Old 19th August 2018, 11:06   #321  |  Link
FredThompson
FredThompson's Avatar
Originally Posted by FredThompson View Post
Does FindVUK search memory for the reader executable or must it explicitly launch the reader executable?
Belay that. Here's a better question:
How does FindVUK determine which DVDFab product is installed?
Is it looking at a registry keys (such as HKLM/SOFTWARE/Classes, HKLM./SOFTWARE/Microsoft/CurrentVersion/Uninstall, or something else), looking in the start menu locations, or something else?
I just started using FindVUK last night and it interactacts with the common database properly, including submitting.
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline   Reply With Quote
Old 19th August 2018, 13:29   #322  |  Link
nalor
Originally Posted by candela View Post
FindVUK somehow thinks it failed
Strange - but the code used to upload things is quite new, the one used in the previous findVUK version (before 1.15) didn't support chunked upload and so didn't support bigger uploads for the synchronisation feature....
Will check the new code to see if I can find anything obvious ...
nalor is offline   Reply With Quote
Old 19th August 2018, 13:37   #323  |  Link
nalor
You can either specify the executeable directly in the inifile for each of the supported products or else it will check the registry to get the exe file.
Your explanation suggests that it's necessary to start your personal-exe-file and this one finally starts DVDfab ... and this setup won't work currently because 1) findvuk reads the dvdfab release from the specified exe file and 2) dumps the memory of the specified exe-file.
So it would always dump the memory of your personal-exe-file and never the required memory of the real dvdfab-application.
You would need an additional setting to define the launch-command that is just used to launch the specific dvdfab-application and that can be completely different from the 'MainFile' setting already available in the ini-file.
Old 22nd August 2018, 22:15   #324  |  Link
FredThompson
ok, the solution then is to install whatever driver support is needed for the app, then launch FindVUK, then remove the driver support when FindVUK is terminated. Thanks for the information.
Reclusive fart.
Old 23rd August 2018, 05:22   #325  |  Link
nalor
This should work
Gesendet von meinem E5823 mit Tapatalk
Old 1st September 2018, 14:15   #326  |  Link
candela
It seems the download links no longer work
candela is offline   Reply With Quote
Old 2nd September 2018, 21:10   #327  |  Link
TTide
FindVUK 1.15
Download FindVUK 1.15
SHA-256: 99848F9CDAA9BDE47BC0EC3D7768ECB2FE93999F2C1F9B4DF033A709F445FE1F
TTide is offline   Reply With Quote
Old 11th September 2018, 22:07   #328  |  Link
nalor
Released FindVUK 1.16
1) it should fix the upload problem reported by candela
2) it's possible to get UnitKeys for UHDs as well, unfortunately it's not possible to validate them because it still does not support BusEncryption (introduced new nodes in the MetaXML for upload)
Please test and report in case something isn't working properly.
btw: I've no idea why FindVUK 1.15 got removed from TinyUpload ... really strange.
Old 12th September 2018, 17:14   #329  |  Link
candela
issue is still there unfortunately
Old 12th September 2018, 19:06   #330  |  Link
nalor
Please create a file named 'FindVUK.ini' in the directory of the findvuk.exe and insert this text into it:
[LogLevel]
Default=4
Retry and post your logfile or send it to me - hopefully the debug information give me some additional hints ...
Thanks!
Old 12th September 2018, 22:31   #331  |  Link
nalor
Found the error, the log was really helpful!
Will shortly release 1.17 with the fix
Old 13th September 2018, 05:53   #332  |  Link
MartyMcNuts
@ Nalor,
I've used FindVUK 1.15 a few times and it works ok for me, although I have to ask:
1. What can we do with the decrypted unit keys?
2. Is there any software that can decrypt using these keys?
3. If possible, could FindVUK also provide the Media Key?
Thanks for all your hard work!
Marty
MartyMcNuts is offline   Reply With Quote
Old 13th September 2018, 13:38   #333  |  Link
candela
Originally Posted by MartyMcNuts View Post
@ Nalor,
Marty
1. Play\rip blurays
2. VLC with libaacs.dll. Dumphd. Bluraytest&decrypt
3. Newer Dvdfab no longer uses MK so its impossible for findvuk to provide it. Older Dvdfab still works for older discs so you can get MK from those. Or use aacskeys with Ps3 keys and valid host cert for mkbv62 and lower discs
Old 13th September 2018, 22:03   #334  |  Link
nalor
Published FindVUK 1.17 - 2nd try to fix the upload issue of candela and I noticed that it doesn't start in case there's no existing keydb.cfg - also fixed, now it just creates an empty file.
Old 13th September 2018, 22:13   #335  |  Link
candela
download link doesn't seem to work for some reason
Old 14th September 2018, 05:56   #336  |  Link
nalor
Strange - uploaded it again and this time it's at least working for me
Old 14th September 2018, 16:46   #337  |  Link
candela
download works now. upload also seems to work in 1.17
HTTP-POST success
17:45:19 - Successfully posted to the OnlineDB! >Successful written to database!<
Old 15th September 2018, 08:46   #338  |  Link
nalor
Good news - thanks for the retest!
Old 22nd September 2018, 10:37   #339  |  Link
richy
@Nalor: How often is the online database updated? I've submitted a few discs earlier this week and also tried the sync function with an older entry that's in my own keydb.cfg but not the online one but the online database doesn't seem to have altered at all. I know other discs I've submitted in the past are in there but I just wanted to check that my recent submissions are working as expected. I've not had any error messages that I'm aware of.
Also, I still get the same error with all versions of FindVUK after 1.10 whereby it attempts to find the media key and volume ID from DVDFab 9.2.2.4 and invariably finds zero values or totally incorrect values and so cannot verify the VUK it calculates. If I'd already got the correct values in my keydb.cfg file this means it will then delete them. Would it be any use if I sent you a logfile of what happens?
richy is offline   Reply With Quote
Old 22nd September 2018, 22:01   #340  |  Link
nalor
Hi!
Unfortunately I've managed to break my processing-script for new keys ... will take a few days until it's working again (need to stop to change things in the live-system ... at least in case there's no backup
I started to integrate the processing of the UHD entries and until it's finished nothing is working at all - stupid situation ... but hopefully the last time that a bigger change is necessary.
A logfile is always a good idea in case something is not working as expected!
