Old 19th July 2019, 20:47   #1  |  Link
Doorn9
Wouter van Doorn
Doorn9's Avatar
Correcting a film that was developed with a colour fault
Hello all,
First post - please be gentle...
I've been lurking on this forum for nine years now, lured in by videoFred's impressive early results. I want that, I thought, and got going getting my workflow together. Now, after many successfully restored super-8 films, I've run into the first clip that I can't get right whatever I do, and I'd appreciate help.
The clip concerned is an almost 40-second super-8 film scene with very little movement of either camera or subject, and with plenty of issues that I can work out - but one that I cannot. The original is here:
clip 1: original
http://www.vandoorn.tv/doom9/022.avi
The problem gets more pronounced after I run my usual set of correction tools over it. The original has a lot of yellow discolouration, for instance, and removing that alone already makes the problem more obvious. For the sake of completeness, this is the clip of the original and (currently) final versions side-by-side:
clip 2: original vs final
https://youtu.be/Zojgq3XvAMM
It seems like the sun appears and disappears several times. That, however, is not so. The change in colour from cold to warm and back affects the entire image; it's not as if clouds were moving. What happened is, in fact, an error during film development. I looking to even it out over the entire run. And I don't know how to go about it.
What follows is where I've come to (which may be a wrong way to go about it, but if it usable then I'm stuck anyway). My thinking was that I'd create a clip in parallel that contains an averaged-out colour (which I made in Photoshop). The changes in that average should then be a measure of the correction I need to apply. The average-clip was made in Photoshop, using the median noise-suppression filter with maximum radius (500) and some extra averaging and evening-out trickery. The result is here, next to the original:
clip 3: original vs average
https://youtu.be/7Mc_UM74DAI
I then asked a friend who is not (as I am) colourblind to choose a reference frame - he chose 831. Even though I'd have been happier with one from the non-sunny seeming range - but oh, well. I then made a second parallel (average) clip that contained just instances of frame 831 for the entire
length. Below: those averages next to one another. It seems that the colour problem (and, for that matter, the flickering in the original) are present in that new clip as I think I need them.
clip 4: reference average vs per-frame average
https://youtu.be/PYcsHdk4Eqc
From there, I was hoping that the following steps would be easy using the avisynth overlay function, but - no. What I tried with no luck at all was:
  1. create a clip with the difference between reference average and average
  2. invert the difference
  3. apply the inverted difference to the original
I won't bore you with all the things that went wrong, suffice to say: I got nowhere.
Anyone know how to make this work?
Anyone know a better way?
I have more clips with this type of problem, so I hope there's a method that can be automated (i.e. within avisynth/virtualdub(mod) in the versions I have and need - see below)!
Thanks for looking,
Wouter van Doorn
If it is of any interest, my setup is:
- Linux Mint 18.3-64 laptop Dell XPS13
- VirtualDub 1.10.4 (build 35491) 32 bit under Wine 1.6.2
* Plugin: DeShaker 3.1
- VirtualDubMod 1.5.10.2 (build 2542) 32 bit under Wine 1.6.2
- AviSynth 2.6 32 bit under Wine 1.6.2
* Plugin: deflicker
* Plugin: TCPDeliverffms2
* Plugin: ffavisynth
* Plugin: mvtools2
* Plugin: TTempSmooth
* Plugin: mvtools
* Plugin: degrainmedian
* Plugin: mt-masktools-25
* Plugin: warpsharp
* Plugin: DirectShowSource
* Plugin: hqn3d
* Plugin: colors_rgb
* Plugin: despot
- Photoshop CS6 64 bit under PlayOnLinux 4.2.10
* Plugin: iCorrect EditLab Pro 6.0 plugin for colour correction
- ffdshow rev 4532
- ffmpeg 4.1.3-0york1~16.04
- xvid 1.3.2
Last edited by Doorn9; 6th August 2019 at 22:09. Reason: Link to non-youtube original for clip 1
Doorn9 is offline   Reply With Quote
Old 20th July 2019, 11:27   #2  |  Link
videoFred
videoFred's Avatar
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Hello Wouter and welcome here!
Please upload an original not manipulated example somewhere so we can download it.
Fred.
About 8mm film:
http://www.super-8.be
Film Transfer Tutorial and example clips:
https://www.youtube.com/watch?v=W4QBsWXKuV8
More Example clips:
http://www.vimeo.com/user678523/videos/sort:newest
videoFred is offline   Reply With Quote
Old 20th July 2019, 14:12   #3  |  Link
Doorn9
Wouter van Doorn
Doorn9's Avatar
Hi Fred,
The first link is the original. Nothing done to it at all.
Thanks for looking!
Wouter
Old 20th July 2019, 15:41   #4  |  Link
ChaosKing
Could you identify which plugin is causing this color/brightness changes? A script would be good to reproduce the results...
Old 20th July 2019, 17:09   #5  |  Link
Doorn9
Wouter van Doorn
Doorn9's Avatar
The problem is in the original. Cleaning the clip up makes it stand out more - the yellow cast on the original hides quite a bit of the issue. Remove that (I do that in Photoshop with the iCorrect EditLab 6 plugin, not with an avisynth script) and the *real* problem shows up.
Old 20th July 2019, 19:17   #6  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Originally Posted by Doorn9 View Post
Hi Fred,
Thanks for looking!
Wouter
Uploading to YouTube will recompress it and possibly change the colour matrix - not by a great amount, but an unaltered cut from the original file may be preferable.
wonkey_monkey is offline   Reply With Quote
Old 20th July 2019, 19:53   #7  |  Link
ChaosKing
Maybe AutoAdjust() with a high temporal radius could help https://forum.doom9.org/showthread.php?t=167573
Old 20th July 2019, 20:44   #8  |  Link
Asmodian
Uploaded to Youtube and nothing done to it at all are mutually exclusive realities.
madVR options explained
Old 20th July 2019, 22:28   #9  |  Link
Doorn9
Wouter van Doorn
Doorn9's Avatar
Ah. That shows what I know. I didn't care about the compression, but mucking about with the colours is exactly what I wouldn't want here. So this is the original - as far as we can speak of an original considering it's super-8!
https://www.vandoorn.tv/doom9/022.avi
Thanks for explaining,
Wouter
Old 20th July 2019, 22:29   #10  |  Link
Doorn9
Wouter van Doorn
Doorn9's Avatar
Learning all the time!
Old 20th July 2019, 22:30   #11  |  Link
Doorn9
Wouter van Doorn
Doorn9's Avatar
Something to look into; I do not know autoAdjust, so there's something to look at.
Thanks!
Wouter
Old 21st July 2019, 10:05   #12  |  Link
videoFred
videoFred's Avatar
http://www.vandoorn.tv/022.avi
The requested URL /022.avi was not found on this server.
Oops....... sorry now it works
Fred.
About 8mm film:
More Example clips:
Old 21st July 2019, 11:20   #13  |  Link
videoFred
videoFred's Avatar
The original file is low resolution and low bitrate.(mpeg4). I see lots of block artefacts caused by compression. Is this how the original scans where delivered?
This is what I can make from it: stabilized, cleaned with RemoveDirtSMC(), Gammac() to remove the yellow cast, sharpened and finaly some minor RGB color correction (a bit less blue and a bit more red)
https://www.dropbox.com/s/fkeoi0bgoj...Doorn.avi?dl=0
But to have realy good results, you need a better scan from the original 8mm film.
PS: your corrected example is pretty good. The brightness change is probably caused by the borders.
This is why I have used a cropped clip for the Gammac detect clip.
Fred.
About 8mm film:
More Example clips:
Old 21st July 2019, 12:53   #14  |  Link
videoFred
videoFred's Avatar
Ok, I was not awake this morning
The brightness change is on the original indeed.
Fortunately, Gammac() in modus -1 can deal with this:
https://www.dropbox.com/s/rh6gwq3qfj...rn_01.avi?dl=0
Please look at the histograms at frames 565, 572, 579 and 735.
I doubt ........ is this brightness change or compression block artefact change? Or both?
Fred.
About 8mm film:
More Example clips:
Old 21st July 2019, 15:47   #15  |  Link
Doorn9
Wouter van Doorn
Doorn9's Avatar
Hello videoFred!
I was already very impressed by the first effort (when you were asleep...??) because it was already a lot better. Then this one came along, and it seems you have simply completely solved the problem! At least to my not very colour-sensitive eyes it seems so. Anyway - SO much better than the original, that I will now have to find out all I can about this gammac thing - whatever it is - so I can build it into my workflow. I hope I can do it under Linux/wine (it can be tricky) but I'll give it the best go I can.
What's the best resource for me to visit for learning about installation, settings, function parameters and all that?
Wouter
PS: all those many years ago it was actually you who encouraged me to start looking into digital film processing with the huge script you then had on this forum. It was the basis for all I do now (so far: thirteen stages for a piece of super-8 film, soon to be fourteen I hope!). Glad of the opportunity to thank you very much for what you published then, in addition to your response here!
Old 21st July 2019, 16:46   #16  |  Link
I thought that I had seen something about noisy 'sparkles' in this thread, maybe its was in some other thread, but anyway,
suggest do an eg Blur(0.2) on GamMac DC detect clip, just in case, no real downside to doing that.
Old 21st July 2019, 18:56   #17  |  Link
videoFred
videoFred's Avatar
Hi Wouter,
Gammac thread:
https://forum.doom9.org/showthread.p...ghlight=gammac
And Johnmeyer has made a version of my film restoring script with Gammac included. You can do a search here for this.
You are welcome!
Fred.
About 8mm film:
More Example clips:
Old 21st July 2019, 18:59   #18  |  Link
videoFred
videoFred's Avatar
Good idea as usual!
Fred.
About 8mm film:
More Example clips:
Old 21st July 2019, 19:38   #19  |  Link
Hi Fred.
I'm still a bit stuck on AutoLevels, when I get the frame radius smoothing thing sorted out[well actualy that part pretty much done], I'll add it and scene change detection part to GamMac.
EDIT: Should not slow it down much, had it [AutoLevels] doing something like 560 FPS on STD Def clip on my crap machine. [Same clip with Autogain I was getting more like 68FPS].
Old 22nd July 2019, 11:17   #20  |  Link
Bernardd
022.avi is better clip source.
I have try this source only with Automatic white balance with RGBAdapt plugin, post https://forum.doom9.org/showthread.p...04#post1878904
With only gain and contrast, we can get a readable white balance. Note this way have no issue with frame 102 with her big black dust. Two samples bellow.
AWB_Func(matrix="Rec601",show_scrutinized=false,x=0.04,y=0.04,w=0.04,h=0.04,threshold=0.1,show_info=false,
\ gain = truee, cont = true, g_c_decrease = 0.0, bias = false, rpow = false, spow = false, gamma_bias_mix = 0.5)
https://www.dropbox.com/s/5mxr9gwd5c...20min.mkv?dl=0
\ gain = truee, cont = true, g_c_decrease = 1.0, bias = false, rpow = false, spow = false, gamma_bias_mix = 0.5)
https://www.dropbox.com/s/hc82aqn22k...20max.mkv?dl=0
Bernardd is offline   Reply With Quote
avisynth, colour-fault, super-8
