27th February 2012, 21:59 | #12362 | Link | |
27th February 2012, 22:55 | #12363 | Link |
@dansrfe: yeah I know dslibdvdnav but it's in early stage, yet. Requires a modified MPC-HC or registry hack and doesn't work very well with some menus. Can't wait it to became more stable, so we can abandon ms dvd navigator.
27th February 2012, 23:18 | #12364 | Link |
It doesn't modify MPC-HC. it simply resets the path to qdvd.dll so that calls to mircosoft's dvd navigator are directed to dslibdvdnav.ax. And even at its current state it performs better than MS's dvd navigator.
28th February 2012, 01:41 | #12367 | Link | |
Dscaler only works for 3:2 cadence, and only for MPEG2 content. MadVR has it's own on the fly pattern-finder (it searches for all possible cadences, like 3:2, 2:2, 3:2:2,... almost unlimited, and can (almost real-time) switch between different cadences) and works for all content, not just MPEG2. Also H264 (from broadcasting for example) can be "telecined", what should be no problem for Madvr because for the renderer the content does not matter anymore. Last edited by Pat357; 28th February 2012 at 02:18. Reason: typo |
28th February 2012, 02:12 | #12368 | Link |
Matt,
I got a complete crash from Potplayer (latest version) in a way that my screen was completely black. I happened when switching to or back from FSE, can't tell for sure what is was. I couldn't even access the taskman anymore, because after ctrl+alt+del -> taskman gave me again the back screen. The only way to recover was switching to a different user and kill the Potplayer process from there. At the moment that the screen turned black, I pressed the magic buttons to create a crash report. Now here it comes : there were 41 crash-reports on my desktop ! You probably need just the first one I suppose, but to make sure, I'll provide all of them. (don't worry, all together compressed is still only 15 kB.) MadVR 0.81 / Nvidia GTX-570 / Win7 x64 SP1 (auto-updates) Potplayer 1.5.32007 / CPU i7-970 / NVidia driver : v290.33 http://www.mediafire.com/?m5fmjp3a618jdpv http://www.mediafire.com/download.php?m5fmjp3a618jdpv |
28th February 2012, 04:47 | #12369 | Link |
I'm finding that the automatic display mode changer isn't taking deinterlacing+IVTC into account when determining which display mode to change to. It is selecting 1080p60, even though the playback rate is 24fps. When the content is already 24p, 1080p24 is selected correctly. Can anyone confirm, or am I missing something?
28th February 2012, 06:03 | #12370 | Link |
you have to flag it manually with a "24p" in the file name. If you want film mode to be detected automatically too without having to press CTRL+SHIFT+ALT+T, then you have to disable automatic source type detection in madVR's deinterlacing options.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
28th February 2012, 07:10 | #12371 | Link |
Suptitle, MediaPlayer.NET
Hi Madshi,
Would it be possible to change the seek bar's height in exclusive mode? It's a little too thin now -- with an overscan, I could merely see the tip of the bar. A time code overlayed on top of the seek bar (I know it's custom drawn and much harder than what most ppl think) would be appreciated as well. Last edited by Zachs; 28th February 2012 at 07:15. |
28th February 2012, 10:21 | #12375 | Link |
Questioning User
Installed the new version and the video resolution is slow to adjust when going in and out of full screen while playing.
For example: When I double-click MPCHC it switches to full screen but the video remains the windowed sized stuck at the top-left corner, a blank non-Aero windowed frame of MPCHC is seen as well. MPCHC then gets very inresponsive to clicks and keyboard presses. When I manage to exit full screen, the video is still full screen size with the top left part showing in the window. Scales like normal if its done when video is paused though. Did not happen when I was using 0.80.
8 Pro x64 | i5-3470 | 8GB ram | GT430 | Xonar DX | MPC-HC x86
28th February 2012, 12:50 | #12379 | Link |
Questioning User
Yup, driver 295.73 and MPCHC 1.6.1.4081 from xvidvideo.ru
Also using the latest LAV Filters. EDIT: Used the included batch file to reset to default settings and slowly tweak the settings back. Scaling is much faster but sometimes the blank non-Aero windowed frame of MPCHC can still be seen in a flash when scaling to full screen. Seems fine now, fast and usable. The switch to full screen exclusive mode is fast too but I want MPCHC's function that shows the time on hovering the seek bar. On further testing it seems to be the enabling of 'delay playback start until render queue is full' and probably a high backbuffer value. Or is it the 'use a separate device for presentation' option. Haven't been able to pinpoint it for now. I've been following the guide at http://imouto.my/madvr/.
