1st January 2009, 19:56 | #7661 | Link |
does he -slowdown function actually remove the "EX" from ac3 tracks? I got an ac3 track here which is DD EX 5.1, but when I use -slowdown the track is only normal DD 5.1 after that. or does it maybe only remove the EX flag and the slowed down track is still EX? or was it never EX to begin with and only had the flag, which then correctly got removed at processing?
http://www.sendspace.com/file/13ese3 |
1st January 2009, 20:46 | #7662 | Link |
Proper EX decoding results in 6.1ch, but there's is no such decoder available. All we can get is 5.1. As a result, if you decode/slowdown/re-encode the track you can't get the original EX form back.
Happy New Year to everybody. |
1st January 2009, 21:32 | #7663 | Link |
As far as I understand, the mixed in back channel ("EX") should not get lost when slowing down audio (someone correct me, please, if I'm wrong). However, currently eac3to doesn't *ever* set the EX flag when using Aften to encode an AC3 track. Which means that in every case where audio is reencoded, the EX flag is lost. I have on my to do list to transport the EX flag through to the final AC3 file, but this is not implemented yet...
2nd January 2009, 08:00 | #7665 | Link | |
3rd January 2009, 00:57 | #7668 | Link |
@madshi
I'm getting the following error on my Austin Powers 2 Blu-Ray: "Lossless check failed" (see below). Is that something I can ignore? eac3to seems to indicate success after all, but I'm not sure. Thanks -------- eac3to 00002.m2ts 4: c:\video\temp.pcm M2TS, 1 video track, 3 audio tracks, 1 subtitle track, 1:29:35 1: Chapters, 25 chapters 2: VC-1, 1080p24 /1.001 (16:9) 3: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB 4: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB (embedded: AC3, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB) 5: AC3 Surround, English, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB 6: Subtitle (PGS), English [a04] Extracting audio track number 4... [a04] Extracting TrueHD stream... [a04] Removing TrueHD dialog normalization... [a04] Decoding with libav/ffmpeg... [a04] Swapping endian... [a04] Remapping channels... [a04] Creating file "c:\video\temp.24bit.pcm"... [libav] Lossless check failed - expected 0, calculated 91 [a04] The original audio track has a constant bit depth of 16 bits. [a04] The zero bytes were successfully removed. Video track 2 contains 128879 frames. eac3to processing took 12 minutes, 17 seconds. Done.
Gorgeous, delicious, deculture! |
3rd January 2009, 03:02 | #7669 | Link |
might be the same case I had, meaning its only that one instance inside the track which wont be lossless then, while the rest of all other million bytes are or something like that. in other words: you wont notice any difference.
3rd January 2009, 04:41 | #7670 | Link |
Thanks. It looks, indeed, rather benign. I thought that (presumably) the checksum fails because of leading/trailing zeroes (?). But it's good to know I can safely ignore it.
3rd January 2009, 11:22 | #7671 | Link |
Please forgive some '-already-answered-but-can't-search-huge-thread' questions...
I want to convert a DTS-HD MA 5.1 24bit/48KHz track to 24/48 flac from a BD folder/m2ts file. 1. Source reports -8ms, does that mean I've got to add +8ms for any type of destination file, flac included? 2. The blu-ray remapping option (or any other option) isn't needed for this, right? edit: 3. Are there known issues with different versions of the Arcsoft DTS decoder? Thanks Last edited by Weirdo; 3rd January 2009 at 12:11. |
4th January 2009, 00:33 | #7672 | Link | |||
N.B. Actually, never seen an occassion where I did need the "-blu-ray" option. I convert TrueHD/DTS-MA -> LPCM without it, at least. Quote:
4th January 2009, 07:54 | #7674 | Link |
This has probably been answered somewhere in this thread, but Instead of plowing through 380+ pages I'm hoping someone can help me with a simple answer.
How or what do I need to do to the .sup subtitle files extracted by eac3to to get them in a format that I can mux with my audio and video files into .MKV? I believe MKVMerge can handle subtitles in the SRT, SSA, ASS and Vobsub formats (are there others MKVmerge can use?). Thanks |
4th January 2009, 08:32 | #7675 | Link | |
(1) play 00002.m2ts from start to end (2) play the first second of 00002.m2ts another time eac3to didn't like this configuration, because usually playlists which ask for the same m2ts part to be played more than once are menu titles. The next eac3to will "fix" this problem. |
4th January 2009, 08:34 | #7676 | Link | |
4th January 2009, 09:26 | #7678 | Link |
madshi
I just want to say Fan-Friggen-Tastic work with eac3to... it's plain awesome, never fails me, i was about to post a question regarding a tricky DTS file i had, it spits the error: Can't downmix this channel configuration ($60f). Internal error - unknown audio output format! But a simple update from 2.77 to 2.87 fixed my probem.... awesome work!!! keep it up. Do you have a paypal account that i could donate to say thanks for your time and effort? |
4th January 2009, 14:41 | #7679 | Link |
Is this a bug?
eac3to v2.87 command line: eac3to f:\temp\fly_dxva_hd_hq.264 test.mkv ------------------------------------------------------------------------------ h264/AVC, 1920x816 24p /1.001 (40:17) Muxing video to Matroska... Added fps value to MKV header. Video track 1 contains 300 frames. eac3to processing took 1 second. Done. Maybe it's a bug in x264 AUDs placement?... You can download the file here: http://www.megaupload.com/?d=6XTI9UH5 By the way, I have suggested MeGUI authors to automatically set the --aud option in x264 when outputting RAWAVC streams, and they agree do it in the next release. |
eac3to |
