Old 15th June 2004, 09:17   #41  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Originally posted by SiXXGuNNZ
I was wondering if you could get me that older filter again, I dunno where the copy I downloaded went
If you want another copy please just click on the link provided (it should still work). That said, I think I might have to include one or Nero's older parsers with it too, as the newer versions seem a bit wobbly with other apps.... even in WMP9.
And thanks, I'm going to give the new GUI version of the app a go right now
Cheers
Old 15th June 2004, 21:56   #42  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
Cheers
thanks again
10,000 Bullets
10,000 Bullets Forums
Exploring the world of Cinema from the Arthouse to the Grindhouse™
SiXXGuNNZ is offline   Reply With Quote
Old 4th October 2007, 15:44   #43  |  Link
snowden
snowden's Avatar
Originally Posted by mikeX View Post
from Alex Noe's homepage
But what the application should do is change the AR in the MPEG4 bitstream, not in the particular container header (although that would make a nice addition)
what the hell is going on? read the third post here (the google snippet) http://www.google.com/search?hl=en&c...ER&btnG=Search
and you will see it says the videopropertyheader is NOT supported by directshow. yet i thought in the rest of this post it is established that it is in fact the BITSTREAM that is not supported by directshow...can somebody clarify this?
snowden is offline   Reply With Quote
Old 4th October 2007, 15:52   #44  |  Link
SeeMoreDigital
Look at the dates of the posts in this thread...
Just about every MPEG-4 direct-show decoder I know of supports aspect ratio signalling detection now!
Cheers
Old 4th October 2007, 15:58   #45  |  Link
snowden
snowden's Avatar
yeah, funny thing is i was using a modded version of mpc (home theater), and it keeps the previous file position in memory...i just pressed the spacebar to pause it now, and the ar just changed. can't believe it! :lol:
EDIT: now it isn't working, i dunno what's going on.
