5th September 2017, 20:14 | #26401 | Link | ||
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 6th September 2017 at 00:29. |
6th September 2017, 01:56 | #26403 | Link | |
Those are my thoughts on the situation. |
6th September 2017, 07:38 | #26404 | Link | |
6th September 2017, 11:37 | #26405 | Link |
Ah, OK. But still, that isn't the goal of BDRB. The idea is to take a Blu-ray and convert a BD50 to a BD25, or take the BD as input to put the movie into a MKV wrapped file, or take MKV files and author them into a Blu-ray. To take a 4K video and wrap it into a MKV file (I'm guessing 4K -> 1080p), is not within the scope of BDRB. As you said, other programs can to that.
Again, my thoughts on the matter. I could be way off base, or maybe not.
My Total Eclipse 2017 Photos My Nov 2019 Game of Thrones Tour My NEOWISE Comet Photos 2020 Last edited by MrVideo; 6th September 2017 at 12:12. |
8th September 2017, 17:39 | #26409 | Link |
My Sharp LED HDTV croaked today. This is way off topic except related to MKV through BD-RB, I know, and do NOT wish or want to start any debates or arguments and some of you keep tabs on the HDTVs stuff very well. Anyone know of a good new one that plays MKV containers via USB? I'm 40 to 55". I don't care about beyond 1080p, nor do I care about 3D. Perhaps one that displays PGS as well as SRT? I'm looking around also, but...curious if anyone here has noticed something cool? Around 300 to 600 dollars would be ok. I'd order local, probably Wal-Mart Online ship to store. Not all of them indicate on the box..
My old Sharp would sometimes jitter with some 1080p's...and I had to rerender them with same resolution for that to not happen. I think today's would be better at displaying.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 8th September 2017 at 17:42. |
9th September 2017, 11:02 | #26412 | Link | |
Error option Use X264s internal LAVF for frame serving
I want therefore ask what is difference between these options for Decoding/Frame serving and if have some influence on quality final videos? Use would other option if would know as though hasn't influence on quality final videos. Thank you staina |
9th September 2017, 13:03 | #26413 | Link |
@ staina; RE: influence on quality final videos.
I can't really say I've seen any difference in quality. I only use internal LAVF for frame serving, and FRIM if I do 3D. I do know you can't use DGDecNV unless you buy it, and as far as I KNOW there is no quality difference in which one you use since it's only feeding the x264 encoder or FRIME the frames. YMMV and I'm sure some versions are faster but I don't think quality is affected, unless you change the encoder speed setting to use the Good, Better or leave it on the Default High Quality 2 Pass, which is what I use. The size of what you are encoding and encoding it down to is what effects QUALITY more than the encoder used, I THINK. |
9th September 2017, 20:39 | #26414 | Link | |
Also, if you WISH to do so, you can add x264 command line 'Tweaks' very easily in BDRB as long as you kind of know what you are doing. This can 'tweak' the quality a bit more if you want. Otherwise, just as the fellow said, HQ 2 pass LAVF basically does it, especially if you are going to a BD-25. But, then again, as many say here (along with The Creator JD) if you just leave it on 'Auto' BDRB will find the 'best' balance between speed/quality. BUT... like some of us here, if you wanna squeeze a bit more or depending on the type of film / source, you can use the higher settings above. |
11th September 2017, 02:15 | #26415 | Link |
That was the aim, mate. I should have worded it a little differently.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! |
11th September 2017, 22:53 | #26416 | Link |
JD, I think I found a bug. I haven't done MKV to MP4 conversion in a long time. Or BD to Alternate MP4... At the moment, I'm checking MKV to MP4.
Imported some new and older MKVs. The MKVs contain SUP and SRT. During every import, whether with SUP and SRT they all show as Subtitles in BD-RB GUI. However, looking at WORKFILES, all are seen as SUPs. Not a single SRT is found. A created MP4 from that results, of course in not having SRT access. Perhaps have a look-see? I do not have SupTitle or Convert PGS to SRT active. Importing: Star Wars 1-The Phantom Menace.mkv TEMPIMPORT MUXIT.META Star Wars 1-The Phantom Menace.track_1.264 Star Wars 1-The Phantom Menace.track_2.AC3 Star Wars 1-The Phantom Menace.track_3.AC3 Star Wars 1-The Phantom Menace.track_4.AC3 Star Wars 1-The Phantom Menace.track_5.SUP Star Wars 1-The Phantom Menace.track_6.SUP Star Wars 1-The Phantom Menace.track_7.SUP Star Wars 1-The Phantom Menace.track_8.SUP Star Wars 1-The Phantom Menace.track_9.SUP Star Wars 1-The Phantom Menace.track_10.SUP Star Wars 1-The Phantom Menace.track_11.SRT Star Wars 1-The Phantom Menace.track_12.SRT WORKFILES 00000.track_4113.264 00000.track_4352.ac3 00000.track_4353.ac3 00000.track_4608.sup 00000.track_4609.sup 00000.track_4610.sup 00000.track_4611.sup 00000.track_4612.sup AUD_00000.meta AUD_00000_4352.AVS AUD_00000_4353.AVS mChapters.chp MUX_MOVIE_ONLY.meta VID_00000.AVS VID_00000.CHP VID_00000.DGI GUI 3 Audio files (streams) to enable/disable. 8 Subtitles to enable/disable. But in the Workfiles only have 5 SUPs. The SRT's are being converted for PSEUDO.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 11th September 2017 at 23:41. |
12th September 2017, 08:07 | #26417 | Link |
Trying to search this multi-page thread is like looking for a needle in a haystack.
I'm trying to find the option definitions for ONEPASS_ENCODING. The default is 2. I have no idea what 0, 1 or 2 define. The hiddenoptions text file doesn't have it listed. It seems that 2 = 1 pass encoding. I need 2 pass encoding. Thanks. |
12th September 2017, 19:49 | #26418 | Link |
Click on One-pass CRF/ABR to disable which ever is active and 2-pass will be activated.
12th September 2017, 21:43 | #26419 | Link | |
12th September 2017, 21:48 | #26420 | Link | |
Try selecting to only keep only the last two subs in the GUI... Last edited by jdobbs; 12th September 2017 at 21:52. |
