8th April 2006, 02:32 | #21 | Link |
I hope this link will be considirated as corelative (not like crossposting) http://forum.doom9.org/showthread.ph...697#post810697
9th April 2006, 02:26 | #22 | Link | |
x264 developer
7th June 2006, 08:28 | #23 | Link |
I am trying to compress (2 pass, sharktooth's x264 530 - on the HQ-Insane profile, and 2000 kbps) a HD 720p movie (1280x528 @ 23.976 - a little cropped, it's widescreen) from wmv content.
I am running the first pass, as so: H:\Movies>x264.exe --f ps 23.976 --pass 1 --bitrate 2000 --stats "H:\Movies\[......] 16x9 72 0p WM9 HD-DVD.stats" --bframes 3 --b-pyramid --filter -2,-1 --subme 1 --analyse none --direct auto --me dia --cqmfile "C:\Codecs\x264\Matrices\eqm_avc_hr.cfg" --progress --no-psnr --output NUL "H:\Movies\[.........] 16x9 720p WM9 HD-DVD.avs" x264 [info]: file name gives 16x9 avis [info]: 1280x528 @ 23.98 fps (181032 frames) x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2 3DNow! and it finally ends up writing this (you can see, not ALL the frames were written to the .stats file) encoded frames: 180851/181032 (99.9%), 10.24 fps, eta 0:00:17 H:\Movies> Now, as I call pass 2 with all the other options enabled, it throws out this error: x264 [error]: 2nd pass has more frames than 1st pass (181032 vs 180999) x264_encoder_open failed I am using the same x264 commandline as the latest MeGui or StaxRip 0.9.9.2, in fact this first occured while trying to compress through MeGui, x264 HQ-Insane, then I wrote the commands on my own into the console, trying to figure out what I should change - no success. StaxRip 0.9.9.0 had the same difficulty (with Sharktooth's x264 build 467 if I remember well) I tried to trim the movie from the avs script, cutting until that last frame encoded into the .stats file , so pass 2 worked. However, though x264 said "23.98 fps", as I took a part of the encoded movie and muxed it into mp4 (latest mp4box), BSPlayer recognized it as 25 fps. (?) The aac encoded is perfectly synched with the source wav from the wmv, BUT the encoded x264 movie (even from minute 3) seems to be earlier I think than the wmv. (???) why.. This happened before I ran x264 with --fps 23.976 - but I don't think it made a difference since it recognized it anyway as 23.98. |
7th June 2006, 20:42 | #24 | Link | |
Try to disable every filtering before launching your avs script. |
8th June 2006, 09:42 | #25 | Link |
Mr. Sandman
this is the dev thread and it has nothing to do with those kind of questions...
8th June 2006, 19:04 | #27 | Link |
Mr. Sandman
yes, sorry, i was a bit too drastic.
8th June 2006, 21:25 | #28 | Link | |
(note: have lastest ffdshow-2546-gcc4.0.3-sse2-x264) I had "Dolby Surround Downmix" on at audio processing plugins to be loaded automatically, but don't know if it's to blame, unchecked it anyway. (oh, and "subtitles" was also ticked for automatic loading in ffdshow at video decoder config). I also have 'Avisynth' ticked at the video decoder config... hmm It's suppose to bring ffdshow filters into avisynth. I left it on. Is there anything else I should be doing ? I'll get back to you after running the first pass. Thanks |
13th June 2006, 09:24 | #30 | Link | |
Does it really matter?
2nd October 2006, 16:19 | #31 | Link |
Please forgive me (and be kind) if these are braindead questions (consider the source):
I'm trying to determine what the output file format is for the various apps wrapping the codec, specifically under Windows. Obviously the DirectShow AVI filter wraps the data in an AVI file format. But does the command line application use another file format? Which one(s)? And is it true that the h.264 standard file format is Quicktime (MOV)? Xesdeeni |
2nd October 2006, 18:43 | #33 | Link |
indeed, there are three:
1) .mp4 2) .mpg 3) .ts
3rd October 2006, 18:47 | #37 | Link |
yep, i meant PS with .mpg
12th December 2006, 15:46 | #38 | Link |
Location: Qetchua mountains in Peru, and Klingon battlecruiser D'Mar
Look at this, can anyone confirm that devs read this.
http://www3.intel.com/cd/software/pr...eng/219766.htm
Live long and prosperLive long and prosperLive long and prosper |
12th December 2006, 19:39 | #40 | Link |
I don't know why Intel want money for this.
If this package become freeware, then devs can optimize their programs and codecs for Intel Core 2 architecture MUCH EASIER.
coding, development, x264 dev |
