30th March 2020, 16:40 | #23841 | Link | |
Posts: n/a
3rd April 2020, 12:40 | #23843 | Link |
I updated AMD Driver to 20.4.1 for my RX 5700 and when playing this file - https://4kmedia.org/lg-chess-hdr-demo/ I get about 90 dropped frames right at start of playback. I think this was introduced with AMD driver update to 20.4.1
I use MPC-BE v1.5.5 build 5165 with madVR 0.92.17 and LAV Filters 0.74.1-34. If I disable/block external LAV Filters completey in MPC-BE and use its internal filters it is fine. So I think AMD changed anything related in Driver which is causing this behavior in LAV Filters. If you need any further info, let me know. |
6th April 2020, 12:42 | #23844 | Link |
guys i'm not sure if it's the right place to post but is it possible for lav filters's developer to develop an import plug-in for adobe premiere pro? (works on adobe media encoder too)
9th April 2020, 19:12 | #23847 | Link |
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
9th April 2020, 19:35 | #23848 | Link | |
we premiere pro users need something new & great like lav filters for premier pro cc. Last edited by PCU; 9th April 2020 at 19:38. |
15th April 2020, 11:10 | #23849 | Link | |
I'd like someone to review a certain file encoded with x265. Or encoder settings.
File: https://mega.nz/file/5qoBFIqS#c_OjQO...gHok4ZEsHHdiiU The problem: I'm getting very bad fps - 15-20 instead of 24. Changing settings in LAV Video didn't help. Switching to ffmpeg decoder helped. Here is how it was encoded: Quote:
I'd like to know why switching to FFmpeg solves the fps issue, and what can be done with LAV to work better with this case. Hw acceleration is still disabled in both decoders from what I see. Also, any comments about encoding settings are welcome. Last edited by Liandri; 15th April 2020 at 11:13. |
15th April 2020, 16:42 | #23850 | Link |
Hi!
Probably a stupid question, but how do I verify if the MVC codec is successfully installed. If there's any visual feedback it's too fast for me to see. Any way to test if it's working without a 3d screen? (So I can get it working by the time the screen is acquired.) |
16th April 2020, 09:07 | #23856 | Link | |
(Whether I can get it to work with an actual 3d display remains to be seen.) |
28th April 2020, 23:59 | #23859 | Link |
Hey nev,
I've recently run into this problem. I have a few foreign files that have the ENG SDH subtitle as 1, and the regular ENG subtitle as 2. The relevant part of my advanced config is this, basically when there's no ENG audio then load ENG subtitles (the last step there): eng:eng|f eng:0ff *:eng So what I get is subtitle 1, the SDH one. I would like the splitter to choose the regular ENG, e.g. subtitle 2. Would it be possible, in the Lav Splitter configuration, to incorporate a button placed beneath the "Prefer Audio Streams for the Hearing/Visually impaired" called something like "Disable/Remove Audio Streams for the Hearing/Visually impaired"? If that is possible to code, obviously. Would be great. Or if you have other suggestions on how to solve this issue, the post I found was from 2015 and to be honest I have not read through the whole thread, it's a lot of posts. Thanks.
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 Last edited by Xaurus; 29th April 2020 at 00:26. Reason: clarification |
29th April 2020, 00:57 | #23860 | Link |
Since you are already using the advanced rule, there is a flag for hearing impaired subtitles, "h", so you could change yours to this:
eng:eng|f eng:off *:eng|!h That way you'll never get SDH subtitles - if they are flagged properly. Or as an alternative also add the *:eng at the end, so that it can use the SDH subtitles if no others are available at all. Although i'm not sure if MKV for example can flag SDH subtitles as such. I know that MPEG-TS has that for broadcast..
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 29th April 2020 at 01:03. |
