Old 14th April 2018, 09:04   #14641  |  Link
nevcairiel
That is the case for 3DBDs, always. Although left/right could be swapped and the AVC stream actually be the right eye, but there is always one main AVC stream you can just take without the MVC stream to get 2D.
Old 14th April 2018, 12:02   #14642  |  Link
pstn
yes that's what I'm talking about, is there any specific command?
thanks
pstn is offline   Reply With Quote
Old 15th April 2018, 08:55   #14643  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
To grab the 2D movie, you have to demux the MPLS, and select the AVC video stream and the audio and subtitle streams you are interested in, and drop the MVC. If you want to demux directly the M2TS file(s), you have to locate the one that contains the AVC stream. It's easy with a good player. The M2TS files with the MVC stream cannot be played directly.
The command to demux is exactly identical to the command to demux a 2D BD, just omit the MVC stream. But personally, I would use tsMuxeR instead of eac3to to demux a BD. It has a good GUI, easy to use.
r0lZ
Old 16th April 2018, 14:00   #14644  |  Link
pstn
thanks buddy
eac3to
