Old 21st May 2007, 14:18   #2181  |  Link
buzzqw
HDConvertToX author
sometimes seems avimux_gui is a little picky...
often is due to antivirus... or other running programs..
i suggest this secure procedure: load your file, set your options AND before click start encoding go to Advanced settings and check "Use FFmpeg Mux"
then start your encode
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 21st May 2007, 16:44   #2182  |  Link
vorob
Does you program include codec H.264 in it's pacage or i need to download and install it manualy?
vorob is offline
Old 21st May 2007, 17:16   #2183  |  Link
buzzqw
HDConvertToX author
automkv include x264.exe rev 654
automkv don't use vfw codec
BHH
buzzqw is offline
Old 21st May 2007, 19:27   #2184  |  Link
Mtz
Mtz's Avatar
I hope in a future release to allow using virtualdubmod instead of avimux at least when creating avi (xvid) files.
Here is described one problem with the standalone: http://forum.doom9.org/showthread.ph...91#post1005791
Avimux is not good for SAP. The xvid sap profile is useless if using avimux.
enjoy,
Mtz
Mtz is offline
Old 21st May 2007, 19:42   #2185  |  Link
buzzqw
HDConvertToX author
mmm... i will look
thanks
BHH
buzzqw is offline
Old 21st May 2007, 20:03   #2186  |  Link
Killerattacks
Great program buzzqw, really. Thanks.
But I have 2 little issues/questions:
1. It seems to me (I'm a novice to this) that DGIndex is detecting wrong framerates. For example I have a DVD here which is PAL and DGIndex is detecting a framerate of 25.000 and thus Automkv uses 25fps. BUT the resulting encode isn't "fluent", meaning pan shots are choppy. And if I play the DVD in WMP 11 and choose "statistics" the player says: "Frame rate: 25fps" and "Actual frame rate: 24,4fps". When using MPC to play it, the VideoMixing Renderer says something about an avarage framerate of ~24,4 in the beginning and is increasing _slowly_ to 24,93 after 4 minutes, 24,97 after 8 minutes and then I aborted this. I have no idea what's the meaning of this, but maybe you do.
2. I'm a little bit confused about the deinterlacing. Is there any particular deinterlacingalgorithm you would recommend? And what would be the wisest choice to choose if the deint Test detects that ~half the frames are progressive and ~half are deinterlaced and ~half of them are BFF and the other half TFF?
Killerattacks is offline
Old 21st May 2007, 21:33   #2187  |  Link
buzzqw
HDConvertToX author
dgindex detects the framerate written in mpeg file.. so blame the encoder... or better.. who have done that messy...
ouch.. post a fragment in avisynth usage forum... and search for help!
probably a hybrid approach is the way.. but .. post your sample
BHH
buzzqw is offline
Old 21st May 2007, 22:10   #2188  |  Link
TheRyuu
warpsharpened
What kind of movie is it?
I've gotten that sometimes. Most of the time you just need to use the Decimating filter and see if that works. From experience, AutoMKV doesn't detect this very well (sorry buzzqw).
Anime uses this, and so do some movies that were upconverted from 24fps progressive (or 23.97fps) to 29.97fps interlaced. (3:2)
Open up the original video in MPC or something were you can step frames (and that hasn't gone through any deinterlacing). Step a few frames. If some are progressive (has no interlacing lines) and some are interlaced (you'll see it) then you need decimating, which I believe is called 3:2 pulldown.
TheRyuu is offline
Old 22nd May 2007, 06:26   #2189  |  Link
JonRead
Sorry for being a newbie here, just literally installed the great software and was checking out the Wiki page. At the very bottom of the MT section, there is an update that makes it sound like there is no need for the script to be used anymore to get Dual Core speeds, is this correct ? I have downloaded version 0.84, does this mean I no longer need to update the software to make use of the extra speed with my E6400 Dual core with 2gb ram ? Thanks.
JonRead is offline
Old 22nd May 2007, 07:01   #2190  |  Link
buzzqw
HDConvertToX author
@wizboy11
well... i know... but isn't easy to detect hybrid movie
i will glady accept suggestions!
@JonRead
no, i never included MT avisynth build.
I can only suggest to check your CPUs usage, if over 80% (for all cpus) then MT isn't needed... if not.. use the MT approach
BHH
buzzqw is offline
Old 22nd May 2007, 12:47   #2191  |  Link
wallstreetcrash
I am trying to convert mkv and avi (Xvid) files to WMV. That works fine, but I can't get 5.1 audio. I press the exclamation marks, then choose audio codec: WMAPRO and Channels: 6, but the output audio is always WMA2 and 2-channel. BTW, I press WVC1_1_Pass_CBR profile first, then edit the audio.
How do I sort this out?
And the video filters, do you reccomend using it? The source is HD x264 files, and I don't think they need touching up, so left it as NONE. Will I see any benefit using it, and how much longer will it take to encode say using "RemoveGrain(mode=2)"
wallstreetcrash is offline
Old 22nd May 2007, 12:59   #2192  |  Link
apocracy656
I am having an issue with Automkv where every file i try to convert to Avi(xvid), what it does is it converts the audio just fine but when it goes to convert video it just skips that part and goes staight to muxing. when it uses avi synth it just crashes, and when i tell it to use ffmpeg mux it just spits out file a little bigger then sorce audio file that won't play. All the sorces files i have used converted just fine in MkvMagic but i wanna use something that will allow them to batch encode.
apocracy656 is offline
Old 22nd May 2007, 13:14   #2193  |  Link
buzzqw
HDConvertToX author
actually you cannot. Sorry.
the current workflow and avisynth don't support well the 5.1 output. maybe with avisynth 2.58 the waveextendedformat will be fixed.
filters isn't always needed. If your sorce is clean and don't need more compression ... don't apply it. The cpu used by removegrain is small... not more than 5%
@apocracy656
be sure to have installed all software linked in first page
AND REMEMBER TO USE THE NEW http://neuron2.net/dgmpgdec/dgmpgdec149.zip ... after that... retry...
BHH
buzzqw is offline
Old 22nd May 2007, 15:29   #2194  |  Link
vorob
I’ve got a strange problem. When I start encoding, and then for some reason turn off this process (for example I’ve forgot to do smth), then, if even I restart program, and start encoding it will convert audio but DOS windows with 1 and 2 pass video encoding will open for 1 sec and the close. To solve this problem I have to restart PC. Here is LOG http://vorob2.nm.ru/VTS_02_0.IFO.log
P.s. sorry for my eng, I’m Russian.
vorob is offline
Old 22nd May 2007, 15:52   #2195  |  Link
buzzqw
HDConvertToX author
what process ? automkv itself ?
audio but DOS windows with 1 and 2 pass video encoding will open for 1 sec and the close.To solve this problem I have to restart PC.
maybe the file isn't deleted when the new encoding start, because are locked by OS...
try empting the \temp folder manually before start a new encoding
i don't think is a issue of automkv... since after rebooting all is ok...
EDIT: your crop is wrong... isn't mod4 the width ... use -8 as left crop
BHH
buzzqw is offline
Old 22nd May 2007, 17:12   #2196  |  Link
apocracy656
@apocracy656
did that and its still skiping video encode as you can see from this log it finishs the audio then where its supposted to do video and where it tries to mux and all that stuff shows the same time in the log because it just went from audio to muxing with out any kind of video encode poping up.
12:08:55 Encoded 1' Audio Track: 28353696 bytes
12:08:55 BREAK ! FILE NOT SUPPORTED ! LAST TRY WITH FFMPEG!
12:08:55 Switched to FFmpeg for Video Encoding!
12:08:55 Fished Encoding!
12:10:24 Final Muxed size: -1 bytes
12:10:24 Encoding finished: 00:03:43 elapsed time
12:10:24 -----------------------------------------------------------------------
12:10:24 Muxing Script
12:10:24 C:\automkv\exe\matroska\AVIMux_GUI.exe C:\Encode\temp\muxavi
12:10:24
12:10:24 CLEAR
12:10:24 LOAD C:\Encode\temp\movie.avi
12:10:24 LOAD C:\Encode\temp\audio.mp3
12:10:24 SELECT FILE 1
12:10:24 ADD VIDEOSOURCE
12:10:24 SET INPUT OPTIONS
12:10:24 SET OPTION MP3 VERIFY CBR ALWAYS
12:10:24 SET OPTION MP3 VERIFY RESDLG OFF
12:10:24 SET OUTPUT OPTIONS
12:10:24 WITH SET OPTION
12:10:24 OPENDML 0
12:10:24 RECLISTS 0
12:10:24 AUDIO INTERLEAVE 3 FR
12:10:24 AVI ADDJUNKBEFOREHEADERS 0
12:10:24 PRELOAD 200
12:10:24 WITH AUDIO
12:10:24 NAME 1 english
12:10:24 END WITH
12:10:24 OVERWRITEDLG 0
12:10:24 CLOSEAPP 1
12:10:24 DONEDLG 0
12:10:24 ALL AUDIO 1
12:10:24 LEGACY 0
12:10:24 RECLISTS 0
12:10:24 NUMBERING OFF
12:10:24 MAXFILESIZE OFF
12:10:24 END WITH
12:10:24 START C:\Encode\temp\01(xvid)_full.avi
12:10:24 Script AutoCrop.log
12:10:24
12:10:24 Crop(4,0,632,480)
12:10:24 Script Resmovie.avs
12:10:24 Script movie.avs
12:10:24
12:10:24 LoadPlugin("C:\automkv\exe\filter\AddGrain.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\autocrop.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\aWarpSharp.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\blockbuster.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\cnr2.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\ColorMatrix.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\Convolution3D.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\corrector.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\DctFilter.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\Decomb.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\Deen.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\degrainmedian.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\DGDecode.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\EEDI2.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\fft3dfilter.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\FluxSmooth.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\frfun7.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\hqdn3d.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\LeakKernelDeint.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\MaskTools.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\medianblur.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\MipSmooth.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\MSharpen.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\mt_masktools.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\mvtools.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\NicAudio.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\RemoveGrainS.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\RepairS.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\SangNom.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\SimpleResize.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\SoundOut.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\TBilateral.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\TDeint.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\TIVTC.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\TomsMoComp.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\TTempSmooth.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\UnDot.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\UnFilter.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\VSFilter.dll")
12:10:24 LoadPlugin("C:\automkv\exe\filter\warpsharp.dll")
12:10:24 #loadpluginstart
12:10:24
12:10:24 #test1
12:10:24
12:10:24 Import("C:\automkv\exe\filter\HybridFuPP.avsi")
12:10:24 Import("C:\automkv\exe\filter\LanczosPlus.avsi")
12:10:24 Import("C:\automkv\exe\filter\Lem.avsi")
12:10:24 Import("C:\automkv\exe\filter\LimitedSharpenFaster.avsi")
12:10:24 Import("C:\automkv\exe\filter\MCBob_v03c.avsi")
12:10:24 Import("C:\automkv\exe\filter\mvbob.avsi")
12:10:24 Import("C:\automkv\exe\filter\seesaw.avsi")
12:10:24 Import("C:\automkv\exe\filter\spresso.avsi")
12:10:24 #importstart
12:10:24
12:10:24 #test2
12:10:24
12:10:24 movie = directshowsource("C:\01(xvid).mkv",fps=23.976044,convertfps=true,audio=false)
12:10:24 movie = isRGB(movie) ? ConvertToYV12(movie,interlaced=true) : movie
12:10:24 movie = isYUY2(movie) ? ConvertToYV12(movie,interlaced=true) : movie
12:10:24 function getOrder(clip c) {
12:10:24 order = GetParity(c) ? 1 : 0
12:10:24 Return order }
12:10:24 #filter1start
12:10:24
12:10:24 #test3
12:10:24
12:10:24 #resizestart
12:10:24
12:10:24 #test4
12:10:24
12:10:24 last = movie
12:10:24 #filter2start
12:10:24
12:10:24 #test5
12:10:24
12:10:24 RemoveGrain(mode=2)
12:10:24 Script mkvmaudio.avs
12:10:24
12:10:24 DirectShowSource("C:\01(xvid).mkv",fps=23.976044,convertfps=true,video=false)
12:10:24 #Applying STEREO downmixing routines
12:10:24 function stereo(clip a)
12:10:24 {
12:10:24 flr = GetChannel(a, 1, 2)
12:10:24 fcc = GetChannel(a, 3)
12:10:24 lfe = GetChannel(a, 4)
12:10:24 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071)
12:10:24 mix = MergeChannels(lfc, lfc)
12:10:24 lrc = MixAudio(flr, mix, 0.2929, 1.0)
12:10:24 blr = GetChannel(a, 5, 6)
12:10:24 Return MixAudio(lrc, blr, 1.0, 0.2929)
12:10:24 }
12:10:24 #
12:10:24 6==Audiochannels() ? stereo() : last
12:10:24 Normalize()
12:10:24 Soundout(output="mp3",type=0,format=0,autoclose=true,mode=1,abrrate=160,showoutput=false,filename="audio.mp3")
12:10:24 Script mkvmaudio.bat
12:10:24
12:10:24 "C:\automkv\exe\BeSweet\vdub.exe" /x "C:\Encode\temp\mkvmaudio.avs"
12:10:24 Script mkvmaudio2.avs
12:10:24 Script mkvmaudio2.bat
12:10:24
12:10:24 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - -
Old 22nd May 2007, 18:44   #2197  |  Link
buzzqw
HDConvertToX author
open movie.avs in virtualdub
any errors ?
also post the first part of log file
BHH
buzzqw is offline
Old 22nd May 2007, 19:54   #2198  |  Link
wallstreetcrash
Thanks, so no 5.1 with WMV
My source video size was 1280x720, and left the resolution to original, but it came out as 1280x707.
Here it is from the log:
10:24:40 Selected Slice: 1
10:24:40 Selected Profile: WVC1_1_Pass_CBR.xml
10:24:40 Selected Width: Original
10:24:40 Selected Resizer: NONE
10:24:40 Selected Filters: NONE
10:24:40 Selected Deinterlacer: AUTO
10:24:40 Selected Field Order: AUTO
10:24:40 Enabled CRF/CQ AutoRes at 90 value
10:24:44 Aspect ratio: 1.778
10:24:44 Number of Frames: 84531
10:24:44 Framerate: 25.000
10:24:44 Movie length in Seconds: 3382
10:24:44 Movie Width/Height: 1280/720
Hope you can help.
P.S. How do you check framerate of wmv files?
Old 22nd May 2007, 21:34   #2199  |  Link
TheRyuu
warpsharpened
The update thing I just put there because I changed around with the script a little bit. Instead of putting SetMTMode(2) and then closing it at the bottom with SetMTMode(0), and wrap the individual filters with MT().
Instead I decided to try just putting SetMTMode(2, 0) in the beginning and not closing it out. That way, everything below the SetMTMode gets multi-threaded, even if you use filters through AutoMKV (which previously didn't work).
If your finding it confusing then just skip MT all together. It's unstable and can crash (often, but I'm trying around with different scripts, older ones, newer ones, they all seem to crash eventually, I just pick the one that crashes the least).
There's a funny story to this too. I was encoding a hour long movie with a pretty complicated avisynth script. Took an hour for the first pass, and was ~95% done with the second pass (which had been running for a few hours), then it crashed on me .
The speed improvment really isn't that great. At most your shaving off a few minutes on simple scripts, maybe a little more on more complicated ones.
TheRyuu is offline
Old 23rd May 2007, 07:04   #2200  |  Link
buzzqw
HDConvertToX author
actually no. sorry
please open the movie.avs script... there is any resizers or crop ? i don't think so...
if you open your video with mediainfo/gspot.. what resolution is reported ?
i use avisynth to get video info values
BHH
buzzqw is offline
