Old 4th September 2009, 18:19   #1181  |  Link
Thunderbolt8
Originally Posted by LeMoi View Post
You have 'mul' = multiple languages, doesn' fit ?
never saw that one before, thanks.
Thunderbolt8 is offline
Old 4th September 2009, 19:55   #1182  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Originally Posted by froggy1 View Post
Maybe a somewhat stupid question but I was wondering a bit here. I know that one can set movie titles (with --title) and track names (with --track-name) but there's no --genre option present. I know I can use an XML tag file (and I just added that to h264enc) to set the genre and much more, but I was wondering if a --genre option could be added for when I don't want to create an XML just for that. It'll be also nice for audio files in MKA's
No, sorry. I will not add any option for directly modifying tags. One of the reasons is that such an option would either be very simple and therefore completly situational (which usually leads to a lot more requests like "but I want it to do xyz" and "but I also need abc") or it's powerful and very complicated to use (which in turn leads to the users requesting a simple GUI component in mmg for it which then is supposed to turn into a full-blown tag editor).
Latest MKVToolNix is v83.0
Mosu is offline
Old 4th September 2009, 19:59   #1183  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
Fair enough. It's just strange that there's --title and --track-name options but --genre is completely missing (which is pretty important for audio files). I'll use the XML then
microchip8 is offline
Old 4th September 2009, 20:13   #1184  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
That's because the title and track name elements are actual header elements and not stored in tags.
Mosu is offline
Old 4th September 2009, 20:21   #1185  |  Link
microchip8
microchip8's Avatar
I see. Can't genre be a header element too or does this violate something?
Old 4th September 2009, 20:24   #1186  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
The Matroska specs don't contain such an element in the track headers, and I cannot simply add one. Back when we created the specs we consciously decided against creating a multitude of tag-like header elements because all we'd accomplish is either creating a huge list of elements that almost no one ever used or we'd end up with a list that would notoriously lack one or the other. Therefore we settled for the most important elements, a title/track name, languages. The rest is supposed to be stored in tags.
Mosu is offline
Old 4th September 2009, 20:32   #1187  |  Link
microchip8
microchip8's Avatar
Makes sense. Thanks for clarification. Indeed XML is pretty powerful on itself and very flexible so I can see why such decision was made. Thanks again
Old 7th September 2009, 17:46   #1188  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Originally Posted by Vincent Vega View Post
i have an avi with 1 xvid, 2 ac3 and 2 srt tracks. no matter whether i check both srt tracks or just one of them or uncheck both mmg still muxes both subtitle tracks into the .mkv. tried versions 2.9.7 and 2.9.8
The following build fixes this issue:
http://www.bunkus.org/videotools/mkv...-171-setup.exe
Mosu is offline
Old 28th September 2009, 06:20   #1189  |  Link
Vincent Vega
thank you Mosu for the new build, sorry didnt have a chance to see and try it earlier. worked fine for me this time srt-wise.
there's one other glitch i noticed: original file was xvid+5.1ac3+5.1ac3+srt.avi -> xvid+5.1ac3.mkv. mkvinfo and matroska shell extension show audio in the mkv not as 5.1 but as 5 channels. though ac3filter still plays it fine as 5.1
Vincent Vega is offline
Old 28th September 2009, 07:23   #1190  |  Link
juGGaKNot
juGGaKNot's Avatar
Rename the thread.
Originally Posted by Dark Shikari View Post
If they can beat x264 in visual quality on ordinary test clips without postprocessing, I'll eat my hat.
juGGaKNot is offline
Old 5th October 2009, 12:02   #1191  |  Link
Warpman
Originally Posted by juGGaKNot View Post
Rename the thread.
http://forum.doom9.org/showpost.php?...postcount=1171
Warpman is offline
Old 5th October 2009, 20:31   #1192  |  Link
Palikrovol
Palikrovol's Avatar
Hello Mosu.
Little problem:
I have a mkv with some attachments (images). When remuxing it with mmg (version 2.9.8 or 2.9.8 build 171) the output mkv doesn't have the files.
In the "Attachments" tab the files are checked before muxing.
To check if the mkv has the files i use the matroska shell extension or open it with mmg and take a look at the "Attachments" tab.
The image files are 'jpg' between 50 kB and 400 kB.
The input MKVs that i've tried had between 1 and 24 image files.
Any idea?
Thanks
Palikrovol is offline
Old 5th October 2009, 20:47   #1193  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Works fine for me (I've just re-tested it).
1. Make sure your mmg is using the correct mkvmerge.exe executable and that you don't have an older version lying around somewhere.
2. What does "mkvmerge --identify-for-mmg the-remuxed-file.mkv" say?
3. What does "mkvmerge -o remuxed-test.mkv original-source-file.mkv" followed by "mkvmerge --identify-for-mmg remuxed-test.mkv" say?
Add paths to mkvmerge/the files where appropriate.
Mosu is offline
Old 5th October 2009, 23:07   #1194  |  Link
Palikrovol
Palikrovol's Avatar
Hi.
I have uninstalled and reinstalled version 2.9.8 build 1.7.1.
"D:\AdP\_Video_\Mkvtoolnix\"
The first test is the commad line used in mmg "Muxing -> Copy command line to clipboard"
mkvmerge is called from its original folder (no use of "path" env var).
Output: Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv
F:\>"D:\AdP\_Video_\Mkvtoolnix\mkvmerge.exe" -o "F:\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv"  "--track-name" "1:Quantum of Solace" "--default-track" "1:yes" "--forced-track" "1:no" "--display-dimensions" "1:720x304" "--language" "2:spa" "--track-name" "2:(AC3 5.1)" "--default-track" "2:yes" "--forced-track" "2:no" "--language" "3:eng" "--track-name" "3:(AC3 5.1)" "--default-track" "3:no" "--forced-track" "3:no" "--language" "4:spa" "--default-track" "4:no" "--forced-track" "4:no" "--language" "5:eng" "--default-track" "5:no" "--forced-track" "5:no" "-a" "2,3" "-d" "1" "-s" "4,5" "--attachments" "8389311906485108737,8389311906485108738,8389311906485108739,8389311906485108740" "-T" "--no-global-tags" "--no-chapters" "G:\\Peliculas\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv" "--track-order" "0:1,0:2,0:3,0:4,0:5" "--title" "Quantum of Solace"
mkvmerge v2.9.8 ('C'est le bon') built on Sep  6 2009 21:40:12
'G:\\Peliculas\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv': Using the Matroska demultiplexer.
'G:\\Peliculas\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv' track 1: Using the MPEG-4 part 2 video output module.
'G:\\Peliculas\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv' track 2: Using the AC3 output module.
'G:\\Peliculas\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv' track 3: Using the AC3 output module.
'G:\\Peliculas\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv' track 4: Using the text subtitle output module.
'G:\\Peliculas\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv' track 5: Using the text subtitle output module.
The file 'F:\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv' has been opened for writing.
Progress: 100%
The cue entries (the index) are being written...
Muxing took 31 seconds.
And the "--identify-for-mmg"
(The result is the same if mkv is muxed within mmg instead of command line)
F:\>"D:\AdP\_Video_\Mkvtoolnix\mkvmerge.exe" --identify-for-mmg "F:\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv"
File 'F:\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv': container: Matroska [title:Quantum\sof\sSolace duration:6374280000000]
Track ID 1: video (V_MS/VFW/FOURCC, XVID) [language:und track_name:Quantum\sof\sSolace display_dimensions:720x304 default_track:1 forced_track:0]
Track ID 2: audio (A_AC3) [language:spa track_name:(AC3\s5.1) default_track:1 forced_track:0]
Track ID 3: audio (A_AC3) [language:eng track_name:(AC3\s5.1) default_track:0 forced_track:0]
Track ID 4: subtitles (S_TEXT/UTF8) [language:spa default_track:0 forced_track:0]
Track ID 5: subtitles (S_TEXT/UTF8) [language:eng default_track:0 forced_track:0]
The Second test (your test)
Output: Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos)2.mkv
F:\>"D:\AdP\_Video_\Mkvtoolnix\mkvmerge.exe" -o "F:\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos)2.mkv"  "G:\\Peliculas\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv"
The file 'F:\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos)2.mkv' has been opened for writing.
Progress: 100%
F:\>"D:\AdP\_Video_\Mkvtoolnix\mkvmerge.exe" --identify-for-mmg "F:\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos)2.mkv"
File 'F:\\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos)2.mkv': container: Matroska [title:Quantum\sof\sSolace duration:6374280000000]
Attachment ID 1: type "image/jpeg", size 437901 bytes, description "Poster", file name "Quantum\sof\sSolace\sver1.jpg"
Attachment ID 2: type "image/jpeg", size 212939 bytes, description "Poster", file name "Quantum\sof\sSolace\sver2.jpg"
Attachment ID 3: type "image/jpeg", size 210077 bytes, description "Poster", file name "Quantum\sof\sSolace\sver3.jpg"
Attachment ID 4: type "image/jpeg", size 276761 bytes, description "Poster", file name "Quantum\sof\sSolace\sver4.jpg"
Old 6th October 2009, 08:17   #1195  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Thanks for the info. This is the problem but not the cause:
Originally Posted by Palikrovol View Post
F:\>"D:\AdP\_Video_\Mkvtoolnix\mkvmerge.exe" ... "--attachments" "8389311906485108737,8389311906485108738,8389311906485108739,8389311906485108740" ...
The attachement IDs are totally out of bounds. I'll try to see where this problem might come from.
Which Windows version is this, and is this a 32bit or 64bit version?
Mosu is offline
Old 6th October 2009, 08:26   #1196  |  Link
Palikrovol
Palikrovol's Avatar
The OS is a 32 bits Windows XP.
Thanks a lot.
PD: If you need any more info, let me know.
Old 6th October 2009, 09:44   #1197  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Please do another test for me. Run mmg, open its preferences dialog and enable "show debug window". Close the preferences dialog. Add the original file (the one with the attachments intact). Post the content of the debug window here or send it to me by email (the debug window contains a "save to file" menu option).
Mosu is offline
Old 6th October 2009, 10:46   #1198  |  Link
Palikrovol
Palikrovol's Avatar
I'm not at home right now (where i have the files). When a get there this night, i'll made the test.
Old 6th October 2009, 18:01   #1199  |  Link
Palikrovol
Palikrovol's Avatar
Here is the output from debug window.
BTW the size of the mkv is "1,49 GB (1.601.952.120 bytes)"
18:55:31: Querying mkvmerge's capabilities
18:55:31: Capability: VERSION=mkvmerge v2.9.8 ('C'est le bon')
18:55:31: Capability: BZ2
18:55:31: Capability: LZO
18:55:31: Capability: FLAC
18:55:34: Locale selection logic: select_locale English (English) uu_locale_lower en translation_c::get_default_ui_locale() en app->m_ui_locale en
18:55:37: Querying mkvmerge's capabilities
18:55:37: Capability: VERSION=mkvmerge v2.9.8 ('C'est le bon')
18:55:37: Capability: BZ2
18:55:37: Capability: LZO
18:55:37: Capability: FLAC
18:55:53: identify 1: command: ``"D:\AdP\_Video_\Mkvtoolnix\mkvmerge.exe" "@C:\TEMP\mmg-mkvmerge-options-3884-1254848153"''
18:55:53: identify 1: result: 0
18:55:53: identify 1: output[0]: ``File 'G:\Peliculas\Quantum of Solace (XviD)(Espaņol AC3 5.1)(English AC3 5.1)(Subtitulos).mkv': container: Matroska [title:Quantum\sof\sSolace duration:6374280000000]''
18:55:53: identify 1: output[1]: ``''
18:55:53: identify 1: output[2]: ``Track ID 1: video (V_MS/VFW/FOURCC, XVID) [language:und track_name:Quantum\sof\sSolace display_dimensions:720x304 default_track:1 forced_track:0]''
18:55:53: identify 1: output[3]: ``''
18:55:53: identify 1: output[4]: ``Track ID 2: audio (A_AC3) [language:spa track_name:(AC3\s5.1) default_track:1 forced_track:0]''
18:55:53: identify 1: output[5]: ``''
18:55:53: identify 1: output[6]: ``Track ID 3: audio (A_AC3) [language:eng track_name:(AC3\s5.1) default_track:0 forced_track:0]''
18:55:53: identify 1: output[7]: ``''
18:55:53: identify 1: output[8]: ``Track ID 4: subtitles (S_TEXT/UTF8) [language:spa default_track:0 forced_track:0]''
18:55:53: identify 1: output[9]: ``''
18:55:53: identify 1: output[10]: ``Track ID 5: subtitles (S_TEXT/UTF8) [language:eng default_track:0 forced_track:0]''
18:55:53: identify 1: output[11]: ``''
18:55:53: identify 1: output[12]: ``Attachment ID 1: type "image/jpeg", size 437901 bytes, description "Poster", file name "Quantum\sof\sSolace\sver1.jpg"''
18:55:53: identify 1: output[13]: ``''
18:55:53: identify 1: output[14]: ``Attachment ID 2: type "image/jpeg", size 212939 bytes, description "Poster", file name "Quantum\sof\sSolace\sver2.jpg"''
18:55:53: identify 1: output[15]: ``''
18:55:53: identify 1: output[16]: ``Attachment ID 3: type "image/jpeg", size 210077 bytes, description "Poster", file name "Quantum\sof\sSolace\sver3.jpg"''
18:55:53: identify 1: output[17]: ``''
18:55:53: identify 1: output[18]: ``Attachment ID 4: type "image/jpeg", size 276761 bytes, description "Poster", file name "Quantum\sof\sSolace\sver4.jpg"''
18:55:53: identify 1: output[19]: ``''
18:55:53: Attached file ID 64424509441 MIME type 'image/jpeg' size 64424947341 description 'Poster' name 'Quantum of Solace ver1.jpg'
18:55:53: Attached file ID 9793435967946754 MIME type 'image/jpeg' size 9793435968159691 description 'Poster' name 'Quantum of Solace ver2.jpg'
18:55:53: Attached file ID 9793435967946755 MIME type 'image/jpeg' size 9793435968156829 description 'Poster' name 'Quantum of Solace ver3.jpg'
18:55:53: Attached file ID 9793435967946756 MIME type 'image/jpeg' size 9793435968223513 description 'Poster' name 'Quantum of Solace ver4.jpg'
18:55:53: EAFB size 1
18:55:53: EAFB size 2
18:55:53: EAFB size 3
18:55:53: EAFB size 4
Old 6th October 2009, 19:07   #1200  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Thanks. The problem should be fixed in http://www.bunkus.org/videotools/mkv...-172-setup.exe (still being uploaded; should be done in eight minutes).
Mosu is offline
