Old 6th September 2008, 09:36   #961  |  Link
gigah72
Originally Posted by chriszxl View Post
ya...me too...serious bug...
965 fixed this
gigah72 is offline   Reply With Quote
Old 6th September 2008, 09:36   #962  |  Link
lucassp
I'm trying to backup a DVD Video with x264 (the build from MeGUI) on Vista x64 but it crashes at the beginning. The avs script is playable in Media Player. Does x264 work with Vista x64?
lucassp is offline   Reply With Quote
Old 6th September 2008, 09:59   #963  |  Link
techouse
Strictly Rhythm
techouse's Avatar
x264_x86_r965_techouse
Source: x264 r965 GIT (git://git.videolan.org/x264.git)
Applied patches (current versions):
x264_progress.indication_r957.diff
x264_psy_rdo.0.6_r957.diff
x264_hrd_pulldown.09_interlace.diff
x264_new_bframe_decision_04.7.diff
Please check http://forum.doom9.org/showthread.php?t=130364 and http://git.videolan.org/gitweb.cgi?p=x264.git;a=shortlog for more info
Compiled by techouse on September 6th 2008, 10:50:33 CEST with GCC-4.3.2 on Windows Vista Business SP-1 64-bit.
Commandline used: ./configure --extra-cflags="-march=core2 -pipe" && make fprofiled
Platform:   X86
System:     MINGW
asm:        yes
avis input: yes
mp4 output: yes
pthread:    yes
gtk:        no
debug:      no
gprof:      no
PIC:        no
shared:     no
visualize:  no
techouse is offline   Reply With Quote
Old 6th September 2008, 14:54   #964  |  Link
gav1577
gav1577's Avatar
Originally Posted by Dark Shikari View Post
Indeed, there was a subtle test case in which it failed (a very rare one which almost never crops up... almost) and thus slipped past our regression tests.
Thanks for the report, fixed in r965.
Works perfect now thanks
gav1577 is offline   Reply With Quote
Old 6th September 2008, 15:07   #965  |  Link
saint-francis
too much lurking
saint-francis's Avatar
There is a new version on the update server which works.
saint-francis is offline   Reply With Quote
Old 6th September 2008, 15:12   #966  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
sure... i just updated it. damn, i did 3 test encodes with r964 and everything was ok... i was pretty sure that build was working fine...
well, 965 is up... so there should be no more problems.
Old 6th September 2008, 15:20   #967  |  Link
lucassp
Still no go
Old 6th September 2008, 15:29   #968  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
? did yo update to r965 ?
Old 6th September 2008, 19:35   #969  |  Link
Ranguvar
Ranguvar's Avatar
Originally Posted by techouse View Post
Ranguvar:
I guess you got GCC-4.3.2 from TDM's website and have overwritten all your old files with the new ones from TDM's zip/tar.gz packages. The problem is that the gcc-4.3.2-tdm-1-core.tar.gz package includes pthreadGC2.dll and pthreadGCE2.dll in its /bin folder, libpthreadGCE2.a, libpthreadGC2-static.a and libpthread.a in its /lib folder and pthread.h, sched.h and semaphore.h in its /include folder. You probably copied over those files to your MinGW /bin, your MinGW /include and your MinGW /lib folder folder.
I suggest you remove all these files, get the latest pthread cvs (cvs -d server:anoncvs@sources.redhat.com:/cvs/pthreads-win32 checkout pthreads), compile (make clean GC-static) and install it (copy libpthreadGC2.a to your MinGW /lib folder and copy pthread.h, sched.h and semaphore.h to your MinGW /iclude folder). That way you will eliminate the need of x264.exe for an extra pthreadGC2.dll in C:\Windows\System32.
Trust me on this one, I had the same problem.
I also suggest you people update your GPAC libraries. Many have reported errors building it from CVS, however I have found a nasty trick that actually works:
1. download the old stable tarball from here http://downloads.sourceforge.net/gpa...4.4-rc2.tar.gz
2. once it is downloaded, extract it to your MSYS /home/username folder and cd into it (i.e. cd /home/username/gpac)
3. while inside the gpac folder get the latest GPAC CVS using the command cvs -z3 -dserver:anonymous@gpac.cvs.sourceforge.net:/cvsroot/gpac co -P gpac
4. run ./configure && make lib
5. copy /home/username/gpac/include/gpac to your MinGW /include folder
P.S.: If this doesn't work for you try it in your /home folder (i.e. /home/gpac).
Thanks very much The problem was that I somehow got that damn DLL into my PATH without knowing it, so I thought my build was good.
Ranguvar is offline   Reply With Quote
Old 6th September 2008, 19:54   #970  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
i don't even bother with 'installing' the gpac/pthread library/include files..
it's easy enough to add
--extra-cflags="-I../pthreads -I../gpac/include" --extra-ldflags="-L../pthreads -L../gpac/bin/gcc"
to x264 configure to tell it where the files are without having to install them
especially useful when building multiple versions
since i do -march athlon-xp and pentium2 builds
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 6th September 2008, 20:54   #971  |  Link
komisar
komisar's Avatar
I updated my previous message about speed comparsion of GCC here: http://forum.doom9.org/showthread.ph...32#post1179832
[965] My CLI and VFW VAQmod builds found here: http://komisar.gin.by/
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 6th September 2008, 21:09   #972  |  Link
techouse
Strictly Rhythm
techouse's Avatar
Huh? I've been encoding with x264 on a Vista Business x64 since the dawn of time and have never had any problems with it. Check your filters and AVS.
P.S.: I'm just guessing, but did you crop the file right?
Old 6th September 2008, 21:26   #973  |  Link
skystrife
skystrife's Avatar
x264.965.modified.exe - Alternate Download
Patches used:
x264_psy_rdo_0.6_r956.diff
gcc 3.4.5 fprofiled build with -march=pentium2.
skystrife is offline   Reply With Quote
Old 6th September 2008, 22:39   #974  |  Link
burfadel
x264 works fine on both Xp x64 and Vista x64
Old 7th September 2008, 10:56   #975  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
Post your script, and maybe open a separate thread for it
Make sure it contains a ConvertToYV12() somewhere (preferably at the end), otherwise x264 won't accept it.
If it does, do other builds behave the same way ?
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 7th September 2008, 16:52   #976  |  Link
lucassp
DGDecode_mpeg2source("D:\Test\VIDEO_TS\file.d2v",info=3)
ColorMatrix(hints=true,interlaced=true)
#Load_Stdcall_Plugin("C:\Program Files (x86)\Encodings\megui\tools\yadif\yadif.dll")
#Yadif(order=-1)
#crop
#resize
#denoise
Trim(5000,7000)
Old 7th September 2008, 18:01   #977  |  Link
Ranguvar
Ranguvar's Avatar
@komisar: I see you have a LOT of minor patches on your website. Would you mind explaining what they do, in fairly basic terms? Mostly the following:
k.38.cosmetic.diff
999.log_param.diff
x264_32x32samples_crash.r870.diff
k.20.x264_fix_stats_file_work.r877.diff
x264_multithreading_Nth_pass_ratecontrol.r870.diff
bm_x264_thread_pool.r870.diff
k.41.x264_log_file.01k.r928.diff
Thanks!
Old 7th September 2008, 18:40   #978  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
k.38.cosmetic.diff
changes x264 signature in crf mode to use 4 digits after the decimal instead of just 1
also adds a long \r line to clear output from progress before printing stats <--- already implemented in r957.
999.log_param.diff
writes the x264 generated signature to the stderr/log file
looks to be an overhaul of the stats file writing and includes a padding mechanism for vfw compatibility
implements http://en.wikipedia.org/wiki/Thread_pool_pattern
adds the log-file parameter to log output to a file
(imo easier to just use tee)
Old 7th September 2008, 19:05   #979  |  Link
Ranguvar
Ranguvar's Avatar
Thanks, kemuri!
Thread pool pattern looks interesting. I'll try a build with and without it, and compare.
Any ideas on x264_multithreading_Nth_pass_ratecontrol.r870.diff?
Old 7th September 2008, 21:14   #980  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
looked at it again and it's definitely complexing up the bitrate approximation/ratecontrol so it should be more accurate.
that is, bitrate aiming in multi-threading should be more accurate (though i don't usually have a problem with this in x264 as is)
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
