Old 13th October 2013, 19:25   #1161  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Please make a clean re-install of Simple x264 Launcher and try again. I cannot help you with modified versions.
If you still encounter problems, then please:
Old 13th October 2013, 20:05   #1162  |  Link
Leinad4Mind
Please, DeInterlace me!
Leinad4Mind's Avatar
You are right, with a unmodified version, it update.
With an modified one, the message appears too, but on the log. And we can see the same information too.
Thanks to explain.
Who am I?! I'm GOD... 8for it... father of my godchilds.
Leinad4Mind is offline   Reply With Quote
Old 13th October 2013, 20:21   #1163  |  Link
LoRd_MuldeR
Software Developer
Please post a link to the exact modified x264 binary you are using and I might be able to implement a workaround...
Old 13th October 2013, 21:24   #1164  |  Link
LoRd_MuldeR
Software Developer
Well, here is a test version that adds support for the heavily modified progress output in Komisar's "kMod" build:
http://www.mediafire.com/download/n8...2013-10-13.exe
Please note that this will probably remain an exception, as I certainly won't try to support any modified build out there
(It's generally a very bad idea to modify the progress output, as this is likely to break x264 GUI's)
Old 13th October 2013, 22:08   #1165  |  Link
Leinad4Mind
Thanks, I'll try out later.
Old 17th October 2013, 19:32   #1166  |  Link
kypec
User of free A/V tools
kypec's Avatar
Awesome GUI getting even better!
a million for "Apply to all selected files" option when adding new jobs. Until now I had to click dozens of times on "Add job" with chosen template which was not that bad either when encoding series with more than 20 episodes at once but this option is simply amazing!
Thumbs up once again, Lord M!
kypec is offline   Reply With Quote
Old 5th November 2013, 02:23   #1167  |  Link
AGKnotUser
2.24 throws a compatabilty mode error with Win. 8.1 64 bit
Just tried to use version 2.24 with Windows 8.1 64 bit. When started a (paraphrasing) "...Launcher.exe cannot run in Windows Compatibility mode" message appears and asks to quit. If I go back to 2013-8-28 or 2013-10-13 it runs without incident. I'm not running in compatibility mode. Could you please have a look?
AGKnotUser is offline   Reply With Quote
Old 5th November 2013, 11:47   #1168  |  Link
LoRd_MuldeR
Software Developer
I think I have an idea. Will upload a fixed version when I'm back from work this evening...
Old 5th November 2013, 12:42   #1169  |  Link
AGKnotUser
Thanks for the quick response.
Old 6th November 2013, 01:00   #1170  |  Link
LoRd_MuldeR
Software Developer
New version is now available.
Old 6th November 2013, 01:25   #1171  |  Link
AGKnotUser
Thanks, that fixed the problem.
Old 6th November 2013, 12:49   #1172  |  Link
AGKnotUser
AVS Script Check
I see it does an avs script check now. It tells me my script doesn't look like an avs script when it is and the path and script name are displayed in 8.3 format not long file names. I have uploaded the script used.
File Type: zip avs_script.zip (501 Bytes, 31 views)
Old 6th November 2013, 15:07   #1173  |  Link
LoRd_MuldeR
Software Developer
First of all, Simple x264 Launcher is passing short (8+3) file names to Avs2YUV because Avisynth (latest stable release) does not support Unicode file names
Using short (8+3) file names is an unreliable hack, I know, but it's all we can do until they add proper Unicode support. x264 does support Unicode file names now, but until recently it had the same issue.
Secondly, the error message you are getting is not generated by Simple x264 Launcher, but by Avs2YUV. It probably means that your script has some kind of error and did not actually return a clip
When I try to run your script I get this:
infile 'C:\Temp\AVS_72~1.AVS' doesn't look like an avisynth script
error: Script error: there is no function named "SetMTmode"
(C:\Temp\AVS_72~1.AVS, line 2)
It's obviously because I don't use the "MT" branch of Avisynth and thus SetMTmode() doesn't exist. You will need Avisynth-MT to run this kind of script. Do you use Avisynth-MT ???
(There also are a bunch of plug-in's used in that script. Do you have all of the required plug-ins in your Avisynth "plugins" folder too?)
Old 6th November 2013, 15:25   #1174  |  Link
AGKnotUser
Thank you for the explanation. I'll check my script but it did run properly with a cmd file using avs2yuv. And yes, I am using the MT version AVISynth 2.6.
Edit: Ok, I guess I was just not used to seeing those messages as they did not appear in earlier versions of the launcher. The script seems to run though so no problem.
Old 6th November 2013, 20:53   #1175  |  Link
LoRd_MuldeR
Software Developer
After some more investigation, it seems the "doesn't look like an avisynth script" warning is not related to the error message I got at all.
Avs2YUV simply checks the input file name for an ".avs" extension and it will show a warning if no such extension is present. However that check is case-sensitive!
And since we are passing a "short" (8+3) file name - which happens to be all upper-case - Avs2YUV doesn't recognize the ".avs" extension
Old 7th November 2013, 02:00   #1176  |  Link
AGKnotUser
So now you have a choice to make. Unicode compatibility or a permanent avs script warning.
Old 7th November 2013, 12:17   #1177  |  Link
LoRd_MuldeR
Software Developer
The warning can be ignored safely, so it's just a "cosmetic" problem
I could either filter out that message so user never gets it to see or I could convert the "shot" name to lower case before passing it to Avs2YUV.
Or I could simply fix the check inside Avs2YUV...
Old 7th November 2013, 12:42   #1178  |  Link
szabi
Hi
This error message pop up when I want to start the application:
Of course aplication does not start.
What can be the solution?
bye
szabi
szabi is offline   Reply With Quote
Old 7th November 2013, 12:43   #1179  |  Link
LoRd_MuldeR
Software Developer
What version are you using? If you are not using v2.25 (Build #610) yet, please install the latest update.
Old 7th November 2013, 12:51   #1180  |  Link
szabi
This one: x264_x64.2013-11-03.exe
bye
szabi
