23rd December 2006, 16:39 | #402 | Link |
i don't either have office installed at all
@mannuse i followed the instructions that you gave but nothing happens so i'll also wait for another fix version thanks in advance [edit] no sorry wait it worked i just confused the versions
it's one thing that i know for sure, that i know nothing for sure (Plato, ancient Greek Philosopher) Last edited by clickit; 23rd December 2006 at 16:41. Reason: run the wrong version |
24th December 2006, 10:24 | #406 | Link |
i installed Setup_SubtitleCreator_v2_1b3.exe and tried Tools->Manipulate SUP ...
i opened and .idx file made a change and tried to save on the same .idx file i got this error thanks in advance p.s. is there a chance subtitlecreator to support convertion from .sup or idx/sub or directly from DVD to .srt format error.txt |
24th December 2006, 11:09 | #407 | Link |
SubtitleCreator's Co-Dev
I can't read your attachment yet as it is not approved but I would advice you use another name for the output file. You can convert a .sup or .sub/.idx to srt using the Tools -> Recognize text using OCR function. It will use Office 2003's embedded OCR. So you need to have Office 2003 (or later?) installed on your PC. Cheers Manusse |
24th December 2006, 13:05 | #408 | Link |
hi manusse,
and what if someone don't have office installed at all, like me is there any workaround for builtin OCR to work ? something like a package of needed libraries to be self-registered ???
it's one thing that i know for sure, that i know nothing for sure (Plato, ancient Greek Philosopher) |
24th December 2006, 14:43 | #410 | Link |
i've allready done this but DVDSubEdit's OCR unfortunately produces unreadable greek characters
24th December 2006, 15:21 | #412 | Link |
i was expecting your tip about subrip
it makes fine .srt files but with some letters it produces double characters, one letter and one space right after it like O, it OCRs "O" but produces "O " maybe i have something wrong in my matrices thanks for your time
it's one thing that i know for sure, that i know nothing for sure (Plato, ancient Greek Philosopher) Last edited by clickit; 24th December 2006 at 15:30. |
5th January 2007, 16:43 | #413 | Link |
Wrong colors written to sup-file...
Hi
I've just tested your application - version 2.0.6 I ripped the first chapter of a movie and used PGCDemux to split it into streams, video, audio and sup. I used another application to get the sub-text in SRT-format. I then moved all files test.mv2, test.ac3, test.srt to a new folder and loaded the srt-file into subcreator - only checking "PAL" and "Use anti-aliases filter" - and changing the font and colors for test purpose: Font = Univers 20 Bold (TrueType) Background = 00 Blue (Transp. checked) Text = 03 White Outline = 02 Black Anti-alias = 04 Green Text-colors looks fine in SC! I saved the file test.sup and mux'ed the files using Muxman. When I play the test-dvd on my PC using "Media Player Classic" or "Intervideo WinDVD 6" the subs have different colors than seen in SC: Background : White Text : White Outline : Black Anti-alias : unknown (maybe black or white) and the subs are positioned differently (vertically) than in SC. What is wrong here ? regards Pol Last edited by Politiken; 5th January 2007 at 16:54. |
5th January 2007, 17:50 | #414 | Link |
Please use the 2.1 beta 4 of SC which includes many bug fixes. About the color problems, it is a very common problem. You must open the IFO file of your movie with SC so that it uses the same color palette as your original DVD. Then you can change the colors and generate the sup file. About the positioning, it can be related to an anamorphic DVD? Did you try the internal preview of SubtitleCreator? Cheers Manusse |
7th January 2007, 11:38 | #415 | Link |
Issues corrected !
Hi - The latest beta corrects the problems - Thanks.
Yet, it is still a mystery to me that such a fundamental issue can go wrong - it appear that you were saving the same color palette index to both the background and the text - It must have been correct in an earlier version. The preview is much better in positioning the subs vertically, than the the default background vindow and the built in options. Pol |
4th May 2007, 12:36 | #416 | Link | ||
I had a problem recently with some movies ,the problem is that i cant see the movie ,just a black screen. what should i do ? Quote:
13th January 2008, 23:29 | #417 | Link |
I have tried several versions but it always crash when I try to run it. I have all the .NET updates. Is there anything I can try so I can run the application?
I really would like to try the feature of being able to open HD subtitles and save them as regular resolution subs. |
14th January 2008, 20:27 | #418 | Link |
Please use this thread: http://forum.doom9.org/showthread.php?t=112539. Could you please post a copy of the crash message. Cheers Manusse |
