19th February 2017, 08:03 | #3161 | Link |
a. DPL and DPL2 are methods for downmixing 5.1 to stereo which have no influence on the required bit rate
b. no clue what you do with multiple files or not, the file count should not have any influence on whether a downmix is possible or not. -> please describe in details what you do and what doesn't work since currently I have no clue. + create a debug output, if you don't know how to create a debug output read http://www.selur.de/support There might be a bug in Hybrid, but unless I can reproduce and understand the issue I can't do anything about it. Cu Selur |
20th February 2017, 05:33 | #3162 | Link | |
Audio tab, set Filtering to Stereo, set audio Encoder tab to Qaac cvbr and High Efficiency, set audio bitrate to 32. Now drag and drop a file. The audio box to the right in the Audio tab then shows what the audio output will be. It shows 32 kbps and stereo. Now do the same but instead of Stereo choose DPL or DPL2. When I drag and drop the file, the bitrate that was set at High Efficiency 32 kbps changes to Low Complexity and 192 kbps. If I change it to High Efficiency, the lowest bitrate I can choose is 80 kbps. My assumption is DPL and DPL2 require a minimum bitrate to be set, since that's what it is doing. I can get around that by drag-dropping the file and then setting the audio to 32kbps and DPL and then pressing the minus button in the audio output box to delete the drag-dropped audio and pressing the + button to add the 32kbps DPL audio. And it does output in 32 kbps and in what sounds like DPL. If I drag-drop more than one file at a time, I can't use that trick because pressing the + button only adds the audio for one of the drag-dropped files. If I press the audio Source button, it adds audio for both drag-dropped files, but puts them at 192 kbps instead of 32 kbps. The main question is the first part of this post. If audio is set to QAAC, DPL, High Efficiency, 32 kbps, is drag-dropping a file supposed to change the audio to Low Complexity 192 kbps? And is DPL/DPL2 with High Efficiency supposed to have a lowest kbps possible setting of 80 kbps? Even if DPL/DPL2 with High Efficiency has a lowest kbps setting of 80, maybe I'm missing a setting somewhere that forces Hybrid to keep the 80 kbps setting, since every time I drag-drop with DPL or DPL2 and High Efficiency QAAC, the bitrate changes to 192. (Though it does let me manually change it to as low as 80 kbps.) FDK let's me drag-drop to DPL/DPL2 with 32 kbps, but if I had it set to High Efficiency or High Efficiency V2, it changes it to Low Complexity (but does keep it at 32 kbps.) Last edited by Dclose; 20th February 2017 at 05:42. |
20th February 2017, 08:27 | #3163 | Link |
Reason isn't DPL/DPL2, but simply that Hybrid seems to ignore the downmix when you use drag&drop.
Since you provided no information about: a. What audio handling method you use. b. What characteristics your audio files have. c. What OS you are on. d. What other settings you use. this will take a while. btw. to see the restrictions regarding bit rates from the qaac encoder you can call 'qaac --formats': Code:
LC 8000Hz Mono -- 8,12,16,20,24 LC 8000Hz Stereo -- 16,20,24,28,32,40,48 LC 8000Hz 3.0 (C L R) -- 24,28,32,40,48,56,64,72 LC 8000Hz 4.0 (L R Ls Rs) -- 32,40,48,56,64,72,80,96 LC 8000Hz 4.0 (C L R Cs) -- 32,40,48,56,64,72,80,96 LC 8000Hz 5.0 (C L R Ls Rs) -- 40,48,56,64,72,80,96,112 LC 8000Hz 5.1 (C L R Ls Rs LFE) -- 40,48,56,64,72,80,96,112 LC 8000Hz 6.0 (C L R Ls Rs Cs) -- 48,56,64,72,80,96,112,128,144 LC 8000Hz 6.1 (C L R Ls Rs Cs LFE) -- 48,56,64,72,80,96,112,128,144 LC 8000Hz 7.0 (C L R Ls Rs Rls Rrs) -- 56,64,72,80,96,112,128,144,160 LC 8000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 56,64,72,80,96,112,128,144,160 LC 8000Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 64,72,80,96,112,128,144,160,192 LC 11025Hz Mono -- 8,12,16,20,24,28,32 LC 11025Hz Stereo -- 16,20,24,28,32,40,48,56,64 LC 11025Hz 3.0 (C L R) -- 40,48,56,64,72,80,96 LC 11025Hz 4.0 (L R Ls Rs) -- 48,56,64,72,80,96,112,128 LC 11025Hz 4.0 (C L R Cs) -- 48,56,64,72,80,96,112,128 LC 11025Hz 5.0 (C L R Ls Rs) -- 64,72,80,96,112,128,144,160 LC 11025Hz 5.1 (C L R Ls Rs LFE) -- 64,72,80,96,112,128,144,160 LC 11025Hz 6.0 (C L R Ls Rs Cs) -- 72,80,96,112,128,144,160,192 LC 11025Hz 6.1 (C L R Ls Rs Cs LFE) -- 72,80,96,112,128,144,160,192 LC 11025Hz 7.0 (C L R Ls Rs Rls Rrs) -- 96,112,128,144,160,192,224 LC 11025Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 96,112,128,144,160,192,224 LC 11025Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 96,112,128,144,160,192,224,256 LC 12000Hz Mono -- 12,16,20,24,28,32 LC 12000Hz Stereo -- 24,28,32,40,48,56,64 LC 12000Hz 3.0 (C L R) -- 40,48,56,64,72,80,96 LC 12000Hz 4.0 (L R Ls Rs) -- 48,56,64,72,80,96,112,128 LC 12000Hz 4.0 (C L R Cs) -- 48,56,64,72,80,96,112,128 LC 12000Hz 5.0 (C L R Ls Rs) -- 64,72,80,96,112,128,144,160 LC 12000Hz 5.1 (C L R Ls Rs LFE) -- 64,72,80,96,112,128,144,160 LC 12000Hz 6.0 (C L R Ls Rs Cs) -- 72,80,96,112,128,144,160,192 LC 12000Hz 6.1 (C L R Ls Rs Cs LFE) -- 72,80,96,112,128,144,160,192 LC 12000Hz 7.0 (C L R Ls Rs Rls Rrs) -- 96,112,128,144,160,192,224 LC 12000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 96,112,128,144,160,192,224 LC 12000Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 96,112,128,144,160,192,224,256 LC 16000Hz Mono -- 12,16,20,24,28,32,40,48 LC 16000Hz Stereo -- 24,28,32,40,48,56,64,72,80,96 LC 16000Hz 3.0 (C L R) -- 40,48,56,64,72,80,96,112,128,144 LC 16000Hz 4.0 (L R Ls Rs) -- 48,56,64,72,80,96,112,128,144,160,192 LC 16000Hz 4.0 (C L R Cs) -- 48,56,64,72,80,96,112,128,144,160,192 LC 16000Hz 5.0 (C L R Ls Rs) -- 64,72,80,96,112,128,144,160,192,224 LC 16000Hz 5.1 (C L R Ls Rs LFE) -- 64,72,80,96,112,128,144,160,192,224 LC 16000Hz 6.0 (C L R Ls Rs Cs) -- 72,80,96,112,128,144,160,192,224,256,288 LC 16000Hz 6.1 (C L R Ls Rs Cs LFE) -- 72,80,96,112,128,144,160,192,224,256,288 LC 16000Hz 7.0 (C L R Ls Rs Rls Rrs) -- 96,112,128,144,160,192,224,256,288,320 LC 16000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 96,112,128,144,160,192,224,256,288,320 LC 16000Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 96,112,128,144,160,192,224,256,288,320,384 LC 22050Hz Mono -- 16,20,24,28,32,40,48,56,64 LC 22050Hz Stereo -- 32,40,48,56,64,72,80,96,112,128 LC 22050Hz 3.0 (C L R) -- 48,56,64,72,80,96,112,128,144,160,192 LC 22050Hz 4.0 (L R Ls Rs) -- 64,72,80,96,112,128,144,160,192,224,256 LC 22050Hz 4.0 (C L R Cs) -- 64,72,80,96,112,128,144,160,192,224,256 LC 22050Hz 5.0 (C L R Ls Rs) -- 80,96,112,128,144,160,192,224,256,288,320 LC 22050Hz 5.1 (C L R Ls Rs LFE) -- 80,96,112,128,144,160,192,224,256,288,320 LC 22050Hz 6.0 (C L R Ls Rs Cs) -- 96,112,128,144,160,192,224,256,288,320,384 LC 22050Hz 6.1 (C L R Ls Rs Cs LFE) -- 96,112,128,144,160,192,224,256,288,320,384 LC 22050Hz 7.0 (C L R Ls Rs Rls Rrs) -- 112,128,144,160,192,224,256,288,320,384,448 LC 22050Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 112,128,144,160,192,224,256,288,320,384,448 LC 22050Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 128,144,160,192,224,256,288,320,384,448,512 LC 24000Hz Mono -- 16,20,24,28,32,40,48,56,64 LC 24000Hz Stereo -- 32,40,48,56,64,72,80,96,112,128 LC 24000Hz 3.0 (C L R) -- 48,56,64,72,80,96,112,128,144,160,192 LC 24000Hz 4.0 (L R Ls Rs) -- 64,72,80,96,112,128,144,160,192,224,256 LC 24000Hz 4.0 (C L R Cs) -- 64,72,80,96,112,128,144,160,192,224,256 LC 24000Hz 5.0 (C L R Ls Rs) -- 80,96,112,128,144,160,192,224,256,288,320 LC 24000Hz 5.1 (C L R Ls Rs LFE) -- 80,96,112,128,144,160,192,224,256,288,320 LC 24000Hz 6.0 (C L R Ls Rs Cs) -- 96,112,128,144,160,192,224,256,288,320,384 LC 24000Hz 6.1 (C L R Ls Rs Cs LFE) -- 96,112,128,144,160,192,224,256,288,320,384 LC 24000Hz 7.0 (C L R Ls Rs Rls Rrs) -- 112,128,144,160,192,224,256,288,320,384,448 LC 24000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 112,128,144,160,192,224,256,288,320,384,448 LC 24000Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 128,144,160,192,224,256,288,320,384,448,512 LC 32000Hz Mono -- 24,28,32,40,48,56,64,72,80,96 LC 32000Hz Stereo -- 48,56,64,72,80,96,112,128,144,160,192 LC 32000Hz 3.0 (C L R) -- 72,80,96,112,128,144,160,192,224,256,288 LC 32000Hz 4.0 (L R Ls Rs) -- 96,112,128,144,160,192,224,256,288,320,384 LC 32000Hz 4.0 (C L R Cs) -- 96,112,128,144,160,192,224,256,288,320,384 LC 32000Hz 5.0 (C L R Ls Rs) -- 128,144,160,192,224,256,288,320,384,448 LC 32000Hz 5.1 (C L R Ls Rs LFE) -- 128,144,160,192,224,256,288,320,384,448 LC 32000Hz 6.0 (C L R Ls Rs Cs) -- 144,160,192,224,256,288,320,384,448,512,576 LC 32000Hz 6.1 (C L R Ls Rs Cs LFE) -- 144,160,192,224,256,288,320,384,448,512,576 LC 32000Hz 7.0 (C L R Ls Rs Rls Rrs) -- 192,224,256,288,320,384,448,512,576,640 LC 32000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 192,224,256,288,320,384,448,512,576,640 LC 32000Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 192,224,256,288,320,384,448,512,576,640,768 LC 44100Hz Mono -- 32,40,48,56,64,72,80,96,112,128,144,160,192,224,256 LC 44100Hz Stereo -- 64,72,80,96,112,128,144,160,192,224,256,288,320 LC 44100Hz 3.0 (C L R) -- 96,112,128,144,160,192,224,256,288,320,384,448 LC 44100Hz 4.0 (L R Ls Rs) -- 128,144,160,192,224,256,288,320,384,448,512,576,640 LC 44100Hz 4.0 (C L R Cs) -- 128,144,160,192,224,256,288,320,384,448,512,576,640 LC 44100Hz 5.0 (C L R Ls Rs) -- 160,192,224,256,288,320,384,448,512,576,640,768 LC 44100Hz 5.1 (C L R Ls Rs LFE) -- 160,192,224,256,288,320,384,448,512,576,640,768 LC 44100Hz 6.0 (C L R Ls Rs Cs) -- 192,224,256,288,320,384,448,512,576,640,768,960 LC 44100Hz 6.1 (C L R Ls Rs Cs LFE) -- 192,224,256,288,320,384,448,512,576,640,768,960 LC 44100Hz 7.0 (C L R Ls Rs Rls Rrs) -- 224,256,288,320,384,448,512,576,640,768,960 LC 44100Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 224,256,288,320,384,448,512,576,640,768,960 LC 44100Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 256,288,320,384,448,512,576,640,768,960,1280 LC 48000Hz Mono -- 32,40,48,56,64,72,80,96,112,128,144,160,192,224,256 LC 48000Hz Stereo -- 64,72,80,96,112,128,144,160,192,224,256,288,320 LC 48000Hz 3.0 (C L R) -- 96,112,128,144,160,192,224,256,288,320,384,448 LC 48000Hz 4.0 (L R Ls Rs) -- 128,144,160,192,224,256,288,320,384,448,512,576,640 LC 48000Hz 4.0 (C L R Cs) -- 128,144,160,192,224,256,288,320,384,448,512,576,640 LC 48000Hz 5.0 (C L R Ls Rs) -- 160,192,224,256,288,320,384,448,512,576,640,768 LC 48000Hz 5.1 (C L R Ls Rs LFE) -- 160,192,224,256,288,320,384,448,512,576,640,768 LC 48000Hz 6.0 (C L R Ls Rs Cs) -- 192,224,256,288,320,384,448,512,576,640,768,960 LC 48000Hz 6.1 (C L R Ls Rs Cs LFE) -- 192,224,256,288,320,384,448,512,576,640,768,960 LC 48000Hz 7.0 (C L R Ls Rs Rls Rrs) -- 224,256,288,320,384,448,512,576,640,768,960 LC 48000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 224,256,288,320,384,448,512,576,640,768,960 LC 48000Hz 8.0 (C L R Ls Rs Rls Rrs Cs) -- 256,288,320,384,448,512,576,640,768,960,1280 HE 32000Hz Mono -- 12,16,24,32,40 HE 32000Hz Stereo -- 24,32,40,48,56,64,80 HE 32000Hz 4.0 (L R Ls Rs) -- 48,56,64,80,96,112,128,160 HE 32000Hz 5.1 (C L R Ls Rs LFE) -- 64,80,96,112,128,160,192 HE 32000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 96,112,128,160,192,224,256 HE 44100Hz Mono -- 16,24,32,40 HE 44100Hz Stereo -- 32,40,48,56,64,80 HE 44100Hz 4.0 (L R Ls Rs) -- 64,80,96,112,128,160 HE 44100Hz 5.1 (C L R Ls Rs LFE) -- 80,96,112,128,160,192 HE 44100Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 112,128,160,192,224,256 HE 48000Hz Mono -- 16,24,32,40 HE 48000Hz Stereo -- 32,40,48,56,64,80 HE 48000Hz 4.0 (L R Ls Rs) -- 64,80,96,112,128,160 HE 48000Hz 5.1 (C L R Ls Rs LFE) -- 80,96,112,128,160,192 HE 48000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 112,128,160,192,224,256 HE 88200Hz Mono -- 32,40,48,56,64,80,96,112,128,160 HE 88200Hz Stereo -- 64,80,96,112,128,160,192,224,256,320 HE 88200Hz 4.0 (L R Ls Rs) -- 128,160,192,224,256,320,448,640 HE 88200Hz 5.1 (C L R Ls Rs LFE) -- 160,192,224,256,320,448,640 HE 88200Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 224,256,320,448,640,1120 HE 96000Hz Mono -- 32,40,48,56,64,80,96,112,128,160 HE 96000Hz Stereo -- 64,80,96,112,128,160,192,224,256,320 HE 96000Hz 4.0 (L R Ls Rs) -- 128,160,192,224,256,320,448,640 HE 96000Hz 5.1 (C L R Ls Rs LFE) -- 160,192,224,256,320,448,640 HE 96000Hz 7.1 (C Lc Rc L R Ls Rs LFE) -- 224,256,320,448,640,1120 Cu Selur Ps.: send you a pm with a link to a dev version which should fix the issue,... Last edited by Selur; 20th February 2017 at 10:14. Reason: pm info |
22nd February 2017, 22:29 | #3164 | Link | ||
It looks like the new fix fixed it. Thank you. I hadn't even considered it could be linked to drag&dropping. |
5th March 2017, 10:40 | #3165 | Link |
Hybrid rev 2017.05.03.1:
*fixed*
Cu Selur |
5th March 2017, 11:44 | #3167 | Link | |
+ No time and motivation to adjust the NSIS Installer script. (aside from minimal changes I haven't adjusted the script for ages and it would need a complete overhaul) Last edited by Selur; 5th March 2017 at 11:47. |
5th March 2017, 12:25 | #3168 | Link | |
I did a clean install here, and Vapousynth is enabled instead of Avisynth. Windows 10 x64 Last edited by Havokdan; 5th March 2017 at 12:30. |
6th March 2017, 08:06 | #3170 | Link |
Hybrid rev 2017.03.06.1:
*fixed*
-> downloads: http://www.selur.de/downloads Cu Selur Ps.: to Windows users: You can switch between vapoursynth and avisynth by adjusting the misc.ini file. |
19th March 2017, 11:32 | #3171 | Link |
Hybrid rev 2017.03.19.1:
*fixed*
Cu Selur |
26th March 2017, 10:03 | #3177 | Link |
Hybrid rev 2017.03.26.1:
*fixed*
Cu Selur |
9th April 2017, 22:59 | #3178 | Link |
2017.03.26.1
I noticed that under the Audio Tab/Audio Encoding Options/Filtering, whenever I set "Downmix" to custom and regardless of what I place for the remix call, when I add the project to the queue I receive the error message "Unsupported downmix call 2, custom!" twice. Is this a bug or am I butchering my custom sox call? Let me know if you would like a log. [EDIT] Code:
2017.04.09 - 11:09:24_Windows 7-32bit_2017.03.26.1 - level 8: creating sox call,... 2017.04.09 - 11:09:24_Windows 7-32bit_2017.03.26.1 - level 8: soxRemixCall input count 2, mode: custom 2017.04.09 - 11:09:24_Windows 7-32bit_2017.03.26.1 - level 8: Unsupported downmix call 2, custom! Last edited by InTheLight; 10th April 2017 at 00:57. |
10th April 2017, 20:22 | #3180 | Link |
Hybrid rev 2017.04.10.1:
*fixed*
-> downloads: http://www.selur.de/downloads Cu Selur |
