21st January 2014, 12:24 | #721 | Link |
@mawen1250,
dither-1.24.0.zip contains this mod which seems to work OK Code:
Function Dither_replace_string (string str, string findstr, string repstr) { strl = LCase (str) findstrl = LCase (findstr) lenf = StrLen (findstr) pos = FindStr (strl, findstrl) pos2 = (pos <= 0) ? 1 : pos # EDIT: seems superflous rep = (pos <= 0) ? "" : LeftStr (str, pos-1) + repstr + Dither_replace_string (MidStr (str, pos + lenf), findstr, repstr) return ((pos <= 0) ? str : rep) } Your version with the added '-1' causes Avisynth halt without producng clip or error message and is not working as you expected. EDIT: Your version keeps trying to replace the same string over and over again, until it runs out of stack. EDIT: This Code:
colorbars Function Dither_replace_string (string str, string findstr, string repstr) { strl = LCase (str) findstrl = LCase (findstr) lenf = StrLen (findstr) pos = FindStr (strl, findstrl) # pos2 = (pos <= 0) ? 1 : pos rep = (pos <= 0) ? "" : LeftStr (str, pos-1) + repstr + Dither_replace_string (MidStr (str, pos + lenf), findstr, repstr) return ((pos <= 0) ? str : rep) } S = " x 32768 <= x x 32768 - ? " F=" x " R=" 123 " O=Dither_replace_string(S,F,R) RT_DebugF("%s\n%s",S,O) S2 = " x 32768 <= x x 32768 - ? " O2=Dither_replace_string(S2,F,R) RT_DebugF("%s\n%s",S2,O2) return Last Code:
00000013 72.02262115 [1948] RT_DebugF: x 32768 <= x x 32768 - ? 00000014 72.02263641 [1948] RT_DebugF: 123 32768 <= 123 x 32768 - ? # Problem 00000015 72.03427887 [1948] RT_DebugF: x 32768 <= x x 32768 - ? 00000016 72.03430176 [1948] RT_DebugF: 123 32768 <= 123 123 32768 - ? # OK
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st January 2014 at 14:21. |
21st January 2014, 13:03 | #722 | Link | |
Avisynth language lover
Try F=" x " R=" 123 " and you will see the issue mawen1250 is talking about. |
21st January 2014, 14:12 | #723 | Link | |
I think his point is that the way the function is used in Dither_lut16, both the search and replacement strings always have added spaces, so his fix works. |
21st January 2014, 15:54 | #724 | Link |
Thank you big G, you got me there.
As omission of space could cause problem, how bout this: Code:
colorbars Function Dither_replace_string_MOD (string str, string findstr, string repstr) { strl = LCase (str) # case independent for FindStr findstrl = LCase (findstr) # lenf = StrLen (findstr) pos = FindStr (strl, findstrl) lenr = Strlen(repstr) # Below string comparison 'RightStr(repstr,1) == LeftStr(findstr,1)' is case insignificant # If last char in replace matches 1st char in find, then # we replace with all but last char of replace, and re-search remainder but with prepended first char of replace. rep = (pos <= 0) \ ? "" \ : (lenf>1 && lenr>1 && RightStr(repstr,1) == LeftStr(findstr,1)) \ ? LeftStr (str, pos-1) + LeftStr(repstr,lenr-1) + Dither_replace_string_MOD (RightStr(repstr,1) \ + MidStr (str, pos + lenf), findstr, repstr) \ : LeftStr (str, pos-1) + repstr + Dither_replace_string_MOD (MidStr (str, pos + lenf), findstr, repstr) return ((pos <= 0) ? str : rep) } S1 = " x 32768 <= x x 32768 - ? " F=" x " R=" ABC " O1=Dither_replace_string_MOD(S1,F,R) RT_DebugF("S1='%s' : F='%s' R='%s'\nO1='%s'\n",S1,F,R,O1) R="ABC" O2=Dither_replace_string_MOD(S1,F,R) RT_DebugF("S1='%s' : F='%s' R='%s'\nO2='%s\n",S1,F,R,O2) S2 = " x 32768 <= x x 32768 - ? " F=" x " R=" ABC " O3=Dither_replace_string_MOD(S2,F,R) RT_DebugF("S2='%s' : F='%s' R='%s'\nO3='%s\n",S2,F,R,O3) R="ABC" O4=Dither_replace_string_MOD(S2,F,R) RT_DebugF("S2='%s' : F='%s' R='%s'\nO4='%s\n",S2,F,R,O4) return Last Code:
00000005 2.31286550 [2940] RT_DebugF: S1=' x 32768 <= x x 32768 - ? ' : F=' x ' R=' ABC ' 00000006 2.31392574 [2940] RT_DebugF: O1=' ABC 32768 <= ABC ABC 32768 - ? ' 00000007 2.31412077 [2940] RT_DebugF: 00000008 2.33118415 [2940] RT_DebugF: S1=' x 32768 <= x x 32768 - ? ' : F=' x ' R='ABC' 00000009 2.37454796 [2940] RT_DebugF: O2='ABC32768 <=ABCABC32768 - ? 00000010 2.37459588 [2940] RT_DebugF: 00000011 2.39530826 [2940] RT_DebugF: S2=' x 32768 <= x x 32768 - ? ' : F=' x ' R=' ABC ' 00000012 2.39533472 [2940] RT_DebugF: O3=' ABC 32768 <= ABC ABC 32768 - ? 00000013 2.39536095 [2940] RT_DebugF: 00000014 2.40840435 [2940] RT_DebugF: S2=' x 32768 <= x x 32768 - ? ' : F=' x ' R='ABC' 00000015 2.41166806 [2940] RT_DebugF: O4='ABC32768 <=ABCx 32768 - ? 00000016 2.41172385 [2940] RT_DebugF: Not much testing but seems to work. Spot any problems Gavino ? PS, Whatever happend to the 'quick reply' spell checker when I was on 'vacation' ??? EDIT: This causes silent crash in Mawen1250 mod, no error message, could be hard to trace bug Code:
S1 = " x 32768 <= x x 32768 - ? " F="x" R="A" O1=Dither_replace_string(S1,F,R) Code:
00000005 2.15423131 [2144] RT_DebugF: S1=' x 32768 <= x x 32768 - ? ' : F='x' R='A' 00000006 2.15425491 [2144] RT_DebugF: O1=' A 32768 <= A A 32768 - ? '
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st January 2014 at 17:23. |
22nd January 2014, 05:02 | #725 | Link |
The original Dither_replace_string works correctly for pure linear string replacement, but it is only used in Dither_lut16, while the string replacement in Dither_lut16 is somewhat meant to be non-linear...
So the modified Dither_replace_string should be renamed to something like Dither_expr_replace_string IMO. Last edited by mawen1250; 22nd January 2014 at 05:08. |
22nd January 2014, 11:30 | #726 | Link |
Because there isn’t currently any operator starting with the letter "x", I think replacing " x" instead of " x " in Dither_lut16_expr() is a simpler solution.
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding |
2nd March 2014, 09:37 | #727 | Link |
Dither 1.25.0:
dither 1.28.1 for AviSynth | avstp 1.0.4 for AviSynth development | fmtconv r30 for Vapoursynth & Avs+ | trimx264opt segmented encoding Last edited by cretindesalpes; 3rd March 2014 at 22:14. |
2nd March 2014, 13:44 | #729 | Link |
Do you mean avstp.dll? Most likely not. With this 64-bit version, I’m supporting AviSynth+, not the old 64-bit AviSynth which is abandoned. Avs+ already has frame-based multi-threading capabilities, and I’ll probably make avstp use its internal thread pool interface in the future.
3rd March 2014, 22:11 | #732 | Link |
Damn! Your’re right. Fixed in Dither 1.25.1
5th March 2014, 21:41 | #733 | Link |
Just wondering... is this the expected encode speed for a Q8400 and 4GB RAM?
(avstp.dll is in the autoload plugin folder) Code:
setmemorymax(512) LoadPlugin("D:\Edição de video\MeGUI\tools\dgavcindex\DGAVCDecode.dll") LoadPlugin("D:\Arquivos de programas\AviSynth 2.5\plugins\removegrain\RemoveGrainSSE2.dll") LoadPlugin("D:\Arquivos de programas\AviSynth 2.5\plugins\removegrain\RepairSSE2.dll") LoadPlugin("D:\Arquivos de programas\AviSynth 2.5\plugins\removegrain\RSharpenSSE2.dll") LoadPlugin("D:\Arquivos de programas\AviSynth 2.5\plugins\outros\mt_masktools-26.dll") LoadPlugin("D:\Arquivos de programas\AviSynth 2.5\plugins\outros\AddGrainC.dll") LoadPlugin("D:\Arquivos de programas\AviSynth 2.5\plugins\outros\dither.dll") Import("D:\Arquivos de programas\AviSynth 2.5\plugins\outros\dither.avs") AVCSource("I:\BDMV Symphogear G Vol. 2\BDMV\STREAM\00003.dga") spline64resize(1280,720) dither_convert_8_to_16() gradfun3(lsb_in=true,lsb=true,smode=2) dither_out() |
5th March 2014, 23:24 | #734 | Link |
No idea. If you want to check the speed of the script, use AVSMeter. If you want to check the speed of x264, keep only AVCSource + resize and use 10bit-x264 with 8-bit input.
7th March 2014, 08:34 | #736 | Link |
Not right now. This is a serious beast, and I have things to finish before (porting dfttest and eedi3 to 64-bits/VS/Avs+/high bit depth). But I plan to work on it. I think Myrsloik and tp7 are already poking it too.
9th March 2014, 10:16 | #738 | Link |
Hello
When I try Martin53's AWB function, i get error " Unable to call Dither_convert_yuv_to_rgb(). Required dither package 1.23.0 or higher installed ? http://forum.doom9.org/showthread.php?p=1386559" I have writted this short script for checking LoadPlugin("C:\RT_Stats_25&26_dll_v1.30_20131219\Avisynth26\RT_Stats26.dll") LoadPlugin("C:\dither-1.25.1\win32\dither.dll") assert(RT_FunctionExist("""Dither_convert_yuv_to_rgb"""), "Unable to call Dither_convert_yuv_to_rgb().") return last I get the same error. I use avisynth 2.60A5 (CVS 20130920, ICL 10). What is missing ? Thanks |
9th March 2014, 10:58 | #739 | Link |
Yes, I'm weird.
@Bernardd:
Function Dither_convert_yuv_to_rgb is implemented as a script function in dither.avsi, so you need to import dither.avsi or have it in autoload folder.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain |
color banding, deblocking, noise reduction |
