24th October 2015, 13:53 | #3701 | Link |
Suptitle, MediaPlayer.NET
Well delayed frames occur when your GPU had failed to present the frame in the vsync MPDN wanted. This can be due to various reasons external to MPDN. But if it's just delayed by one frame on a 75hz display, chances are you won't even notice it.
24th October 2015, 16:56 | #3702 | Link |
Interesting player with some useful potential. Small footprint is a bonus.
I'm having unexpected results with interlaced content though - with identical LAV filter settings, using either DXVA or CUVID, it's not properly deinterlacing. Even with 50/60p enabled and attempting to force either just hardware or just Yadif software, and aggressively deinterlacing, everything is being blend deinterlaced. The same video files, with MPC-HC and LAV configured identically, play perfectly. I'm happy to communicate privately and send some example video files so you can attempt to replicate the issue if you wish, PM me through the board. |
24th October 2015, 21:15 | #3703 | Link |
Yes, I tried the last release with the old extension, and when the media file changes it comes up with the crash dialogue that says MPDN - Media Player .NET has stopped working.
I might try a really ancient version and associated extension and see if something has changed over the versions. |
24th October 2015, 22:43 | #3704 | Link |
I found where the issue is introduced, it's the extensions version v1.22.0. I tried numerous MPDN's and extensions, and they all worked fine (they would not crash). I then went back to MPDN v2.44.3.3480 and tried the numerous supported extensions. The v1.21.x series works fine (including v1.21.4), I went previous/next about 60 times trying to get it to crash, perfectly stable! I then tried extension version v1.22.0 (also supported under the same MPDN), and it crashed just like the latest versions, without fail. I then tried extension version v1.21.4 again, and no issues!
So, the issue was definitely introduced in v1.22.0. I hope that makes it easier to track down what could be causing it! |
25th October 2015, 14:27 | #3715 | Link |
I sometimes get visual corruption when loading the next file (pink or green lines throughout the image) briefly when preloading is active.'
I haven't been able to reliably reproduce the next file load crashing so far. |
25th October 2015, 23:37 | #3717 | Link |
In recent days I twiddled parameters around SuperRes, since I am not satisfied with the 'artificial' kind effect NNEDI3 produced.
Now I am quite satisfied with Super-xBR as image doubler with Edge Strength 1.00 and Sharpness 0.35, and without 'third pass', the SuperRes configured with the default parameters. Though not perfect, but it gives me natural and vivid images watching a movie from a fare distance. Tried with other image doublers, some, e.g. the NNEDI3 may better closed look, yet the overall visual pleasure it brings is not as good as with the settings I mentioned. |
25th October 2015, 23:45 | #3719 | Link |
I was using the latest LAVFilters 0.66.0-31 which works perfectly with all other media players, and even all versions of MPDN with the extensions prior to v1.22.0. However, I just tried a fresh install of MPDN (clean install option) and extensions (same, clean install), installing the version of LAV Filters that came with MPDN. Same result, crash on changing media files.
Something between the extensions in v1.21.4 and v1.22.0 is causing the crash. Was the compile environment exactly the same for v1.21.4 and v1.22.0? Since it is such a specific fault (only with extensions v1.22.0 and later) and for me doesn't affect anything else, I still suspect the issue lies with one of the commits. It could either be the commit itself, or something in the commit that causes something in MPDN to go awry? Is it possible for you to compile a few different test MPDN extensions omitting some of the different commits between v1.21.4 and v1.22.0 to see which commit is causing the issue? Thanks |
25th October 2015, 23:47 | #3720 | Link | |
direct3d, mpdn, nnedi3, opencl, reclock |
