6th October 2005, 00:46 | #22 | Link |
Posts: n/a
hi
i tested the remap vts / delete last, i actually got an error after the deleting, when pgcedit autoreloaded the dvd it asked me for the deleted vob (vts3) :/, so i had to open video_ts in ifoedit and make a getvtssector, after that when loading the "fixed" ifos pgcedit blocked at the loading of the last ifo (vts2), i fixed this by manually removing the vts3 and associated title in ifoedit (strangely they were still inside), btw i've a question about LU menus, is it possible to change the language or something somewhere in pgcedit (i was not able to find it ) ? Nice job , Regards |
6th October 2005, 11:07 | #23 | Link | ||
PgcEdit daemon
I have done that this way to let the user remove several titlesets in sequence. But maybe I have to add an automatic save, to avoid this problem. Quote:
Why do you want to change the language code? If you have a good reason, I may add a function or a plugin to do it.
6th October 2005, 12:30 | #24 | Link |
PgcEdit daemon
LU Plugin
Changed my mind. There is one reason to change the LU: when you have entered a wrong code in an authoring program, you may want to change it without having to recompile the DVD.
And it was so easy to do... So, here it is. Download: lu_plugin_v10.zip As usual, you have to put it in the "plugins" folder. See my homepage for details. This plugin requires PgcEdit v0.6.1 or more.
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 6th October 2005 at 12:43. |
6th October 2005, 12:40 | #25 | Link |
PgcEdit daemon
Auto-Comment plugin
I have also created a new "Auto-Comment" plugin. It adds a <void> comment to all PGCs without pre/post/cell commands. Though this plugin is of little use, it may be useful in some cases. See here for details.
Download: auto_comment_plugin_v10.zip Consider these two plugins as beta versions. I will add links to them on my homepage later...
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 6th October 2005 at 12:42. |
6th October 2005, 14:10 | #26 | Link | |
Posts: n/a
i removed one of 2 LU so it was using the other as default as you said, just wanted this one to be "unspecified" or something, but correcting an authoring error is a good reason , i'll retest the remap / delete thing, thanks Last edited by radius; 6th October 2005 at 14:17. |
6th October 2005, 14:38 | #27 | Link | |
first things first: great update!
I'm glad radius asked for the LU switcher , so there's another nice Plug-In Quote:
I'm still puzzled on how to add a new LU at all; IfoEdit, Add PGC to VTSM_PGCI_UT did "something", but of course it didn't work Guess I need to do some more research on that subject. It'd be great to simply author the full set of menus, clone/duplicate that LU, assign another lang code, and then replace what needs localization with VobBlanker or whatever (... just thinking) Have fun, CirTap
You can have programs written fast, well, and cheap, but you only get to pick 2 ... "I love deadlines. I like the whooshing sound they make as they fly by." Douglas Adams |
6th October 2005, 16:39 | #28 | Link | |
JuSt a PoWer uSEr
if it can be done. (for people who cannot easily read the trace dump output) thanks
Birthdays are good. Statistics show that the people who have the most live the longest. Last edited by dirio49; 6th October 2005 at 16:43. |
6th October 2005, 17:02 | #29 | Link |
Posts: n/a
Excuse my possible ignorance dirio49, but to what purpose ?
A list of played cells would only relate to the specific command flow and menu selections made to that point, but not other cells possibly played via similar but slightly different route. Can get very complex to trace all possible routes. |
6th October 2005, 17:15 | #30 | Link | |
JuSt a PoWer uSEr
this would be only done when you would use the trace function and all the times or it could be as a plugin |
6th October 2005, 17:24 | #31 | Link |
DVD Magistrate
@CirTrap
DVDLab can set language code....but only after you compile your project....goto Tools-->IFO Editor - Audio see http://www.mediachance.com/dvdlab/Helppro/tools.htm and scroll down |
6th October 2005, 23:26 | #32 | Link |
@ron: yes, thanx, I know, but the feature you're refering to applies to audio tracks in "regular" DVD-lab (hence "IFO Editor - Audio"). DVD-lab PRO has *that* kind of (audio) language setting built-in w/o IFO hacking.
The LUs handled by r0lz' plug-in belong to "localized" DVD menus, DVD-lab does not handle -- yet. CirTap
8th October 2005, 10:59 | #33 | Link |
Country Member
I haven't been on much, so let me add my voice to all others to congratulate r0lZ on his fine work.
The best just got better! Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
8th October 2005, 16:30 | #34 | Link |
Posts: n/a
there's actually a small issue using the "input value" button in the "prohibited user operation menu", when you validate or cancel the "input value" the "prohibited user ..." menu doesn't stay on top so we can't close it and continue, it does the same if you are in the "prohibited user ..." menu and you leave / refocus the pgcedit window, maybe it's something with gtk ? btw is it possible to get the windows maximized when setting it's set in the shortcut too ^^ ? thanks |
8th October 2005, 17:07 | #35 | Link | ||
PgcEdit daemon
8th October 2005, 17:18 | #36 | Link | |
8th October 2005, 17:51 | #37 | Link | |
8th October 2005, 18:50 | #38 | Link | |
Posts: n/a
another thing, could it be possible choosing to not "create a new vob id / edit vob" when creating a new blank cell, as sometimes we may use existing stuff ? thanks Last edited by radius; 8th October 2005 at 19:05. |
8th October 2005, 19:16 | #39 | Link | ||
PgcEdit daemon
I don't understand why it doesn't work with Tcl/Tk. I have tried some time ago to make it work, without success. Quote:
9th October 2005, 01:46 | #40 | Link |
Create ISO image
In my DVD backup directory, I usually have sub-directories like BAKUP, STRIPPED, ... besides VIDEO_TS and of course PgcEditBackup. When creating ISO image, PgcEdit knew to ask if I wanted to include the other sub-dirs but would not go forward if I clicked No i.e did not allow me to create ISO image with just the VIDEO_TS, excluding the others sub-dirs though it knew not to ask about the PgcEditBackup sub-dir.
Can you add this exclude option for creating ISO image, save me from having to move other stuffs out each time. Thanks. |
