Old 12th December 2006, 20:19   #41  |  Link
Koti
Always trying
Koti's Avatar
Originally Posted by Romario View Post
I don't know why Intel want money for this.
If this package become freeware, then devs can optimize their programs and codecs for Intel Core 2 architecture MUCH EASIER.
you could always buy the libraries for x264 dev's
Koti is offline   Reply With Quote
Old 12th December 2006, 20:38   #42  |  Link
Romario
Romario's Avatar
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
Yes, but I can't.
Live long and prosperLive long and prosperLive long and prosper
Romario is offline   Reply With Quote
Old 12th December 2006, 20:44   #43  |  Link
KoD
Because Intel is not making money only from selling Core2 Duo processors. They are actually producing more hardware and software than just cpus for personal computers.
KoD is offline   Reply With Quote
Old 12th December 2006, 21:51   #44  |  Link
Romario
Romario's Avatar
Certainly, but...
If someone decide to make pressure on Intel software division, who knows what can happen?
Old 13th December 2006, 03:18   #45  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
It's like asking M$ to make Windows OpenSource...
and however x264 has ASM optimizations that maybe are even faster than intel libs...
Old 13th December 2006, 03:30   #46  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
faster, really? is that because they are done by hand? But I thought that x264 hadn't been all the way optimized yet.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 13th December 2006, 04:27   #47  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Hand optimizations are always better than third party libs (that work well only on certain scenarios), also qualitywise x264 is as fast if not faster than commercial h.264 encoders... so how can you say it's not optimized?
Maybe there could be further speed optimizations but it's already quite fast.
Old 13th December 2006, 04:41   #48  |  Link
Adub
Adub's Avatar
I thought that Ateme blew it out of the water, maybe not in terms of quality, but speed wise. Maybe I am just hearing voices again.
Also, I ask about hand optimizations because I am interesting in learning to program and speed is a fetish. Ha!
Site:Adubvideo
Old 13th December 2006, 10:17   #49  |  Link
imcold
pencil artist
imcold's Avatar
so, learn about programming. It's fun and it doesn't hurt - allright, debugging can be very frustrating, but the bigger will be your joy after you finnaly manage to make the code behave the way you want.
Large programs are broken into smaller parts: functions. When you want to make your program run faster, you search for the functions that are most computationally intensive and then you find a better (faster) algorithm for it, you rewrite it in assembly, or very often both. Compiler may not generate the best assembly code for your function -it's just a program, not thinking being- in contrast with creator of the code, who is perfectly aware of what the function is supposed to do. Optimalizations (most of the time?) take advantage of SIMD (single instruction - multiple data) instructions: MMX, 3DNow!, SSE1/2/3 aso. They are kind of... parallel processing instructions, they provide huge speedup if properly used. X264 has plenty of optimized functions. It's kind of complicated for compiler to rewrite your function into SIMD instructions. So is for humans... but humans are intelligent, thinking beings, and creative too. You can find out an algorithm, that would work much better in SIMD. Compiler sort of... can't. That's why I believe humans will always (or for a very long time) be better for optimizing.
Also, about optimizing for some CPU - under this I understand using instructions that suit the CPU is best at: be it 3DNow for (old?) amds, SSE2 for core2, 64-bit instructions for 64bit processors on 64-bit OS etc. So in my eyes x264 is pretty much optimized for core2. Also I admire the programmers that take part in developing our beloved oss encoders and find them very skilled and inteligent (and I am most thankful for their work); I doubt that Intel's optimized code would be significantly faster - IF it would be faster at all.
sorry if this was kind of boring reading (also corrections welcomed). I also think that x264 is very fast taking it's complexicity (that makes me dizzy) into consideration (hey, it got faster by >30% during 2006 according to my tests). Big thankyou for the devs.
imcold is offline   Reply With Quote
Old 13th December 2006, 13:48   #50  |  Link
pgb
Friendly Coder
Hear, hear, imcold!
Anyone wanting to learn more about real programming and squeezing the most out of those clock cycles could do worse than read Don Knuth's magnum opus:
http://www-cs-faculty.stanford.edu/~knuth/taocp.html
And I'd like to add my thanks to the X264 developers too.
Happy holidays, everyone!
pgb is offline   Reply With Quote
Old 13th December 2006, 15:17   #51  |  Link
Adub
Adub's Avatar
Thanks guys! I will give them a read when I have the time.
Site:Adubvideo
Old 13th December 2006, 16:56   #52  |  Link
dancho
if you wanna learn more check this links:
Software optimization resources :http://www.agner.org/optimize/
Assembly Optimization Tips : http://www.mark.masmcode.com/
dancho is offline   Reply With Quote
Old 21st December 2006, 15:10   #53  |  Link
Inventive Software
Turkey Machine
Got a suggestion. Bear with me.
The progress indicator only updates every (total frames / 1000), thus for a 100000 frame movie, it updates every 100 frames. This is a little slow with some resolutions, so why not have it update the progress every frame and not by percentage? The current percentage could then go down to 2dp or 3dp instead of 1dp to accomodate the longer encodes, and be calculated each frame.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 21st December 2006, 23:10   #54  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
You can get something like that if you enable verbose mode.
check is offline   Reply With Quote
Old 26th December 2006, 18:30   #55  |  Link
chadamir
Sorry if this crosses over into feature request territory, but in the advanced dvd authoring forum we've been discussing codecs that are hd-dvd compliant. X264 is not. Some minor header changes need to be made to conform to spec. Is this being worked on? Fantastic work otherwise, certainly my choice for pc backups.
Heres the thread: http://forum.doom9.org/showthread.php?t=119392&page=4
chadamir is offline   Reply With Quote
Old 27th December 2006, 02:49   #56  |  Link
akupenguin
x264 developer
akupenguin's Avatar
No. I am not interested in HD-DVD or any other application that adds requirements beyond the H.264 standard for no good reason.
Old 27th December 2006, 04:16   #57  |  Link
chadamir
But aren't the two data structures in the reference encoder?
Old 27th December 2006, 09:07   #58  |  Link
akupenguin
x264 developer
akupenguin's Avatar
You tell me. Can you make an HD-DVD compliant stream using JM? Does anyone even know what the constraints are?
Old 27th December 2006, 10:05   #59  |  Link
chadamir
I guess the people on the forum who have the specs know. I do know JM supports those data structures which were said to be needed by those who have the specs. I thought JM only outputs avi and I have a feeling demuxing would ruin it.
Old 27th December 2006, 10:32   #60  |  Link
Manao
No. They have only a vague idea of what some of the constraints may be. Those who effectively have the specs are most probably under NDA and can't disclose them ( CF : http://forum.doom9.org/showthread.ph...932#post882932 )
Manao is offline   Reply With Quote
coding, development, x264 dev
