Old 24th January 2018, 08:14   #101  |  Link
kuchikirukia
Unfiltered: 30MB
smdegrain(thsad=200,lsb=true,lsb_in=false,lsb_out=true) = 21MB
smdegrain(thsad=200,lsb=true,lsb_in=false,lsb_out=true, plane=0) = 28MB
smdegrain(thsad=200,lsb=true,lsb_in=false,lsb_out=true, plane=3) = 81MB
smdegrain(thsad=200,lsb=true,lsb_in=false,lsb_out=true, plane=1) = 83MB
Umm....
eh, 3.1.2d does it too.
kuchikirukia is offline   Reply With Quote
Old 25th January 2018, 14:34   #102  |  Link
real.finder
Originally Posted by kuchikirukia View Post
Unfiltered: 30MB
Umm....
it's something in mvtools or the way of how the encoder work
See My Avisynth Stuff
Old 11th February 2018, 16:37   #103  |  Link
real.finder
days ago I did update stab3, now it's should be more stable with mirror=15
Old 16th February 2018, 13:36   #104  |  Link
tormento
Acid fr0g
tormento's Avatar
SMDegrain 16 bit
I want to ask you a curiosity: is SMDegrain written to work with the 16 bit depth capabilities of MaskTool, MVTool and KNLMeansCL or does it use some kind of workaround?
AFAIK they are the only filters I use with the following:
PHP Code:
SMDegrain (tr=4,PreFilter=4,thSAD=600,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=0
If not, would be a "pure" 16 bit version faster and/or more precise than the workaround method, if any?
@turment on Telegram
Old 16th February 2018, 15:09   #105  |  Link
real.finder
PHP Code:
in avs+ native 16 bit? it not use workaround, but the lsb in your code is not, it should show you some error message that lsb it not work with native HBD
edit: it will not be faster in native 16 unless you did this workaround
#8bit source
c=last
SMDegrain(globals=3,tr=4,PreFilter=4)
global fv1 = fv1.MScalevect(bits=16)
global fv2 = fv2.MScalevect(bits=16)
global fv3 = fv3.MScalevect(bits=16)
global fv4 = fv4.MScalevect(bits=16)
global bv1 = bv1.MScalevect(bits=16)
global bv2 = bv2.MScalevect(bits=16)
global bv3 = bv3.MScalevect(bits=16)
global bv4 = bv4.MScalevect(bits=16)
c
ConvertBits(16)
SMDegrain(globals=1,tr=4,thSAD=600,contrasharp=false,refinemotion=false,truemotion=true,plane=4)
ConvertBits(8,dither=1)
Old 18th February 2018, 09:14   #106  |  Link
tormento
Acid fr0g
tormento's Avatar
Thanks for your clear reply.
To clarify my question: will be possible one day to have a SMDegrain (bitdepthworkingspace=8/10/16,outputbitdepth=8/10/16) without the need of LSB? Would like also to try if a pure 16 bit processing would be more precise than a "fake" one.
Old 18th February 2018, 16:31   #107  |  Link
real.finder
it's already do that but there are some filters that not work with native HBD yet (in your case it support native 10-16 bit now but you should remove the "lsb=true" or make it false), but that is way slower than the lsb method, even with the code I post above, see here https://forum.doom9.org/showthread.p...87#post1833887
Old 10th March 2018, 12:21   #108  |  Link
tormento
Acid fr0g
tormento's Avatar
@real.finder
Could you please tell me which is the difference between
PHP Code:
pre=KNLMeansCL (d=0a=3h=7.0)
SMDegrain (tr=6thSAD=400refinemotion=falselsb=truemode=0contrasharp=falsePreFilter=pretruemotion=falseplane=4chroma=true
and
PHP Code:
pre=SMDegrain_KNLMeansCL (d=0a=3h=7.0)
They are giving me different results.
Old 10th March 2018, 13:40   #109  |  Link
real.finder
@real.finder
PHP Code:
and
PHP Code:
of course they are different, since SMDegrain_KNLMeansCL process chroma with luma by special way
Old 10th March 2018, 13:44   #110  |  Link
tormento
Acid fr0g
tormento's Avatar
Please define "special".
Old 10th March 2018, 13:51   #111  |  Link
real.finder
back then and still KNLMeansCL can't process chroma with luma in subsampling Chroma (new KNLMeansCL can do process chroma alone) so dogway use stacking method, you can see the code yourself, or back to dogway posts in videohelp forum
Old 10th March 2018, 15:58   #112  |  Link
magiblot
Eurobeat Fan
Hi real.finder,
Is there any way to run srestore in AVS+ x64? At first sight, it won't run because there doesn't seem to be a x64 version of GScript. Since I have read AVS+ supports GScript's functionality natively, I tried to replace the call to GScriptClip in srestore.avsi with ScriptClip, but a "I don't know what 'dm' means" error is the farthest I got.
magiblot is offline   Reply With Quote
Old 10th March 2018, 17:55   #113  |  Link
GScriptClip is from Grunt plugin, not GScript.
Old 10th March 2018, 20:55   #114  |  Link
magiblot
Eurobeat Fan
Wow, what a miss.
Thanks, Stainless .
Old 10th March 2018, 20:59   #115  |  Link
real.finder
Originally Posted by magiblot View Post
Hi real.finder,
as StainlessS said, it's Grunt
and I think the error related to something else (not Grunt)
you use mt "Prefetch()"? cuz it will not work, runtime things (srestore use it) not compatible with mt yet
Old 11th March 2018, 09:00   #116  |  Link
tormento
Acid fr0g
tormento's Avatar
Looked.
What does this line
!lsb && lsb_in ? Ditherpost(mode=6,slice=false) : last
means?
As I am using SMDegrain_KNLMeansCL as a prefilter (just to have more control over prefilter parameters), is it useful to dither when SMDegrain already dither again at some point?
Wanting to use KNLMeansCL as a plain prefilter, would it be sufficient to use:
pre =KNLMeansCL (d=0, a=3, h=7.0, channels="Y")
pre2=KNLMeansCL (d=0, a=3, h=7.0, channels="UV")
SMDegrain (tr=6, thSAD=400, refinemotion=false, lsb=true, mode=0, contrasharp=false, PreFilter=pre2, truemotion=false, plane=4, chroma=true)
or the very complex prefilter script is necessary?
Old 11th March 2018, 12:15   #117  |  Link
real.finder
remember that I told you that mvtools don't has lsb_in anywhere, it's just has lsb parameter in mdegrainX, so you must dither any stacked input clip
yes, you can use
or anything give you what you want
but I think you need to added "pre." before KNLMeansCL in pre2, so it should be
pre2=pre.KNLMeansCL (d=0, a=3, h=7.0, channels="UV")
Old 11th March 2018, 12:22   #118  |  Link
tormento
Acid fr0g
tormento's Avatar
We need some Pinterf modding here
Old 11th March 2018, 12:25   #119  |  Link
real.finder
why? lsb is hack, he already did support native avs+ HBD, and he will add out16 as replacement for lsb method, see last posts in his mvtools Thread
Old 11th March 2018, 13:42   #120  |  Link
tormento
Acid fr0g
tormento's Avatar
I saw and I know. Look at smiley.
avisynth, avs script, avs+, banding, generator, hbd, mod
