17th May 2009, 18:50 | #2741 | Link | |||
Programmer (or just 教务长)
About your DVD title hanging - I'd ask you to wait and try with the next build. If the problem persists - I'd be glad to get a sample of your DVD folder... If there is another way to extract DVD subtitles IN CLI application - let me know - I'll implement it. You can also open task manager and kill mencoder. multiAVCHD will continue forward. Quote:
You have my skype - so just drop a note if you're worried about anything. Dean p.s. I'm preparing a new build that will offer completely rewritten way of importing AVCHD/BDMV folders and playlists. All will be available for edit/rearrange/remove in media tab. Preview (for titles) will work also for all kind of media (including playlists and imported AVCHD/BDMV titles). DVD support is also rewritten without the use of IFOUPDATE. DVD titles with no chapters get new ones...etc... a lot of things I prepared this afternoon... Will post it later. Last edited by deank; 17th May 2009 at 19:20. |
17th May 2009, 19:15 | #2742 | Link | |
@zrdb
17th May 2009, 19:40 | #2743 | Link | |
I found the problem. It will be fixed in next build later tonight. Last edited by deank; 17th May 2009 at 20:04. |
17th May 2009, 19:49 | #2744 | Link |
thank you Dean!
multiAVCHD.pid doesnīt exist, but I disabled the warning in "Settings". Killing memcoder leads to loss of that subtitle. How can I submit the folder (4.2GB)? What do you think about the thumbnail problem with DirectShow and MPlayer ("Directshow splitter/Encoder failed")? This obviously only has to do with just 3 chapter thumnails. |
18th May 2009, 01:21 | #2747 | Link |
Build 600:
* DVD VOB support * DVR TRP support * Preview (3x3) for all media (including imported playlists) * Bugfixes ("tsmuxer didn't like..." errors) * Rewritten DVD chapters / titles import * Imported DVD titles without chapters will get auto-generated chapter marks * IfoUpdate.exe is no longer used for DVD import * AVCHD/BDMV editor (on load) is removed * Major revision of how imported PLAYLISTS are handled: You will now see each title in MEDIA TAB (as a separate MPL/MPLS file). You can use UP/DOWN/DEL/VIEW/EDIT for all items in media tab. Removing titles will remove them from the list, not from your drive. New IDs for media in MEDIA TAB: [f] - File or MPL/MPLS playlist for m2ts join mode [d] - DVD title [m] - multiAVCHD playlist (no m2ts join) [p] - Imported playlist (no m2ts join) The difference between [m] and [p] is that [m]/multiAVCHD playlists and their media will be MOVED to your destination folder and [p] will be moved only if [x] Move ([x] all) is enabled. [f] for MPL/MPLS means that playlist contents will be processed in m2ts join mode. A lot of other new things in this release but it is late now so I'll leave the details for tomorrow. If anyone experience some weird behavior from multiAVCHD - let me know. I hope you'll like this release. Dean |
18th May 2009, 02:32 | #2748 | Link |
Had an Issue with Build 591. Some M2TS files would play fine an others would cause the PS3 to play part way through then crash out of the disk with Illegal Disk error. With a previous build which I don't know which one it was...sorry...I did not have this issue with the exact same M2TS files.
Any idea what may be causing the PS3 to react as Illegal Disk? Thanks. |
18th May 2009, 09:37 | #2750 | Link |
Hello,
about the "loop playback" at end of the last title saw in previous posts : I've tested with the lastest versions : - with avchd "no menu" and option QUIT desactivated, it's works fine. - with avchd "with menu" and option QUIT desactivated, no "loop playback" and player return to the menu. Can you add a option for avchd "with menu" to force loop playback at the end of last title (last title movie end->fisrt title movie start). With this option, the return to menu will be only if "TOP menu/MEnu" button used on remote. Another error appaer during complilation if I make AVCHD with menu, if image.jpeg existing in same folder as video/audio files. ex : with movie.jpeg and movie.264/movie.ac3 If I removoe the jpeg file no error message, with avhd with menu, it's works fine. |
18th May 2009, 13:29 | #2751 | Link |
DVD import works great but not sure what use it really is. If someone wants to play a DVD, wouldn't they just put the DVD on? I suppose it is a quick way to get menus for selecting smaller mutiple files.
I like the preview screen. |
18th May 2009, 13:36 | #2752 | Link |
SORRY, but with Build 600 I got a strange problem!
Yesterday I burned by mistake a 7.5GB compilation (AVCHD), made with v.591, to a DVD + R DL, which my Panasonic BD-60 refused to read. This morning I wanted to repeat the whole thing on -R DL (with a few changes using v.600-full download), but after pressing the button "AVCHD compatible players" the attached message appeared, no matter how often I tried, also after changing settings. Normally I erase former versions, but then found v.588 in one folder which worked instanly. What goes wrong? Last edited by strad; 18th May 2009 at 13:45. |
18th May 2009, 13:56 | #2753 | Link |
Upload multiAVCHD_pid.JPG to http://host.imageshack.us/ for example and put here the link, don't attach.
@dean, thank you for the TRP support. I made a test with the only TRP file I have and I noticed some audio delay. enjoy, Mtz |
18th May 2009, 13:59 | #2754 | Link | |
Build 600 was probably the worst build of all in the short history of multiAVCHD.
There were like 1000 bugs. Please update to 601. There were so many things wrong that I can't even start to list them. Dean @nwg: Quote:
*** @Mtz: Yes, I need a way to demux/encode MP2 audio without this audio sync problems. If you know how - let me know. Last edited by deank; 18th May 2009 at 14:01. |
18th May 2009, 14:21 | #2755 | Link | |
18th May 2009, 16:07 | #2757 | Link |
Is there a way to have multiAVCHD play a video file ie: an intro video first then launch the main menu with the other titles?
Were any of the bugs in 600 related to build 591 and my post on some M2TS files in the compilation causing the PS3 to reject the BD disk as illegal while some titles play fine? As I mentioned all the titles played fine in a previous build (with the auto-update I lost that build and don't know which one it was). Thank you. |
18th May 2009, 16:29 | #2760 | Link | |||
In build 601+ you will find a drop-down list in Author:
Action after last title: [Go to stand-by mode] [Display menu] [Loop playback] Quote:
*** @Mtz: Can you check again the TRP import? Last edited by deank; 18th May 2009 at 16:33. |
