6th October 2018, 21:08 | #53021 | Link | |
Is this for real?
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED |
7th October 2018, 00:05 | #53022 | Link |
Thanks just switched it back, but still stuttering unfortunately. Also tried the clean driver installation which fixed some other gaming related problems but not the stuttering.
Does anyone know if Nvidia game overlay or Xbox game bar can cause any issue with MadVR when enabled? |
7th October 2018, 00:15 | #53023 | Link |
You need to look at your clocks. You say the performance is fine when you lower your settings.. I think that's your answer right there. Post your OSD, ideally with both the problematic settings and slighter lower settings that work well also but look at taskman/gpu-Z etc. Asmodian can confirm if your settings for that content yield the same results.. FYI NGU very high can be extremely demanding.
7th October 2018, 04:33 | #53024 | Link | |
I see ~35ms rendering times with 720p -> 2160p at full crazy settings.
chroma: NGU very high luma: NGU very high -> very high -> SSIM1D LL chroma: NGU med -> low Every upscaling refinement option enabled except SuperRes. ED1 dithering, no smooth motion, no artifact removal options, and no trade quality for performance options. With all artifact removal options enabled I start seeing dropped frames and I am just on the edge, but not dropping frames, with only reduce random noise disabled (23.976 fps). At my normal settings I get ~17.5ms rendering times. I did this testing at stock settings (1950 MHz), except the power limit has been doubled with a hardware mod. I don't think this has a big impact on madVR but it might have some. madVR also really likes a memory overclock so I get quite a bit better performance with an overclock. Quote:
edit: Hmm, I am not sure about the game bar, I was thinking about "game mode".
madVR options explained Last edited by Asmodian; 7th October 2018 at 04:53. |
7th October 2018, 06:43 | #53025 | Link |
First time I've had my 1060 in the open right whilst playing video and noticed NGU AA very high making the GPU chirp away high is a lot less noticeable than very high.
Wonder if there's any cards that don't do this.. I got a Gigabyte G1 Gaming 6GB. |
7th October 2018, 08:03 | #53027 | Link |
Posts: n/a
Right now I use fully updated Windows 10 x64 1607-14393 LTSB for OS and I used NTLite free demo/edition to cleanly and surgically remove Game Bar + all related bloatware. I have ZERO issues with madVR, playback and games. But 1607 is getting old and 1809 LTSC is out. Has anyone tried it (as a fresh OS install) with madVR? Any issues with reported frame skippage, etc?
7th October 2018, 13:21 | #53029 | Link | |
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
7th October 2018, 16:22 | #53031 | Link |
The fan is likely hitting higher speeds. A higher GTX would probably complain less about very high. I am using very high with a GTX 1050 Ti at 1080p. Using a custom fan profile in MSI Afterburner keeps the fan at idle, so very high is putting a lot of stress on the GPU, but it isn't getting as hot as I would expect.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 7th October 2018 at 17:16. |
7th October 2018, 16:23 | #53032 | Link |
Haven't seen it. Try reducing other settings. The load could be becoming too heavy.
7th October 2018, 16:49 | #53034 | Link |
Is it a 4K source?
7th October 2018, 16:53 | #53035 | Link | |
i even stopped the CPU fan to make sure. |
7th October 2018, 17:11 | #53037 | Link |
Weird. I'd have to check to see if I notice any odd spikes.
7th October 2018, 19:15 | #53040 | Link |
any ideas why the picture changes to black and white for me as soon as I set "highlight recovery strength" to anything else than 'none'?
