line has been cut off and it appears like this in the Before Resize box:
ColorMatrix(mode
Notice that typing the full line in the box is working fine and it's correctly sent to the AVS file. So it's just the program that stops reading the line at the = sign.
Brazil2 is offline   Reply With Quote
Old 16th December 2009, 08:09   #42  |  Link
buzzqw
HDConvertToX author
thanks, fixed
now use the # as separator
so the microx264.ini can be like this
Encoding Mode=2 pass
Preset=ultrafast
Tuning=Film
Bitrate=1500
Audio Codec=Aac
Audio Quality=50
Normalize=1
Custom x264=--subme 3
MT Mode=1
MT Value=2,0
Resizer=PointResize
Before Resize#ColorMatrix(mode="Rec.709->Rec.601")
After Resize#
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 17th December 2009, 12:32   #43  |  Link
Brazil2
fixed
Nice, thanks, it's now working fine
Little feature request: a box for setting up the audio delay (ms, negative values allowed).
Old 17th December 2009, 13:40   #44  |  Link
buzzqw
HDConvertToX author
sorry pal.. why this request ?
decoding is done via DSS..
BHH
Old 17th December 2009, 15:59   #45  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
Open D2V, crop doesn't do anything. Preview shows this output from avisynth: The script return value is not a video clip. When I removed the last two lines from preview.avs I can play it in MPC.
last = isRGB(last) ? ConvertToYV12(last) : last <= remove
last = isYUY2(last) ? ConvertToYV12(last) : last <= remove
autocrop.avs: There is no function named autocrop?
my subtitle site
dwrbudr is offline   Reply With Quote
Old 17th December 2009, 16:23   #46  |  Link
buzzqw
HDConvertToX author
please put autocrop.dll in \filters folder
i missed it
will put it in next full package
BHH
Old 17th December 2009, 16:32   #47  |  Link
Brazil2
why this request ?
Not for MPEG2.
FFMS2 is used for the video (VOB and DVB captures) and DSS for the audio which leads to huge A/V sync problems.
Or is there a way to force the use of DSS ? Because with FFMS2 and interlaced material bobbed with Yadif mode=1 the video is playing at like half speed. With Yadif mode=0 I'm getting the right speed but it's out of sync with the audio by several seconds.
Old 17th December 2009, 17:11   #48  |  Link
buzzqw
HDConvertToX author
understand
please update microx264.exe
and add in microx264.ini this line
Force DSS=1
BHH
Old 17th December 2009, 19:46   #49  |  Link
Brazil2
Force DSS=1
I did that and now I'm getting this error:
Avisynth error:
I don't know what "movie" means
(F:\HAM\MicroX264.avs, line 13)
"movie" is not defined in the AVS file, the line is missing, but audio is there though.
Old 18th December 2009, 07:59   #50  |  Link
buzzqw
HDConvertToX author
thanks, fixed.
BHH
Old 18th December 2009, 20:06   #51  |  Link
Brazil2
DSS is now working fine
However I still have a problem with MPEG2 interlaced sources when using Yadif in mode=1. The resulting files are playing at half speed even though they are at 50 FPS as expected. They also show a duration which is the double of the source file one.
Encoding of MicroX264.avs from the temporary folder directly with x264 is making correct files.
x264 -o test.mp4 MicroX264.avs
Muxing of MicroX264.h264 from the temporary folder to MP4 or MKV is also making correct files. So there is something wrong after the encoding and before the muxing.
Old 18th December 2009, 20:15   #52  |  Link
buzzqw
HDConvertToX author
well.. post the queue...
BHH
Old 18th December 2009, 20:51   #53  |  Link
Brazil2
queue.bat :
"F:\Test\MicroX264\application\avs2yuv.exe" "F:\HAM\MicroX264.avs" - | "F:\Test\MicroX264\application\x264.exe" - --stdin y4m --crf 22 --threads auto --thread-input --preset slower --tune film  --subme 10 --merange 32 --weightp 1  --output "F:\HAM\MicroX264.h264"
"F:\Test\MicroX264\application\wavi.exe" "F:\HAM\MicroX264.avs" - | "F:\Test\MicroX264\application\neroaacenc.exe" -if - -q 0.50 -ignorelength -of "F:\HAM\MicroX264.mp4"
"F:\Test\MicroX264\application\mp4box.exe" -add "F:\HAM\MicroX264.h264" -fps 25.000  -add "F:\HAM\MicroX264.mp4" "F:\HAM_MX.mp4"
So the culprit is the FPS passed to the muxer at the end: -fps 25.000
And using a more detailled view in MediaInfo has shown me this from the final file:
Frame rate mode                  : Constant
Frame rate                       : 25.000 fps
Original frame rate              : 50.000 fps
But in the DOS window during encoding FPS are correct:
F:\HAM\MicroX264.avs: 704x400, 50 fps, 864 frames
yuv4mpeg: 704x400@50/1fps, 0:0
Old 28th December 2009, 15:49   #54  |  Link
buzzqw
HDConvertToX author
update microx264
added support for HDConvertToX_profile.txt
just put it in the same folder as microx264.exe
BHH
Old 13th January 2010, 08:48   #55  |  Link
buzzqw
HDConvertToX author
@Brazil2
fixed
please try the new package.
now if microx264 find yadif and mode=1 in "Before Resize" will double the fps for muxing
@All
new full package with X264.exe supporting LAVF
changelog
lots of hints
added support for DGI input
if using avs2yuv and in Bitrate is present a M (like 700M), MicroX264 will automatically compute the bitrate to achive 700 mb final size
BHH
Old 13th January 2010, 10:02   #56  |  Link
kosmonaut
kosmonaut's Avatar
The download link in the first post of the thread is incorrect, it should be: http://www.64k.it/andres/data/microx...0.1.19.284.rar
kosmonaut is offline   Reply With Quote
Old 13th January 2010, 10:20   #57  |  Link
buzzqw
HDConvertToX author
Thanks kosmonaut
link fixed
BHH
Old 14th January 2010, 15:55   #58  |  Link
Brazil2
@Brazil2
fixed
Yep it's working as expected now, thanks
Old 14th January 2010, 19:17   #59  |  Link
ronnylov
"64bit ready" - Does this mean I can replace the x264.exe file with a 64-bit version when I am using 64-bit Windows 7?
Or are all the supplied exe-files already 64-bit versions?
Ronny
ronnylov is offline   Reply With Quote
Old 14th January 2010, 20:28   #60  |  Link
buzzqw
HDConvertToX author
you can replace x264.exe with x264.exe at 64bit
BHH
