Old 19th December 2008, 00:54   #181  |  Link
tomos
and of course us ATi card users who dont get cool stuff like this
tomos is offline
Old 19th December 2008, 01:19   #182  |  Link
rica
One year and a half:
Two Ati cards in my bin while my 8600GTS is still on my PC....
Still 2/3 ratio....
Last edited by rica; 20th December 2008 at 18:42. Reason: corrected the mistake "two years"
rica is offline
Old 19th December 2008, 02:44   #183  |  Link
CruNcher
CruNcher's Avatar
@tomos
don't want to go to much oftop there could still be light at the tunnel for you i hope AMD/ATI gonna do the right thing and go as open as Nvidia with their UVD2 support for non licensed Developers
http://www.phoronix.com/scan.php?pag...dpau_gpu&num=1 <- this is unique a very long time Linux waited for that and Nvidia made it reality 1 AMD/ATI are currently slow and behind Nvidia. It isn't over yet, though the question remains are AMD/ATI gonna support non licensed Developers on UVD2 and bring out a patch for Mplayer ?
Don't supporting those wouldn't fit in their strategy they already gave access to their Driver but keep UVD2 a 3rd Party Licensed Developer Secret ? (btw Nvidia goes the other way keeping their Driver a Secret opening VP2).
Still a Main Standard needs to be developed for Linux but it's a first direct step to SOA Hardware Video Decoding by both. Just lets wait for next month and see what and how AMD/ATI is gonna offer Developers for Linux and Windows alike in terms of UVD2 access they could gain at least under Linux the head with being complete open by then . Also another thing which imho is of interest is the question of are UVD2 and VP2 programmable ??? could they be leveraged for other Video Codecs in the future by updating (somekind of pre loaded firmware inside the Driver ?). This way Nvidia for example maybe could even add X264 High Predictive Support in future Driver releases
http://www.youtube.com/watch?v=woq2gZOGQeg <- 100% CPU utilized playback via libavcodec
http://www.youtube.com/watch?v=Cw1IZuskREU <- 100% CPU utilized playback via Nvidia VDPAU VP2 Hardware
http://www.youtube.com/watch?v=U7R90A7ZqLU <- And this is what im 100% sure by now what we have in our Nvidia/ATI GPUs working (a dedicated Video Processor a ARM11 logic for Nvidia the same Video Engine inside the APX 2500)
Nothing different to what ST Micro, Broadcom, Sigma and others Develop, just by Nvidia and ATI and in reality this has nothing todo with CUDA @ all should be complete independent of it just called that way for Marketing Purposes, everything that comes after the Bitstream Decoding though is Shader based (ouput via Direct3D on Windows) and so CUDA like Deinterlacing, DeNoising, Scaling soon Super resolution Conversion and could potentially need some CPU time
It is about Time
CruNcher is offline
Old 19th December 2008, 02:49   #184  |  Link
laserfan
Aging Video Hobbyist
It would be nice to think that, but the community of Avisynth afficionado's is pretty small... 9600GT is a good choice for price/performance.
Small, but wirey (read: influential)!!!
Thanks for the tip on the card (which I see is only $90 bucks BFG Tech at Frys atm).
laserfan is offline
Old 20th December 2008, 15:41   #185  |  Link
menlvd
neuron2
can U add option to disable demuxing audio (from ts/m2ts...) when creating project?
menlvd is offline
Old 20th December 2008, 15:53   #186  |  Link
It's already there:
Audio/Audio Demux/Clear All
Guest is offline
Old 20th December 2008, 15:54   #187  |  Link
menlvd
It's already there:
oops sorry
menlvd is offline
Old 21st December 2008, 08:40   #188  |  Link
jpsdr
Hello.
A little question. I've a PC made specialy for video processing encoding.
As i don't need high 3D capability, i've buy for it a simple little nVidia 6600.
I don't care about speed, but is it possible to use DGVC1DecNv with it ?
If not, which is the first or "lowest" nVidia card that support DGVC1DecNV ?
jpsdr is offline
Old 21st December 2008, 09:15   #189  |  Link
nm
No, CUDA doesn't run on it and the GPU doesn't have a VP2 video decoding unit.
GeForce 8400 GS (try to get a G98-based model), but if you ever want to use the GPU for filtering HD video, I'd recommend a bit more powerful card (8500/8600/9400/9500GT).
nm is offline
Old 21st December 2008, 09:48   #190  |  Link
jpsdr
Thanks for the answer.
I've look at the prices, and i think i'll buy a 9600GT.
jpsdr is offline
Old 28th December 2008, 19:44   #191  |  Link
DGVC1DecNV 1.0.1
Originally Posted by Audionut View Post
Another issue I found is when trimming material. The resulting .dgv file has 2 beginning frames of macro blocked garbage.
* DGVC1DecodeNV now replaces leading orphaned B frames with copies of the first decodable frame. This avoids delivering macroblocked frames when cutting at an open GOP.
http://neuron2.net/dgvc1decnv/dgvc1decnv101.zip
Guest is offline
Old 29th December 2008, 11:45   #192  |  Link
dael
OSS VC-1 Decoder in ffmpeg
there is an open source decoder for VC-1 in current ffmpeg(libavcodec) (http://ffmpeg.org/index.html). Is it possible to use this lib to build a DGVC1Dec that is independent from nvidia cards?
Regards,
Daniel.
dael is offline
Old 29th December 2008, 12:15   #193  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Have you already tried using ffmpegSource?
now playing: [artist] - [track] ([album])
Leak is offline
Old 29th December 2008, 12:21   #194  |  Link
dael
Cool, thanks for the hint. I will try it out. Any Experiences with *.m2ts?
dael is offline
Old 29th December 2008, 13:13   #195  |  Link
G_M_C
Many, m2ts is just a container you know.
G_M_C is offline
Old 29th December 2008, 14:20   #196  |  Link
@dael
Please take off topic discussion elsewhere.
Guest is offline
Old 29th December 2008, 14:39   #197  |  Link
Audionut
Thanks for the update.
Audionut is offline
Old 1st January 2009, 05:51   #198  |  Link
~bT~
н∂-ƒαиαтι¢
Hi neuron2,
is the NVIDIA GeForce 8600GS supported?
~bT~ is offline
Old 1st January 2009, 07:18   #199  |  Link
I believe so.
Guest is offline
Old 1st January 2009, 14:45   #200  |  Link
~bT~
н∂-ƒαиαтι¢
this is the card i have: http://support.packardbell.com/uk/it...amadeus_ipower
i don't see any info on CUDA.. pls help.
~bT~ is offline
