Old 17th May 2018, 13:50   #50881  |  Link
madjock
Originally Posted by Clown shoes View Post
Thanks MadJock but that doesn't really answer my question
It sort of does in a way as the only time it mentions LUTs taken into account is when an option with LUTs in the option is selected ?
Old 17th May 2018, 13:56   #50882  |  Link
foozoor
foozoor's Avatar
@madjock
Mpv doesn't need external codecs.
Nvidia GPUs are used in most of top level Linux supercomputers and are optimized.
I use Kodi on a sweet $30 amlogic S905 box and 4K@60hz, HDR and DTS-HD are not a problem.
We are not in 2009 anymore.
foozoor is offline   Reply With Quote
Old 17th May 2018, 14:02   #50883  |  Link
madjock
@foozoor
Haha, tell that to Linux when you have to use an app to manually mount NTFS drives
Don't get me wrong I liked XFCE for speed, and liked messing with Arch etc, but when it all boils down to it, its a lot of work for simple task sometimes.
Using KODI with Nvidia and MadVR, or using lesser variants on everything on Linix, I think Windows 10 has come a long way for ease of use and lets face it Linux has had years to get to a place for a novice, but is just stagnating now.
Old 17th May 2018, 14:02   #50884  |  Link
noee
Originally Posted by foozoor View Post
@noee
No problem here with archlinux and mpv with the default opengl renderer and direct rendering (enabled by default now).
But linux is more advanced than windows for multimedia.
Yeah, well, all my machines except for one are running OpenSUSE Tumbleweed and while TW is *good* out of the box for multimedia on AMD (JRiver and MPV), madVR on Windows is *exceptional*. It's the only reason (besides a couple of games and for testing) that I keep a windows machine around.
Seriously, dude? This isn't 2009.
Win7Ult || RX560/4G || Ryzen 5
noee is offline   Reply With Quote
Old 17th May 2018, 14:17   #50885  |  Link
madjock
Haha as I said I did enjoy messing with Linux, if I have TBs of media, I sure as heck was not converting them to another format after buying more TBs of hard drives to move them to before converting .
But just the AVR not showing DTS-HD and the likes without switches is signs of 2009, not the future.
Old 17th May 2018, 14:26   #50886  |  Link
foozoor
foozoor's Avatar
Just use Linux with mpv for better HDR support, yes the d3d11 renderer needs some little fixes. RAVU and recent FSRCNNX shaders are just like NGU-AA/NGU-Sharp, FSRCNNX is sometimes sharper and RAVU is sometimes softer but they are majorally the same. You can tweak smooth motion (interpolation) settings...
Except the new and not released yet (not scaling related) algorithm, madVR is not that exceptional.
@madshi
Any more news about the new algorithm?
Old 17th May 2018, 14:46   #50887  |  Link
Clown shoes
King of the Jungle
Clown shoes's Avatar
Not really. It doesn't mention whether or not an existing LUT will be ignored when Pixel shader math HDR processing is active and the REC709 LUT still shows up in the MadVR OSD
I presume it isn't active but I would like confirmation as I need to find a work around for my HDR LUT red highlight issue.
Clown shoes is offline   Reply With Quote
Old 17th May 2018, 15:42   #50888  |  Link
nevcairiel
Just don't respond to foozoor, he is a known troll.
Old 17th May 2018, 15:50   #50889  |  Link
foozoor
foozoor's Avatar
I am here to dynamize this almost dead thread.
But I confess I have a strange way of spreading my love for madvr.
Old 17th May 2018, 15:52   #50890  |  Link
madjock
@nevcairiel
Noted.
Old 17th May 2018, 15:54   #50891  |  Link
press control+alt+shift+3 or control+shift+3
huhn is online now   Reply With Quote
Old 17th May 2018, 16:22   #50892  |  Link
Clown shoes
King of the Jungle
Thanks Huhn, that's a handy shortcut and it did help confirm there is no active LUT whilst pixel shader math is processing HDR content.
Old 17th May 2018, 16:28   #50893  |  Link
Clown shoes
King of the Jungle
For anyone curious, here is an example of the strange issue I am having when applying a HDR 3DLUT in MadVR
PASSTHROUGH
https://picload.org/image/doooodia/hdrpassthrough.png
PIXEL SHADER
https://picload.org/image/doooodii/1...shadermath.png
3D LUT
https://picload.org/image/doooodil/1000nitpl3dlut.png
Old 17th May 2018, 17:16   #50894  |  Link
tobindac
I have a relatively severe issue with exclusive mode on current windows 10, on an AMD GPU (R9 290). It does play normally eventually but for the first 3 to 6 seconds it stays frozen without showing motion.
Has this been addressed before?
tobindac is offline   Reply With Quote
Old 17th May 2018, 17:56   #50895  |  Link
you can try a clipping shader:
sampler s0 : register(s0);
float4 main(float2 tex : TEXCOORD0) : COLOR
  return clamp(tex2D(s0, tex),0.0, 1.0);
and please stick to links not everyone wants to see a wall of pictures.
Old 17th May 2018, 18:07   #50896  |  Link
Clown shoes
King of the Jungle
Woops! I forgot Doom9 doesn't scale images. let me go back and fix that.
regarding the clipping shader, how exactly does it work and where would I apply it?
Old 17th May 2018, 19:00   #50897  |  Link
as a shader in mpc-hc.
don't expect much.
Old 17th May 2018, 19:13   #50898  |  Link
Asmodian
That 3DLUT example looks exactly like mine did when the video went above what the 3DLUT was mapping. I had to turn up the peak nits setting for the content but I could never get it to work when using PC mode on my TV, with its poor gamut coverage, I always had a similar magenta out of gamut/clipping issue.
madVR options explained
Old 17th May 2018, 19:17   #50899  |  Link
Clown shoes
King of the Jungle
Yes that's exactly the problem. I can increase the peak luminance to around 2500 nits and that will prevent the issue, but of course that brings down the entire luminance by a significant amount.
Did you ever find a workaround with your particular display?
Old 17th May 2018, 19:34   #50900  |  Link
does the shader work or atleast make it better?
