Old 24th April 2004, 23:55   #41  |  Link
ObiKenobi
Posts: n/a
Not yet but I'll set up some passes tonight and test it out. I'll try to post some screenshots either tomorrow or Monday.
Old 25th April 2004, 14:56   #42  |  Link
Selur
Selur's Avatar
@atreya2011:
to Q1: more like 100
to Q2: ment maximum Iframe interval (Advanced=>Motion=>Other) so, a value like 240
Old 26th April 2004, 09:30   #43  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
After backing up two of my recent TV captures (X-Files episodes "Via Negativa" and "El Mundo Gira"), I've decided to use my matrix with all analog captures from now, since I'm really pleased with the results. I won't post any screenshots, since I didn't encode these episodes using other matrices. I've encoded both episodes with a constant quantizer of 2 and VHQ=4, all the other settings were the same as the ones I've used with "Redrum". Resulting filesizes are 195 M ("Via Negativa") and 380 MB ("El Mundo Gira") - no wonder, since the "El Mundo Gira" capture was more noisy than the one of "Via Negativa".
This matrix still needs to be tested with DVD source. The K-PAX encode should be finished until Friday .
Please excuse if my English is crappy.
Archive of my Xvid builds
http://www.videoaudio.pl
Jawor is offline   Reply With Quote
Old 26th April 2004, 10:02   #44  |  Link
Aktan
Originally posted by Selur
btw. for those who encode animes:
you might also want to check out what happens if you boost b-frame sensivity, set b-frame offset to 0 and ratio to 1.0,.. (oh and set max b-frames to max i-frame distance)
You would sometimes get problems like this: http://forum.doom9.org/showthread.php?s=&threadid=71651
Aktan is offline   Reply With Quote
Old 27th April 2004, 09:43   #45  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Guys, can you remember me? I'm the one who started this thread
Just kidding. I don't mind this DCTune discussion at all - it's very interesting.
Here's another series of screenshots from "Redrum" (HVS - Good Picture, HVS - Best Picture, MPEG, Evil v0.1, Jawor's 1CD):
Old 27th April 2004, 09:50   #46  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Since You have source video can You encode them using DCTune based matrix and post screnshots to compare?
dimzon is offline   Reply With Quote
Old 27th April 2004, 11:49   #47  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Yea, sorry about that . I've somewhat hijacked the thread in developing my own method for creating matrices.
Oh, I really don't mind.
Also, you can stop using the Evil Matrix now - it's served its purpose as a test, and I think my current method far outstripes it in creating a quality encode.
I don't use it anymore. I've just used it in the "Redrum" comparison.
I would appreciate it if you try my new method
I'll let you know if I'd try.
I know that XviD supports (or at least, used to support) changing quantizations like this, but I think it's not mpeg4 compliant.
You're right, it's not
Old 28th April 2004, 07:04   #48  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Here is the long-awaited report concerning the K-Pax encode.
AviSynth script:
Clip=MPEG2Source("D:\K_PAX\VIDEO_TS\K-Pax.d2v",cpu2="ooooxx")
Clip=Crop(Clip,8,70,-6,-72,align=true)
Clip=Deen(Clip,"c3d",1,6,8)
Clip=UnDot(Clip)
Clip1=Trim(Clip,0,165784)
Clip1=LanczosResize(Clip1,608,256)
Clip2=Trim(Clip,165785,171555)
Clip2=BilinearResize(Clip2,608,256)
Clip3=Trim(Clip,171556,172920)
Clip3=LanczosResize(Clip3,608,256)
Clip=Clip1++Clip2++Clip3
Clip=UnDot(Clip)
Return Clip
I had to use the built-in deringer from mpeg2dec3.dll, because the movie had a lot of visible ringing artifacts (the source DVD is a low-cost edition bundled with a Polish magazine).
XviD Settings:
MSP=6, ChromaME, VHQ=4
Trellis ON, quantizers 2-31
AQ, Qpel, GMC ON
B-frames 3/1.00/1.00
Packed bitstream OFF
"fast" first pass
B-VOP sensitivity 2 (movie), 30 (credits)
Greyscale zone and weight=0.30 for the credits
I left rest of the settings at their default values
Results:
Video filesize 602 MB
Average quantizer = 2.714
quantizers:
2 - 28.1 %
3 - 71.8 %
>8 - 0.1 %
frame types:
I-frames - 0.98 %
P-frames - 17.11 %
B-frames - 63.39 %
S-frames - 18.51 %
And some screenshots (probably they won't tell you much, since tere's nothing to compare ):
Old 28th April 2004, 12:17   #49  |  Link
SoonUDie
Very nice looking! I wish there were comparisons, but with an entire movie I can understand why there aren't
Stuff was here at some point.
SoonUDie is offline   Reply With Quote
Old 28th April 2004, 19:28   #50  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Well, I'm quite happy with this encode
@dimzon: Thanks for testing my matrix.
Old 1st May 2004, 13:22   #51  |  Link
Teegedeck
Moderator, Ex(viD)-Mascot
Teegedeck's Avatar
Friends, would you mind if I branch your fabulous DC-Tune discussion into a dedicated new thread? I'm sure lots of people don't even know this discussion is going on here, and also this used to be the thread about Jawor's 1 CD matrix, after all.
Edit: Done. Please continuue the DC-Tune discussion here .
It's a man's life in Doom9's 52nd MPEG division.
"The cat sat on the mat."
ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl!
Teegedeck is offline   Reply With Quote
Old 6th May 2004, 20:57   #52  |  Link
rlin
This is interesting
Hello
Im all new to using a quantization matrix, and im not really sure what its about. But as far as i can understand this thread is about "inserting" the best settings for 1CD backups using custom settings for Xvid.
Today i encoded Brotherhood of the Wolf using your matrix and got fairly good results. The picture is however a bit to grainy at times. Should i use a deinterlace filter? Could that help your matrix produce better result? Another thing that went wrong was the target size, the file was about 100 mb to small. My target size was 717 mb and i got a 617 mb file? Ehh my Audio A says 117 mb in g-knot, could that be the problem? In the avi-overhead area is however no audio checked.
Btw, Brotherhood of the Wolf is 2h and 17m, and my screen-res is 640 x 272.
I find this matrix-stuff wery interesting and ill keep testing it, and in the end i might actually understand how it works.
/Skerno
/ Wath is best in life? Crush the enemies, see them driven before you, hear the lemendation of the women. \
rlin is offline   Reply With Quote
Old 7th May 2004, 21:20   #53  |  Link
DDogg
Retired, but still around
DDogg's Avatar
Jawor, seems to provide good compression when used for MPEG2. Compression was the only thing tested.
DDogg is offline   Reply With Quote
Old 10th May 2004, 07:08   #54  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Re: This is interesting
This matrix tends to keep grain indeed.
Only if you can see interlacing artifacts on your source material.
To be frank, I have no idea. As a rule of thumb, always deinterlace/IVTC unless you want to keep the interlacing (using the Interlaced encoding option) for playback on an interlaced TV.
My matrix is really compressible due to high quantizers.
Old 10th May 2004, 09:38   #55  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Here's another comparison I made for you, folks. This time I used a low bitrate on a high motion scene to create visible blocking artifacts. The test clip is The Matrix Reloaded (R2, PAL) chapter 20. I used XviD 1.0 RC4, VirtualDubMod 1.5.4.1, AviSynth 2.5.4.
AviSynth script:
Clip=MPEG2Source("D:\MATRIX_RELOADED_DISC_1\VIDEO_TS\reloaded.d2v")
Clip=Crop(Clip,0,76,-0,-76)
Clip=Deen(Clip,"c3d",1,4,6)
Clip=Crop(Clip,2,0,-0,-0)
Clip=UnDot(Clip)
Clip=LanczosResize(Clip,656,272)
Return Clip
XviD settings:
target bitrate 600 kbps
"fast" first pass
MSP=6, Chroma ME, VHQ=4
maximum I-frame interval 250
Quarter Pixel, GMC, Trellis ON
B-VOPs 2/1.00/1.00
Quantizers 2-31
B-VOP Sensitivity 1
Quantizers for H.263:
average quantizer = 8.685
5 - 0.6 %
6 - 3.3 %
7 - 8.9 %
8 - 24.1 %
9 - 36.5 %
>9 - 26.6 %
Quantizers for MPEG:
average quantizer = 9.044
5 - 0.1 %
6 - 2.0 %
7 - 6.6 %
8 - 17.3 %
9 - 34.7 %
>9 - 39.4 %
Quantizers for Low Bitrate Matrix:
average quantizer = 9.012
5 - 0.1 %
6 - 1.7 %
7 - 6.9 %
8 - 18.6 %
9 - 35.1 %
>9 - 37.8 %
Quantizers for HVS - Good Picture:
average quantizer = 8.731
5 - 0.2 %
6 - 2.1 %
7 - 8.0 %
8 - 26.5 %
9 - 39.5 %
>9 - 23.7 %
Quantizers for HVS - Best Picture:
average quantizer = 9.176
5 - 0.1 %
6 - 1.6 %
7 - 5.7 %
8 - 14.6 %
9 - 34.1 %
>9 - 43.9 %
Quantizers for Jawor's 1CD Matrix:
average quantizer = 8.321
6 - 2.4 %
7 - 12.9 %
8 - 39.9 %
9 - 35.7 %
>9 - 9.0 %
And here are the screenshots (H.263, MPEG, Low Bitrate Matrix, HVS - Good Picture, HVS - Best Picture, Jawor's 1CD Matrix):
Series 1 - The Merovingian
Look at these interesting blocking patterns on Merv's face and on the wall
Series 2 - Debris
Blocking artifacts in the dust cloud and on parts of the marble statue flying around
Old 10th May 2004, 09:39   #56  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Series 3 - Anti-Gravity
Compare the blocking artifacts behind the guy's butt and above his sword
Series 4 - Neo vs. A Bad Guy
Blocks and mosquitos all over the frame
Old 10th May 2004, 09:44   #57  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
No wonder, since I used high coefficients. I designed this matrix to provide good compressibility.
Old 10th May 2004, 14:02   #58  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Here's another series of screenshots from The Matrix Reloaded comparison (H.263, MPEG, Low Bitrate Matrix, HVS Good Picture, HVS Best Picture, Jawor's 1CD Matrix):
Series 5 - Cutting Edge
Even more blocky than the previous series
Old 11th May 2004, 03:04   #59  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
@ Jawor
I wanna make sure you dont miss this !!!
Just coz your matrix got some real good results...
Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 12th May 2004, 07:10   #60  |  Link
Jawor
Ex-ter-mi-nate!
Jawor's Avatar
Here's another test: Star Trek: First Contact (R2, PAL) chapter 4. This chapter has some static scenes with panning and a scene full of smoke and shaky camera movements during the space battle. I was particularly curiuos how do the matrices cope with the smoke, so I took just one series of screenshots.
AviSynth script:
Clip=MPEG2Source("D:\DVD_VIDEO\VIDEO_TS\first_contact.d2v")
Clip=Crop(Clip,2,74,716,432,align=true)
Clip=Tweak(Clip,sat=0.75,bright=15)
Clip=UnDot(Clip)
Clip=LanczosResize(Clip,640,272)
Clip=UnDot(Clip)
Return Clip
XviD settings:
target bitrate 500 kbps
"fast" first pass
Qpel, GMC, Closed GOV, Trellis ON
B-VOPs 2 / 1.50 / 1.00
B-VOP Sensitivity 2
AQ, interlaced encoding, packed bitstream, Turbo, chroma optimizer, greyscale OFF
MSP=6, ChromaME, VHQ=1
Quantizers 2-31
The first five screenshots (H.263, MPEG, HVS Good Picture, HVS Best Picture, Jawor's 1CD Matrix):
Look at the blocky cloud on the left and notice that the rest of the frame looks much better.
Be patient, some other matrices are currently being tested with this clip.
