25th March 2011, 08:35 | #1061 | Link |
Looking forward to it! I think those 70fps must be limited by the actual decoding performance, not by the GPU -> System RAM copy.
What I found clever is the way NVidia handles the NV12 surfaces: Those allocated for DXVA decoding are optimized for reading. That makes sense because applications will never write to those surfaces, if they access them at all, they will read from them. But NV12 surfaces not allocated for DXVA are optimized for writing instead. Again that makes a lot of sense. Only NVidia has optimized things this way. ATI and Intel have not. |
25th March 2011, 09:15 | #1062 | Link | |
I learned that the hardware decoder runs the same speed on all cards of the same generation, and is not influenced by the actual clock of the GPU, that makes benchmarking it alot easier, and the values more meaningful. I'm not sure if the deinterlacing is done in the fixed function hardware or handed over to the shaders, though. In any case, hardware deinterlaced cheese slice test on madVR = awesome. Its mostly done, as well. I only need to work out some kinks with video renderers that request a certain stride, somehow my handling of this is rather wonky right now =)
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 25th March 2011 at 09:25. |
25th March 2011, 09:26 | #1063 | Link | |
25th March 2011, 09:27 | #1064 | Link |
There is a flag you can set, its values are "weave", "bob" or "adaptive", and then CUVID deinterlaces for you. Nothing you really have to do. Thats why i love CUVID.
25th March 2011, 09:29 | #1065 | Link |
Cool. I'm still wondering how IVTC works, though. Do you really get 24fps out of a 60i stream? Who controls the output framerate? Is that your job or does the deinterlacing hardware do that? I think it's your job? So you'd have to offer a switch video (60p/50p output) vs. film (24p/25p output) mode for optimal results?
25th March 2011, 09:41 | #1066 | Link |
I'm quite sure the decoder just outputs 24 frames per second when IVTC'ing NTSC 30fps content (i don't think i have 60i content, i'll check), but i'll run some more tests on that.
The question is if it tells me that its reducing it to 24fps, so i can set the frame rate in the media type appropriately, as i'm not sure if renderers rely on that value, because from where i stand, the frame rate is simply determined by the distance between two frames, not the frame rate in the media type.
25th March 2011, 10:11 | #1067 | Link |
Well, madVR doesn't really care right now what the media type says. However, automatic refresh rate changing might depend on that value being set correctly, so it would be quite useful having it set correctly. If you find out how the decoder behaves exactly with IVTC, I'd love to know. (NTSC 30fps = 60i, it's one and the same)
25th March 2011, 10:28 | #1068 | Link |
@nevcairiel:
Do you plan to support subtitles rendering too (something like FFDshow DxVA decoder do)?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
25th March 2011, 10:30 | #1069 | Link |
Why?
You can use ffdshow in raw mode, or MPC-HCs internal renderer, there are no limitations.
25th March 2011, 10:35 | #1070 | Link | |
FFDshow RAW is a solution, but not very "clean".
25th March 2011, 10:38 | #1071 | Link |
Subtitle rendering is annoying, and i probably won't touch it. I use a player that can render them properly scaled on the final image, i don't need to render them on the image before scaling, like ffdshow does.
For people that don't use such players, there are several solutions, ffdshow raw and DirectVobSub should work in most if not all players.
25th March 2011, 10:49 | #1072 | Link |
Agreed, spending time to render subtitles on the decoded image pre-scaling simply makes no sense. Subtitle rendering must be done after scaling for proper quality. Which means that subtitle rendering can not be done in the video decoder.
25th March 2011, 11:14 | #1073 | Link |
Yes, i understand that.
This is the reason why i use FFDshow video decoder => resize => subtitles rendering => video renderer for SD and FFDshow DxVA => subtitles overlay => video renderer for HD. Possibly i can use LAVF video decoder => FFDshow RAW (resize + subtitles rendering) => video renderer, but i am afraid some players won't add FFDshow RAW between LAVF video decoder and renderer. Looks like i will need to stay using FFDshow after all.
25th March 2011, 11:20 | #1074 | Link |
My video decoder will for the time being only be for NVIDIA, going by your signature, you don't fit that profile.
A general purpose software and DXVA video decoder is in the planning/alpha stage, but don't hold your breath, it might not happen at all, or take a year.
25th March 2011, 11:23 | #1075 | Link | |
25th March 2011, 13:28 | #1077 | Link |
It just supports vorbis when using LAV Splitter as well, with other splitters it will most likely not work due to not supporting the vorbis-specific media format descriptor.
25th March 2011, 13:53 | #1078 | Link |
Right, I know. On my bedroom machine and laptop I can't use madVR. They just aren't powerful enough to do software decoding. CoreAVC allows me to do CUDA decoding on the bedroom machine, but, I don't have a solution for VC-1 decoding. So I'm stuck with DXVA on that machine. My main HTPC is a quad core monster and has plenty of power for decoding. Using that with the Cyberlink decoder gives me the best results. And yes, my bedroom machine has an nVidia 450. Am I going to be happy?
25th March 2011, 13:54 | #1079 | Link | |
25th March 2011, 14:45 | #1080 | Link |
Wow, a nice surprise.
Will it handle incompatible videos properly by falling back to whatever software decoder is installed? Maybe there are CoreAVC users here that have some samples for you that don't work with CUDA.
MPC-HC 2.2.1 |
