Old 29th June 2014, 13:05   #2221  |  Link
Music Fan
Originally Posted by Selur View Post
[*]video: initial support for ffvhuff
I didn't know ffvhuff, it seems interesting, more efficient than huffyuv.
How to install and use it ?
Can we capture in this format ? I use Lagarith usually.
Music Fan is offline   Reply With Quote
Old 29th June 2014, 13:14   #2222  |  Link
Selur
Selur's Avatar
ffvhuff = huffyuv + "adaptive huffman tables" + support for all the color formats ffmpeg supports
comes with ffmpeg,... argh typo is hiding the option-tab of ffvhuff
(tab shows if UT-Video is selected,... argh -> select UT-Video, then select FFVHuff)
since it's part of ffmpeg/ffdshow/libav I see no reason against that.
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 29th June 2014, 15:04   #2223  |  Link
Music Fan
Thanks, I'd like to try it but I don't understand how to install fmpeg. I took the last version there ;
http://ffmpeg.zeranoe.com/builds/
I found a french a french tutorial but it seems complex ;
http://fr.wikihow.com/installer-FFmpeg-sur-Windows
Is there a version with installer ?
Old 29th June 2014, 15:49   #2224  |  Link
Selur
Selur's Avatar
yes, the installer includes ffmpeg. (I compile up-to-date builds before new releases using: https://github.com/jb-alvarado/media-autobuild_suite <- easy to use)
Old 29th June 2014, 19:07   #2225  |  Link
Music Fan
I guess you are talking about Hybrid, but I'm searching for an installer for ffmpeg, to use it with any program, not only Hybrid.
I don't find links or explanations on this page, github is a confusing website, I prefer videohelp or sourceforge.
edit : I found the link below, it should be placed on top of the page.
Old 29th June 2014, 19:35   #2226  |  Link
Selur
Selur's Avatar
I'd like to use ffvHuff with my capture card with the program Virtual VCR (and maybe also virtual Dub).
Installing ffdshow and enabling the vfw encoders should help there. (Your PM storage is full)
"Download zip"
Old 29th June 2014, 19:49   #2227  |  Link
Music Fan
Ok, but I don't use it anymore.
The ffmpeg developers should release this codec alone, to use it as simply as Lagarith, Xvid, x264...
I downloaded media-autobuild_suite and I read the explanation but it's not clear for me (he doesn't explain how to choose the path of the exe to compile and it seems to install other tools I don't need) and it needs 3 hours to compile
I don't understand why a so known program isn't available with an installer usable by anybody, as all programs, it's discouraging.
Ok, I removed some messages.
Old 29th June 2014, 20:08   #2228  |  Link
Selur
Selur's Avatar
media-autobuild_suite is a large scrit ment to build multiple sources from source, so the inital build will take a long time, later it's faster (initially the build environment itself needs to be build,..)
Old 29th June 2014, 20:37   #2229  |  Link
Music Fan
Ok, so that's not for me.
But I found another tutorial ;
http://www.eric-pidoux.com/tutoriaux...us-windows-mac
Thus I put the 3 exe in the folder C:\ffmpeg and added this folder in the path list in Environment Variables.
But it's not enough to use the ffvhuff codec which does not appear in the codec list in Virtual Dub.
Old 29th June 2014, 20:42   #2230  |  Link
Selur
Selur's Avatar
You use ffvhuff with Virtual Dub, you either need to:
a. call ffmpeg through the external encoder feature of Virtual Dub (with the right parameters)
or
b. use ffdshow
Old 29th June 2014, 20:54   #2231  |  Link
Music Fan
or
b. use ffdshow
Thanks, I didn't know the external encoder feature of Virtual Dub, usually I go in video, compression and select a codec in this list.
In options, external encoders, I see encoders sets and encoders but I don't understand how to add ffvhuff, I will make research.
Old 29th June 2014, 20:59   #2232  |  Link
Selur
Selur's Avatar
a. look how Hybrid calls ffmpeg for encoding with ffvhuff
b. read http://forums.virtualdub.org/index.php?act=ST&f=3&t=18840&st=0 (and if that isn't enough there are a bunch of examples over in the videohelp forum about using the external encoder)
c. adapt the encoder call with the call from a.
Old 29th June 2014, 23:36   #2233  |  Link
Selur
Selur's Avatar
Hybrid rev 2014.06.30.1:
fixed*
  • general: tool tips not showing
  • video: ffvHuff-tab configuration en-/disable
-> downloads: http://www.selur.de/downloads
Cu Selur
Old 30th June 2014, 00:47   #2234  |  Link
Music Fan
Thanks but all images disappeared and it's hard to understand without it, especially about command arguments.
I don't find these examples.
Old 30th June 2014, 01:21   #2235  |  Link
Selur
Selur's Avatar
http://forum.videohelp.com/threads/321874-VirtualDub-doesn-t-see-x264-codec?p=1993055&viewfull=1#post1993055 <- using x264, NeroAacEnc and MP4Box with Virtual Dub
http://forum.videohelp.com/threads/359154-what-apps-allow-the-use-of-external-encoders?p=2270351&viewfull=1#post2270351 <- using DivX265 and MP4Box with Virtual Dub
https://encodingtalk.com/threads/virtualdub-save-direct-to-mp4-fraps-to-youtube-with-external-encoders.2446/page-2 <- about using ffmpeg with Virtual Dub
simply searching for:
  • Virtual Dub external encoder x265
  • Virtual Dub external encoder x264
  • Virtual Dub external encoder ffmpeg
  • Virtual Dub external encoder MP4Box
should produce lots of useful results with your favorite search engine.
Old 30th June 2014, 10:07   #2236  |  Link
Music Fan
Thanks for your research (I did the same before to write my previous post) but none of these threads explain clearly how to configure Virtual Dub for ffvhuff.
I will have a look at Hybrid's call.
Old 30th June 2014, 10:52   #2237  |  Link
Music Fan
The last Hybrid rev (2014.6.30.1) does not want to launch on Windows XP Pro 32, there is a message about QSVEncC.exe. Same message when I restart, again and again.
Actually Hybrid works if I remove QSVEncC.exe.
Old 30th June 2014, 10:56   #2238  |  Link
Selur
Selur's Avatar
You are right, totally forgot about QSVEnc. Will remove QSVEnc from Hybrid for Windows XP (like I do for Vista), since it requires Windows 7 or never.
Old 30th June 2014, 11:21   #2239  |  Link
Music Fan
Ok.
I made a short encoding in ffvHuff with Hybrid, the bitrate is much higher than Lagarith's.
And I believe I won't be able to capture in ffvHuff because my capture tool is old and probably not ffvHuff compatible. And I can't use another capture program because Virtual VCR is the only one to be able to bypass my card's mpeg encoder and capture in lossless, so I will continue to use Lagarith for captures.
Old 30th June 2014, 11:27   #2240  |  Link
Selur
Selur's Avatar
Not surprised by that, iirc ffvHuff should be faster (during capturing and playback) but than lagarith, but should not compress as good.
