Old 20th March 2013, 21:39   #21  |  Link
sl1pkn07
Pajas Mentales...
the version of ffmpeg is 1.1.3
sl1pkn07 is offline   Reply With Quote
Old 20th March 2013, 21:48   #22  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
I think the current any ffmpeg Major Release doesn't help you.
The latest L-SMASH Works requires The Evil Plan.
僕と契約して、L-SMASH developerになってよ!
L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software
VFR maniac is offline   Reply With Quote
Old 20th March 2013, 22:17   #23  |  Link
sl1pkn07
Pajas Mentales...
the evil plan? xd
Old 20th March 2013, 22:21   #24  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
The reference counter which is the new feature of ffmpeg/libav API is called The Evil Plan.
Old 20th March 2013, 22:27   #25  |  Link
sl1pkn07
Pajas Mentales...
oh, ok, I thinking The Evil Plan is a internet meme XDD
Old 21st March 2013, 07:59   #26  |  Link
burfadel
Originally Posted by VFR maniac View Post
I don't know your old AVI files.
The new rev 501 doesn't exhibit this behaviour.
Out of curiosity, what number threads are used by default when none are specified, is it equal to the number of cores, a fixed value (such as 2 or 4), or is it just 1 by default?
Old 21st March 2013, 23:14   #27  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
The number of cores + 1.
This is the default value libavcodec does.
The maximum value is 16.
According to libavcodec/pthread.c,
/* H264 slice threading seems to be buggy with more than 16 threads,
* limit the number of threads to 16 for automatic detection */
Old 22nd March 2013, 04:10   #28  |  Link
qyot27
qyot27's Avatar
What steps should be taken to get the AviSynth plugin built? Because my test builds only worked if I set it on Debug, not Release, and it was only the LWLibav..Source functions that output anything. LSMASH..Source caused Access Violations (which may be because I had the dependencies wrong, or something got screwed up in the .sln/.vcproj conversion*).
*I used VS2010, not VS2008. Unless it's actually caused more by the use of Express than which incremental version of Visual Studio it was.
Old 22nd March 2013, 05:10   #29  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Oh... I didn't notice that.
On Release build, I also get a crash for audio source filter on AviUtl loading AVS.
I still don't get what causes that.
I'm using TDM GCC 4.7.1-dw2 (tdm-1) + MSVC9 Express Edition.
Old 22nd March 2013, 07:23   #30  |  Link
qyot27
qyot27's Avatar
Ah, perhaps it was in the GCC build then, as I was using Komisar's (among other things, it uses sjlj, not dw2).
Old 22nd March 2013, 07:33   #31  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
The crash goes away when I disable /GL on MSVC9.
I don't get still why.
Old 22nd March 2013, 10:48   #32  |  Link
qyot27
qyot27's Avatar
Ok, I did manage to get Release to generate a build that can use both LWLibav..Source and LSMASH..Source, but it may have been at the cost of making it much closer to a Debug build (and the file size reflects it: the normal 'Release' build was ~6 MB, and the normal 'Debug' build was ~9 MB...the adjusted Release build that works is 9.07MB). I'll have to do some more trial-and-error and see exactly which option(s) fixed it.
Old 22nd March 2013, 13:33   #33  |  Link
qyot27
qyot27's Avatar
Following up again, it seems that the offending option was /OPT:REF. Setting /OPT:NOREF makes Release builds work for me, even with /GL and /LTCG enabled. My guess is that /OPT:REF was pruning stuff out of the .dll that it shouldn't have (as that's what the documentation makes it sound like it does), and therefore causing the crashes and Access Violations. The resultant build size is a more modest 7MB or so. Probably could be reduced further, since the FFmpeg build used wasn't the type of minimal compile I use for FFMS2 (I'd also neglected to enable avresample since I actually built it to verify whether it still wanted to crash with the new AviSynth demuxer when built with MSVC...thankfully, it works fine).
LSMASHSource r507
It's been optimized for SSE. Built with VS2010.
Further notes on building:
MinGW-w64's supplied version of libmingwex.a has incompatibilities with MSVC
Use the non-w64 version of the tdm toolchain to build L-SMASH
Build FFmpeg with MSVC as roughly outlined here: http://ffmpeg.org/platform.html#Microsoft-Visual-C_002b_002b
One thing to note is that the c99-to-c89 wrapper should be version 1.0, not version 1.0.1 (unless you want to compile 1.0.1 yourself with Clang, I guess) - the distributed binaries of 1.0.1 have their permissions screwed up somehow and error out with 'Bad file number'. The 1.0 binaries are fine.
Both Debug and Release:
Remove libmingwex.lib from Source Files (select 'Remove' from LSMASHSource project)
Configuration Properties -> VC++ Directories
Add the GCC lib/includes, MinGW lib/includes, and in my case, locally-installed FFmpeg & L-SMASH lib/includes
Append the following directories to the end of their respective lists:
C:\MinGW\tdm-mingw\lib\gcc\mingw32\4.7.1\include
C:\MinGW\tdm-mingw\include
C:\MinGW\home\username\win32_build\include
C:\MinGW\home\username\win32_build\lib
Configuration Properties -> Linker -> Input
Append the following .a files to the end of the list.
Additional Dependences: libmsvcr100.a;libmingwex.a;libmingw32.a;libws2_32.a;libwsock32.a
Ignore Specific Default Libraries: libcmt.lib
'Release' build specific:
Configuration Properties -> Linker -> Debugging
Generate Debug Info: No
(There's no point to the 'Release' build generating Debug info, IMO)
Configuration Properties -> Linker -> Optimization
References: No
Old 24th March 2013, 05:38   #34  |  Link
qyot27
qyot27's Avatar
Partial support for building the VapourSynth plugin for Linux (maybe OSX, but that's completely untested here):
Fix permissions on configure
Linux compilation support
It just took some adjusting of configure and GNUmakefile; the shared object settings were derived from what the FFMS2 C-plugin does when compiling. 'Partial' because the install rules are still missing, but it does generate a valid .so that Linux-native VapourSynth can use. Windows use needs to be tested to make sure nothing broke, even though compilation still succeeds.
...and I just now realized I hadn't shifted the LDFLAGS section's if block from 'MINGW' to 'WIN32'.
Old 24th March 2013, 13:41   #35  |  Link
sl1pkn07
Pajas Mentales...
thanks qyot27!
what version of ffmpeg/libav you use?
Old 24th March 2013, 18:24   #36  |  Link
qyot27
qyot27's Avatar
I was using ffmpeg-git.
Old 20th April 2013, 22:13   #37  |  Link
Selur
Selur's Avatar
btw. does anyone know if 10 bit precision input support is planned, atm. (r561) High10 content throws
Avisynth open failure:
LWLibavVideoSource: yuv420p10le is not supported
Old 22nd April 2013, 19:53   #38  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Did anyone test this patch on OSX?
I don't have any experience about high bit depth on AviSynth.
Patches welcome: Issue 15.
Use vslsmashsource.dll instead, for a while.
Old 23rd April 2013, 00:59   #39  |  Link
qyot27
qyot27's Avatar
I just did, because I finally got around to getting VapourSynth set up on the OSX machine I have access to. It does build, and both LWLibavSource and LibavSMASHSource work as expected. However, due to the way that the output of git rev-list and wc is on OSX, the REV info needed to be fixed up a little by inserting sed into the command.
Revised patch here:
https://gist.github.com/qyot27/5439568
Old 24th April 2013, 01:57   #40  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
OK. Applied.
Thanks for your contribution.
