31st January 2010, 13:58 | #2782 | Link | |
HDConvertToX author
HDC sounds ? BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
31st January 2010, 18:32 | #2783 | Link |
I think Frozen-Figo is talking about that "popping" sound (sounds like popping a cork from a wine bottle?) when the HDC encode starts. This might be HDC and it might be one of the programs it uses. But I think that's the sound he's talking about.
1st February 2010, 06:44 | #2785 | Link |
I've gotten the program to start the video conversion itself with avimux after changing to XP compatability. I've run the video conversion many times and it ALWAYS stops/stalls at about 30.0 - 30.6 % each time. Memory usage is about 478 MB and it just stops, the CMD window is still open, showing the status of conversion, but no more progress in the total percent or frames converted.
1st February 2010, 09:27 | #2786 | Link |
HDConvertToX author
this is usually a decoding issue
are you using dss ? BHH
1st February 2010, 14:14 | #2787 | Link |
About the "Unsupported File Error Popup" for some MKV Files, I think I found the problem:
Seems HDC behaves different when using dragnDrop for Fileinput or using the OpenFile Dialog. The message comes only while using DragNDrop (my prefered way), but I can work with all these Files where I got this error when using the FileOpen Dialog. Seems youre Using redundant coding instead of using the same routine for both ways, so maybe it happened you corrected one and missed the other? best regards |
1st February 2010, 14:28 | #2788 | Link |
HDConvertToX author
@ziemlichdunkel
sorry pal, share the same code. both fuction (drag&drop and file open) call the same routines (you can check the analysis.avs in analysis folder, should be the same for both way) @all i added a preliminary support for dgi input files could someone download hdc and test it ? also: please mail me a zipped dgi file BHH
1st February 2010, 20:09 | #2789 | Link |
Some issues
Hey!
Thanx for a great program. I have been using it for a short while and run across some issues. All of these are with the latest version. All of these happen using a DVD source, either ripped as folders or mounted ISO-images. I convert to x264 in MKV, choosing two audio tracks and one video track.
Two minor wishes too
Regards, Wish Last edited by wishyou; 1st February 2010 at 21:50. Reason: Missing audio track bug was only when encoding right after an interlace analysis |
1st February 2010, 21:15 | #2790 | Link |
Eh? Are yu saying that you don't have NVTools
Here's one, with source and audio. The dgi does not seem happy at all in V3966: "File not Directly supported; Unable to compute aspect ratio...." http://www.mediafire.com/?sharekey=4...390143435ec59c T |
1st February 2010, 21:52 | #2791 | Link |
HDConvertToX author
yes, i have ntvools and even the license but i use as main os linux, and my developing machine (win7) has a integrated intel gpu
BHH
1st February 2010, 23:20 | #2793 | Link | |
... color 0a pause Colorizing is just for me to quickly notice when all jobs are completed. edit: How about an option in HDC (or .ini file) for last queue line(s)? Last edited by feanor12; 1st February 2010 at 23:25. |
2nd February 2010, 03:42 | #2794 | Link |
I've finally gotten the program to fully complete a conversion of a m2ts from a blueray. It would ONLY get past 30% or so when I put it on the fastest conversion speed. IT ALWAYS stalls on any other speed. However, there is a new problem (using latest version). I converted the single m2ts of 32GB ... to a 1.8 GB x264/mkv. The problem is, that the single file (full movie) is 2h 10min in length. THE FINAL converted video was the ENTIRE movie - but put into a running time of 1h 5minutes ....... the entire movie was there, including subtitles and audio, but the video, when watching it was moving slightly fast forward and the entire movie was showing in 1h 5 min .......... what's up with that ?
2nd February 2010, 08:30 | #2795 | Link | ||||
HDConvertToX author
@wishyou
Hi wishyou and welcome to the Forum! Quote:
anyway i have put some sanity checks around deinterlace routines. please use the live update Quote:
thanks for your feedback wishyou! @feanor12 i will think about @TraumaDoc used any deinterlace ? also.. the make report! BHH
2nd February 2010, 10:43 | #2796 | Link |
I am using NOT using De-Noise Filters or De-Interlace Filters.
I'm going to run the program and try converting a different bluray - but that should NOT make a difference. I don't understand why it's doing this. Code:
HDConvertToX v.2.3.566.3972 report Input File: d:\movies\the hurt locker\bdmv\stream\00020.m2ts ( D:\Movies\THE HURT LOCKER\BDMV\STREAM\00020.m2ts ) Codec Video: avc Width / Heigh : 1920 / 1088 Framerate / Framecount: 47.952fps / 376128 frames Duration(hh:mm:ss): 2:10:44 Aspect Ratio: 1.7778 Resized resolution: 1024 / 560 Crop Values : 0:8:0:8 Start Video Configuration -> Encoding Settings: XviD Ultra Fast ; Bitrate= 1363 Final Size: 1400 Denoise Level: None Video Handling: Use Best Decoder -> End Video Configuration Start Audio Configuration -> Audio Codec: MP3 Audio Audio Bitrate/Quality: 128 Audio Channels: 2 MP3 Mode: abr Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 3: dts master audio, english, 5.1 channels, 24 bits, 48khz -> End Full Audio List Full Subtitle List-> (*** mean selected) NONE *** 4: subtitle (pgs), english -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Muxing Options -> <- End Muxing Options Start Queue -> prompt $d $t $_$P$G "C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 2:"C:\HDConvertToX_2.3.566.3972\job1\hdconverttox.mkv" -seekToIFrames "C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 4:"C:\HDConvertToX_2.3.566.3972\job1\hdencodertox__subs_4.sup" "C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 3: stdout.wav -down16 -down2 | "C:\HDConvertToX_2.3.566.3972\applications\lame.exe" - -h --abr 128 "C:\HDConvertToX_2.3.566.3972\job1\hdencodertox-pid3.mp3" java -jar "C:\HDConvertToX_2.3.566.3972\applications\BDSup2Sub.jar" "C:\HDConvertToX_2.3.566.3972\job1\hdencodertox__subs_4.sup" "C:\HDConvertToX_2.3.566.3972\job1\hdencodertox__subs_4.idx" /res:pal "C:\HDConvertToX_2.3.566.3972\applications\xvid_encraw.exe" -progress 50 -i "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avs" -avi "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avi" -max_bframes 0 -quality 4 -vhqmode 0 -max_key_interval 500 -notrellis -nochromame -framerate 47.952 -threads 3 -bitrate 1363 -pass1 -turbo -par 1:1 "C:\HDConvertToX_2.3.566.3972\applications\xvid_encraw.exe" -progress 50 -i "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avs" -avi "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avi" -max_bframes 0 -quality 4 -vhqmode 0 -max_key_interval 500 -notrellis -nochromame -framerate 47.952 -threads 3 -bitrate 1363 -pass2 -par 1:1 "C:\HDConvertToX_2.3.566.3972\applications\AVIMux_GUI.exe" -stdin "C:\HDConvertToX_2.3.566.3972\applications\mux1.amg" -> End Queue AviSynth Script -> Working with files: C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avs directshowsource("C:\HDConvertToX_2.3.566.3972\job1\hdconverttox.mkv",audio=false) last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last BilinearResize(1024,560,0,8,-0,-8) -> End AviSynth Script AVIMux-Gui Script > CLEAR LOAD C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avi LOAD C:\HDConvertToX_2.3.566.3972\job1\hdencodertox-pid3.mp3 SELECT FILE 1 ADD VIDEOSOURCE SET OPTION CLOSEAPP 1 SET OPTION OVERWRITEDLG 0 SET OPTION DONEDLG 0 SET OPTION ALL AUDIO 1 SET OPTION ALL SUBTITLES 1 SET INPUT OPTIONS SET OUTPUT OPTIONS WITH SET OPTION OPENDML 0 RECLISTS 0 AUDIO INTERLEAVE 1 FR AVI ADDJUNKBEFOREHEADERS 0 PRELOAD 512 END WITH START C:\Working\The Hurt Locker.avi -> End AVIMux-Gui Script |
2nd February 2010, 11:12 | #2797 | Link | |
HDConvertToX author
there is some decoding issue try changing this line Code:
"C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 2:"C:\HDConvertToX_2.3.566.3972\job1\hdconverttox.mkv" -seekToIFrames Code:
"C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 2:"C:\HDConvertToX_2.3.566.3972\job1\hdconverttox.mkv" -seekToIFrames -fps XXXXXXXX anyway try to check your decoders BHH
2nd February 2010, 13:07 | #2799 | Link |
HDConvertToX author
my bad
"C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 2:"C:\HDConvertToX_2.3.566.3972\job1\hdconverttox.mkv" -seekToIFrames -XXXXXXXX just -framerate BHH
2nd February 2010, 14:10 | #2800 | Link |
-seekToIFrames -376128 also causes that "376128" is not a proper command
If I just do -seekToIFrames 376128 there is not a command error problem, but there says: Track 3 is used for destination file "376128".This audio conversion is not supported. What if I just use a deinterlace filter to force half frames or force 23.976 fps ? And all the commands are clearly different using mkv or avi and codec, right? So, I can't seem to find a good way to ensure proper output regardless of the codec and package chosen for the video !! I'm going to try the following. This sucks because it takes HOURS AND HOURS even at the fastest selection. If I had a small sample of the video with the SAME properties, framerate, etc. I could try it, but don't know the best way to do that with such a large m2ts. Here is my next attempt plan: Code:
HDConvertToX v.2.3.566.3972 report Input File: d:\movies\the hurt locker\bdmv\stream\00020.m2ts ( D:\Movies\THE HURT LOCKER\BDMV\STREAM\00020.m2ts ) Codec Video: avc Width / Heigh : 1920 / 1088 Framerate / Framecount: 47.952fps / 376128 frames Duration(hh:mm:ss): 2:10:44 Aspect Ratio: 1.7778 Resized resolution: 1024 / 560 Crop Values : 0:8:0:8 Start Video Configuration -> Encoding Settings: X264 UltraFast ; Bitrate= 4668 Final Size: 4482 Denoise Level: None Video Handling: Force DirectShowSource2 (Haali) Deinterlace: Half Framerate -> End Video Configuration Start Audio Configuration -> Audio Codec: MP3 Audio Audio Bitrate/Quality: 128 Audio Channels: 2 MP3 Mode: abr Audio handling: Use Eac3to as demuxer Keep only core: On -> End Audio Configuration Full Audio List-> (*** mean selected) NONE *** 3: dts master audio, english, 5.1 channels, 24 bits, 48khz -> End Full Audio List Full Subtitle List-> (*** mean selected) NONE *** 4: subtitle (pgs), english -> End Full Subtitle List Mux Subtitle in MP4/MKV file: On Start Advanced AviSynth -> ColorMatrix: On -> End Advanced AviSynth Start Muxing Options -> <- End Muxing Options Start Queue -> prompt $d $t $_$P$G "C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 4:"C:\HDConvertToX_2.3.566.3972\job1\hdencodertox__subs_4.sup" "C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 3: stdout.wav -down16 -down2 | "C:\HDConvertToX_2.3.566.3972\applications\lame.exe" - -h --abr 128 "C:\HDConvertToX_2.3.566.3972\job1\hdencodertox-pid3.mp3" java -jar "C:\HDConvertToX_2.3.566.3972\applications\BDSup2Sub.jar" "C:\HDConvertToX_2.3.566.3972\job1\hdencodertox__subs_4.sup" "C:\HDConvertToX_2.3.566.3972\job1\hdencodertox__subs_4.idx" /res:pal "C:\HDConvertToX_2.3.566.3972\applications\x264.exe" --pass 1 --bitrate -1 --preset ultrafast --threads auto --thread-input --sar 1:1 --output "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.h264" "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avs" "C:\HDConvertToX_2.3.566.3972\applications\x264.exe" --pass 2 --bitrate 4668 --preset ultrafast --threads auto --thread-input --sar 1:1 --output "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.h264" "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avs" "C:\HDConvertToX_2.3.566.3972\applications\eac3to.exe" "d:\movies\the hurt locker\bdmv\stream\00020.m2ts" 1:"C:\HDConvertToX_2.3.566.3972\job1\chapters.txt" "C:\HDConvertToX_2.3.566.3972\applications\mkvmerge.exe" -o "c:\working\The Hurt Locker.mkv" --default-duration 0:23.976fps "C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.h264" --language -1:eng "C:\HDConvertToX_2.3.566.3972\job1\hdencodertox-pid3.mp3" --default-track -1:no --language -1:eng "C:\HDConvertToX_2.3.566.3972\job1\hdencodertox__subs_4.idx" --chapters "C:\HDConvertToX_2.3.566.3972\job1\chapters.txt" --title "Done with HDConvertToX v.2.3.566.3972" -> End Queue AviSynth Script -> Working with files: C:\HDConvertToX_2.3.566.3972\job1\hdconverttox_00020.avs DSS2("d:\movies\the hurt locker\bdmv\stream\00020.m2ts",fps=47.952) last = isRGB(last) ? ConvertToYV12(last) : last last = isYUY2(last) ? ConvertToYV12(last) : last ChangeFPS(23.976) BilinearResize(1024,560,0,8,-0,-8) -> End AviSynth Script |
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
