Old 5th August 2016, 00:13   #181  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by locotus View Post
Source file "C:\Downloads\En proceso\DC Audio espaol.ac3" not found. <ERROR>
Without problems here:
eac3to v3.31
command line: "D:\Programa\eac3to\eac3to.exe" "D:\tmp\Audio español.ac3" -progressnumbers -log="D:\Programa\eac3to\UsEac3to\UsEac3To.log"
AC3, 5.1 channels, 0:00:20, 640kbps, 48kHz
Maybe you have a extrange character, showed here like ''
I can't guarantee than UsEac3to work fine with all languages but yes with spanish, my native language.
Try rename the original file changing the character by a typed 'ñ' and say me if work now.
Old 5th August 2016, 00:28   #182  |  Link
locotus
Yeah, I know that, mine too. But since then do some tests changing audionames including and ñ to see what happens and get the same result.
Seems a silly bug, maybe in Eac3to, but is good to know so nobody break his head with it.
Thanks anyhow.
locotus is offline   Reply With Quote
Old 5th August 2016, 02:41   #183  |  Link
tebasuna51
tebasuna51's Avatar
New version v1.2.0
Changelog
- v1.2.0 2016-08-05 Aften.exe deprecated by ffmpeg.exe. See Audio recode.
Added Opus encoder and BeSplit for dtswav.
Option to enqueue Run and MkvMux
Update MkvExtract options (all ATT or SUP)
Old 11th August 2016, 20:59   #184  |  Link
szabi
Hi
I got this error message:
v02 Muxing video to Matroska...
v02 Getting "Haali Matroska Muxer" instance failed.
Do I need to install Haali Media Splitter?
bye
szabi is offline   Reply With Quote
Old 11th August 2016, 22:30   #185  |  Link
tebasuna51
tebasuna51's Avatar
Is a eac3to requirement:
For video muxing you need:
(1) Haali Matroska Muxer
BTW you can extract elementary video stream: h264, vc1,m2v
Old 24th August 2016, 15:40   #186  |  Link
szabi
Hi
You are right.
I was just little confused to install 3 years old Haali Media Splitter.
Nowadays LAV splitter is preferred.
Bye
Old 15th September 2016, 19:55   #187  |  Link
tebasuna51
tebasuna51's Avatar
New version v1.2.1
Changelog
- v1.2.1 2016-09-15 Improved 'A/V Recode':
Added ffmpeg MAP to select track in container.
Added option to override encoder parameters.
More info in Readme, for instance now we can do:
You have a mkv with the second audio track:
3: EAC3, English, 5.1 channels, 48kHz, 678ms
and you want recode to AC3 and apply the delay
1) Put in COMMAND LINE PARAMETERS: -af "adelay=678|678|678|678|678|678"
2) Click in 'A/V Recode'
3) Select the AC3 desired bitrate
4) Select the 'ffmpeg map' to 2
5) Select 'Use Commad Line Parameters' to 'Add to def'
6) 'Run' or 'EnQueue' the job
Last edited by tebasuna51; 16th September 2016 at 04:01. Reason: replace buggy upload
Old 15th September 2016, 20:55   #188  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Many thanks for your continuing support
Old 16th September 2016, 04:02   #189  |  Link
tebasuna51
tebasuna51's Avatar
Sorry, a little bug, reupload the new version.
Old 23rd September 2016, 19:20   #190  |  Link
MaxitoHP
Thank you very much, Tebasuna. Great job, as always.
MaxitoHP is offline   Reply With Quote
Old 27th September 2016, 20:26   #191  |  Link
szabi
Hi
I want to join two AC3.
I open the 1st one and after click "+Sources".
Instead of adding 2nd AC3 the following failure message received "Don't exist a file"
What am I doing wrong?
EDIT: Ok, I found it: CLICK
I forget this naming requirement.
Again.
bye
Old 6th October 2016, 11:58   #192  |  Link
tebasuna51
tebasuna51's Avatar
New version v1.2.2
Changelog
- v1.2.2 2016-10-02 Added -drc_scale 0 to ffmpeg (to decode AC3 or E-AC3)
Now ffmpeg AC3/EAC3 decoder don't apply DRC like eac3to do.
If track input is not a AC3/EAC3 you can safely ignore the yelow (WARNING) ffmpeg message:
Codec AVOption drc_scale (percentage of dynamic range compression to apply) specified for input file #0 (D:\Temp\test.mkv) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some decoder which was not actually used for any stream.
Old 18th November 2016, 15:24   #193  |  Link
romanturbo
just thank you
ive seen u implemented the queue , as well now truehd encoding is also working, awesome work!! thx for your effort
romanturbo is offline   Reply With Quote
Old 23rd November 2016, 21:20   #194  |  Link
SquallMX
Special SeeD
I´m trying to remove DN from an E-AC3 file, but I keep getting error codes:
E-AC3, 7.1 channels, 1:26:28, 768kbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, 1:26:28, 448kbps, 48kHz, dialnorm: -27dB)
Removing AC3 dialog normalization...
Applying (E-)AC3 delay failed.  <ERROR>
Aborted at file position 262144.  <ERROR>
SquallMX is offline   Reply With Quote
Old 23rd November 2016, 21:32   #195  |  Link
tebasuna51
tebasuna51's Avatar
Hello SquallMX!
What is the command line?
Because the problem seems related with delay:
and the info not show any delay.
Can you upload a sample of a few MB?
Old 23rd November 2016, 21:52   #196  |  Link
SquallMX
Special SeeD
Hello SquallMX!
Of course:
eac3to v3.31
command line: "D:\Archivos de Programa\EAC32AC3\eac3to.exe"  "D:\Spanish.ac3" "D:\Spanish.ac3_.eac3" -progressnumbers -log="D:\Archivos de Programa\EAC32AC3\UsEac3To.log"
https://1drv.ms/u/s!AiCgDguh7E_OxTzONBGLTcmHnCop
I had to extract the audio using TSMuxerGUI "Demux" option, since eac3to failed to do so.
Old 24th November 2016, 03:35   #197  |  Link
tebasuna51
tebasuna51's Avatar
Yep, I can reproduce the problem.
Reported to madshi http://bugs.madshi.net/view.php?id=450
Old 21st May 2017, 18:40   #198  |  Link
tebasuna51
tebasuna51's Avatar
New version 1.2.3
Changelog
- v1.2.3 2017-05-21 The exe (or link) support Drag & Drop.
Extract Info from mkv's.
Audio Recode use ffmpeg if don't found a proper decoder.
Audios cut with Trim's of .avs
Offset in Delays of srt's, ass, etc.
Old 21st May 2017, 19:16   #199  |  Link
SeeMoreDigital
Bloody marvellous
Old 10th June 2017, 20:33   #200  |  Link
tebasuna51
tebasuna51's Avatar
New version 1.2.4
Changelog
- v1.2.4 2017-06-10 Video recode: x265 support using avs4x26x.exe
Audio recode: Decode to W64 (always ffmpeg) or WAV.
Encode to EAC3 (ffmpeg), bitrate with prefix 'E'
Merge mono-channels WAV with sufix L,R,C,LFE,...
