7th October 2014, 11:39 | #2361 | Link |
Thanks!
The tedious question is related to programming: how difficult it is to implement the command / procedure of temporary suspension of execution of commands (pause button) in the converter, possible obstacles and how much time will? DivX brakes more than 9 months > example |
7th October 2014, 11:47 | #2362 | Link |
You can pause running processes without a problem for quite some time now, while keeping Hybrid open.
A pause option which will allow to pause and close Hybrid would require a whole memory dump and a lot of other stuff, which either would require: a. a rewrite of all the tools involved to do this (since each would need to create their own memory and internal position dump) b. administrator rights and some OS specific hacks (I'm not capable of without a lot of time studying each OS) -> I doubt that you will see any of this inside an application, since basically it would require the functionality Windows sleep mode has, but even more complex since you want this only for a hand full of applications. (on Windows pausing like Hybrid is doing it, is a simple call to NtSuspendProcess which is a basic function of the ntdll, implementing that inside a c/c++ based software should be possible in a short time. If the DivX Networks hasn't implemented this in 9 months it's not because they can't it's because they do not want to.) Last edited by Selur; 7th October 2014 at 11:54. |
7th October 2014, 12:32 | #2364 | Link |
avsViewer is a really simple tools which doesn't have any real capabilities to modify avs files it's just a simple tool to display avs files.
It's not intended to be some sort of avs editor like avsMod or similar. -> don't think this will happen. |
10th October 2014, 18:13 | #2366 | Link |
Привет,
Have a folder with DVD or MKV > chose x264 > chose restriction 1CD (e.g. automatically 749kb/s) > then delete or adds a chapter - Hybrid not responsive / does not change the bit rate for mode 1CD (on former 749kb/s). |
10th October 2014, 18:25 | #2367 | Link |
will look into it also "not responsive" and "does not change the bit rate" are two totally different things.
-> fixed the not adjusting of the target bit rate in the grayed out dialog Last edited by Selur; 10th October 2014 at 18:49. |
14th October 2014, 09:36 | #2369 | Link |
Hybrid rev 2014.10.13.1:
*fixed*
-> downloads: http://www.selur.de/downloads Cu Selur |
15th October 2014, 21:46 | #2372 | Link |
Hybrid rev 2014.10.15.1:
*added*
Cu Selur |
23rd October 2014, 21:38 | #2373 | Link |
Hybrid rev 2014.10.23.1:
*fixed*
Cu Selur |
24th October 2014, 07:59 | #2374 | Link |
Hybrid rev 2014.10.24.1:
*fixed*
Cu Selur |
25th October 2014, 00:58 | #2375 | Link |
Hybrid rev 2014.10.25.1:
*fixed*
Cu Selur |
3rd November 2014, 18:06 | #2376 | Link |
Hybrid rev 2014.11.03.1:
*changed*
Cu Selur |
9th November 2014, 02:13 | #2377 | Link |
Hybrid rev 2014.11.09.1:
*fixed*
9th November 2014, 12:39 | #2378 | Link |
Hybrid rev 2014.11.09.2:
*changed*
*fixed*
11th November 2014, 15:36 | #2379 | Link |
Hybrid rev 2014.11.11.1:
*fixed*
Cu Selur |
11th November 2014, 18:18 | #2380 | Link |
Hybrid rev 2014.11.11.2:
*fixed*
Cu Selur |
