Old 13th September 2008, 19:49   #61  |  Link
Originally Posted by crypto View Post
OK, I got it running.
What did you have to do to solve the issue?
Guest is offline
Old 13th September 2008, 19:50   #62  |  Link
Originally Posted by bob0r View Post
Where do i read the FPS?
The FPS box at the bottom is empty here.
(8800 gts g92)
In the usual place in the Info dialog. What happens when you have display enabled? Does it play and display? Maybe you have single step set for playback.
Guest is offline
Old 13th September 2008, 19:51   #63  |  Link
CPU is at 0 (That's zero)
Sorry, I'll try to optimize it.
Guest is offline
Old 13th September 2008, 19:52   #64  |  Link
bob0r
Pain and suffering
bob0r's Avatar
I used it out of the zip straight away.
Disable Display indeed reports FPS now, running on a bluray disc.
bob0r is offline
Old 13th September 2008, 19:54   #65  |  Link
Originally Posted by Sagekilla View Post
I found what might be a bug -- If I exit DGAVCNV while previewing a movie (disable display is checked) I simply get an error message from windows telling me the program has stopped working. No other debug info.
Can't duplicate it.
On another note, I've also noticed the issue with half the CPU usage being towards kernel usage. Take a look here: http://img.photobucket.com/albums/v6.../kernusage.png
Is one color kernel and the other app? How would I know that? Why does my display show only one trace?
Bear with me, I'm a noob.
Guest is offline
Old 13th September 2008, 19:56   #66  |  Link
It should be there for play, too, but you have to wait a few seconds for stats to accumulate.
Guest is offline
Old 13th September 2008, 19:56   #67  |  Link
crypto
@DVBPortal
crypto's Avatar
@neuron2
It seems those having trouble are on Vista. It could be, there are different DLLs for XP and Vista. Did you ship those for XP?
BTW. Fantastic Job. Playback is flawless even for PAFF streams. I am really impressed.
crypto is offline
Old 13th September 2008, 19:58   #68  |  Link
Thanks for the kind words, and to all for your test results. Doom9 people are the best!
I don't know about the Vista issue. Have you looked at the Nvidia CUDA Zone site?
OK, I'm going to be gone for a while. Guess what I am working on.
Guest is offline
Old 13th September 2008, 19:58   #69  |  Link
bob0r
Pain and suffering
bob0r's Avatar
FPS varies around 44-48fps with 42 low and 54 peak.
Last edited by bob0r; 13th September 2008 at 20:03. Reason: nevermind the rest, something is up
bob0r is offline
Old 13th September 2008, 20:00   #70  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Yeah! You are the best example, man!
Atak_Snajpera is offline
Old 13th September 2008, 20:02   #71  |  Link
crypto
@DVBPortal
crypto's Avatar
I removed the following DLLs from your package:
nvcuvid.dll
nvapi.dl
nvcuda.dll
and used these from the badaboom package:
nvcuvid.dll
nvdec.dll
nvapi and nvcuda where in my system32 directory. I have not installed the SDK (yet).
crypto is offline
Old 13th September 2008, 20:03   #72  |  Link
Hmm is it normal when DGAVCIndexNV is running the preview, i can't play any 1080p x264 .mkv smooth anymore?
Shouldn't that be CPU only with coreavc?
I have to tell you that DGAVCIndexNV (and DGIndex, and DGAVCIndex) all have horribly inefficient YV12->RGB24 conversion for display. I'll be working on it but it is not important because when serving you don't have any display. What happens when you try it with the display disabled?
Guest is offline
Old 13th September 2008, 20:03   #73  |  Link
BetaBoy
CoreCodec Founder
BetaBoy's Avatar
Congrats neuron2!
Dan "BetaBoy" Marlin
Ubiquitous Multimedia Technologies and Developer Tools
http://corecodec.com
BetaBoy is offline
Old 13th September 2008, 20:05   #74  |  Link
We're both forgetting rule 12, oops.
Guest is offline
Old 13th September 2008, 20:17   #75  |  Link
juGGaKNot
juGGaKNot's Avatar
BTW, guys. You can have a secondary Nvidia card next to your ATI and still use it for decoding.
Does it matter what card ? a 8500GT is as good as a GTX260 ?
juGGaKNot is offline
Old 13th September 2008, 20:21   #76  |  Link
Here is my new generic decoder API:
extern int decoder_open(void (*Alloc)(int, int),
			void (*FrameComplete)(void),
			void (*Error)(char *, int),
			int (*Info)(const char* fmt, ...),
			unsigned char **frame_store);
extern int decoder_close(void);
extern int decoder_flush(void);
extern int decoder_reset(void);
extern int decoder_decode_nalu(unsigned char *buf, int len);
extern int decoder_set_mode(int);
The decoder_open() call passes a pointer to the YV12 store for the decoded picture and pointers to callbacks as follows:
Alloc: called when a video sequence is seen to allow the app to allocate memory, also provides the frame size
FrameComplete: called when the app should receive a picture for display/serving
Error: called for a fatal error
Info: called for an info popup
The decoder_set_mode() call puts the decoder into a stepping or playing mode.
Guest is offline
Old 13th September 2008, 20:22   #77  |  Link
It's been discussed. Almost, yes, except for memory bandwidth.
Guest is offline
Old 13th September 2008, 20:27   #78  |  Link
juGGaKNot
juGGaKNot's Avatar
Wake up! This is only for decoding.
Yeah, I'm going to sleep now :|.
Old 13th September 2008, 20:36   #79  |  Link
Atak_Snajpera
Looks like perfection, no more quad core's for encoders just a low price nVidia card next to your ATI
Old 13th September 2008, 21:06   #80  |  Link
Sagekilla
x264aholic
@neuron2: Sorry, I was making assumptions that people knew what the graphs meant usually! Green is total CPU usage, and red presents the portion that the kernel is using. In this case it looks like nearly half of the cpu usage is from the kernel alone. DGAVCNV only used maybe 12 - 13% cpu but the total CPU usage was closer to 25%.
By the way, is this more or less optimized?
Edit: I'll try to reproduce my error again. I want to see if it happens twice -- I only saw it once when I decided to exit while I was still previewing.
Edit 2: Odd, the error seems to have been a one shot deal. I haven't had it again.
Sagekilla is offline
