Old 13th November 2004, 05:10   #481  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
I did a IfoEdit split and it seems there is difference in parsing the IFO between IfoEdit and PgcEdit. Here's what I have for disc Title 1.
In Ifoedit, I have Chapter 1 with Program 1.
VTS overview:
PGC_1 (program chain): [Title(TTN): 1] [00:50:22.07 / 30 fps] (Programs: 12) (Cells: 12) (uses VOB-IDs: 1)
  [Ch 01] [Pg 01] [Cell 01] [V/C Id:  1/17]
  [Ch 18] [Pg 02] [Cell 02] [V/C Id:  1/18]
  [Ch 19] [Pg 03] [Cell 03] [V/C Id:  1/19]
  [Ch 20] [Pg 04] [Cell 04] [V/C Id:  1/20]
  [Ch 21] [Pg 05] [Cell 05] [V/C Id:  1/21]
  [Ch 22] [Pg 06] [Cell 06] [V/C Id:  1/22]
  [Ch 23] [Pg 07] [Cell 07] [V/C Id:  1/23]
  [Ch 24] [Pg 08] [Cell 08] [V/C Id:  1/24]
  [Ch 25] [Pg 09] [Cell 09] [V/C Id:  1/25]
  [Ch 26] [Pg 10] [Cell 10] [V/C Id:  1/26]
  [Ch 27] [Pg 11] [Cell 11] [V/C Id:  1/27]
  [Ch 28] [Pg 12] [Cell 12] [V/C Id:  1/28]
Parsing the same IFO with PgcEdit, I have Chapter 17 with Program 1.
VTST 1 , 1   TTN 1  (50:22)  Title 1 - Chapters: 28,  Programs: 12,  Cells: 12
 Chap. Prog. Cell  Type  Layer Res-  Still Cell  Playback     End          Entry    First    Last     Last     VOB Cell
 (PTT)             Flags Break tric- Timel Cmd.  Time         Time         VOBU     ILVU     VOBU     VOBU     ID  ID
                               ted.                                        sector   End      Start    End
 17    1     1     2     yes   no    0     0     00:10:03.07  00:10:03.07  0        0        166344   166504   1   17
 18    2     2     8     no    no    0     0     00:05:21.04  00:15:24.11  166505   0        254288   254471   1   18
 19    3     3     8     no    no    0     0     00:02:38.18  00:18:02.29  254472   0        300865   301083   1   19
 20    4     4     8     no    no    0     0     00:07:25.05  00:25:28.04  301084   0        464608   464816   1   20
 21    5     5     8     no    no    0     0     00:02:36.26  00:28:05.00  464817   0        519347   519574   1   21
 22    6     6     8     no    no    0     0     00:02:09.21  00:30:14.21  519575   0        567889   568152   1   22
 23    7     7     8     no    no    0     0     00:04:49.10  00:35:04.01  568153   0        669977   670158   1   23
 24    8     8     8     no    no    0     0     00:01:00.29  00:36:05.00  670159   0        697578   697820   1   24
 25    9     9     8     no    no    0     0     00:03:36.09  00:39:41.09  697821   0        785766   786199   1   25
 26    10    10    8     no    no    0     0     00:03:52.25  00:43:34.04  786200   0        873243   873537   1   26
 27    11    11    8     no    no    0     0     00:01:39.03  00:45:13.07  873538   0        910117   910263   1   27
 28    12    12    8     no    no    0     0     00:05:09.00  00:50:22.07  910264   0        1027423  1027490  1   28
I did 3 playback tests.
IfoEdit: Shows Chapter 1 for my first chapter, 18 for my second
PowerDVD: Same as IfoEdit
Sony standalone: Same as IfoEdit
What's going on with PgcEdit?
2COOL
Old 13th November 2004, 06:06   #482  |  Link
lamster
Suggestion:
If the currently-selected command is other than a Jump or Link command, and Ctrl+J is pressed, move the selection to the next following Jump or Link command.
This will let you step through simple navigation sequences just by repeatedly pressing Ctrl+J.
lamster is offline   Reply With Quote
Old 13th November 2004, 07:40   #483  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Originally posted by 2COOL
@r0lz
Bug?
I have a PGC with one program and holding a VOB/ Cell ID of 2/1.
VTST 1 , 1   TTN 1  (9:02) - Chapters: 1,  Programs: 1,  Cells: 1
********** pre commands:
********** post commands:
********** cell commands:
 Playback time:  00:09:02.04 (at 30 fps)
 PG Playback mode:  sequential
 PUOs:           0 (0x00000000)
 NextPGCN:       3
 PrevPGCN:       0
 GoUpPGCN:       0
 PGC Still Time: 0
 Audio  stream  1 status: 0x00008000 (stream=0)
 Audio  stream  2 status: 0x00008100 (stream=1)
 Subpic stream  1 status: 0x80000000 (streams for 4:3=0, wide=0, letterbox=0, pan&scan=0)
 1     1     1      2    no    no    0     0     00:09:02.04  00:09:02.04  29855    0        212886   213093   2   1
When I select to change this to 1/1 in PGC Editor dialog, my number of Programs has increased. I should still have a single program here.
VTST 1 , 1   TTN 1  (1:18) - Chapters: 1,  Programs: 2,  Cells: 1
 Playback time:  00:01:18.07 (at 30 fps)
 NextPGCN:       3
 PrevPGCN:       0
 GoUpPGCN:       0
 PGC Still Time: 0
 1     1     1      2    no    no    0     0     00:01:18.07  00:01:18.07  0        0        29705    29854    1   1
This is a bug, but it is ONLY in the 0.4.0 beta release you tested for me. It is fixed now.
Also, you have a typo in your PGC dump
"Still Time1" should be "Still Time"
Fixed.
r0lZ
Old 13th November 2004, 07:53   #484  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
In fact, both are right. After your IfoEdit split, in disk 2, the chapters 1 upto 17 are assigned to the same cell (the first one). So, the correct display should be:
1->17    1     1     2     yes   no    0     0     00:10:03.07  00:10:03.07  0        0        166344   166504   1   17
Of course, I don't have enough place in the GUI to list all chapters. So, I display only the last one. IfoEdit displays the first one. Both are right.
[EDIT:] Since most standalone players will probably display the first chapter, I've changed this. PgcEdit now displays the first chapter assigned to the cell.
r0lZ
Old 13th November 2004, 07:58   #485  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
Originally posted by lamster
Suggestion:
Hummm. This is not a bad idea, but I think it may be somewhat strange to see the selection jump to another place without a real reason.
And, as v 0.4 will have a Trace function that will allow to follow the flow verry easily, I don't think I will implement your idea. Sorry.
Stay tuned right here: v0.4.0 is ready, and will be released today or maybe tomorrow...
r0lZ
Old 13th November 2004, 17:58   #486  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
PgcEdit 0.4.0 released!
Please post everything related to v0.4 in this thread.
r0lZ
Old 14th November 2004, 15:54   #487  |  Link
lamster
Well, the "real reason" is pressing Ctrl+J when something that's not a Jump is selected.
My initial thought was to automatically select the first line whenever a PGC was opened, and to automatically select the first jump or link if you entered by following another jump or link, but I thought that might be too strange for those not trying to trace.
OK, I'll take a look at that.
