24th February 2018, 01:40 | #461 | Link |
objective2-slow https://people.xiph.org/~tdaede/sets/objective-2-slow/ has UHD content. Might be useful.
24th February 2018, 23:01 | #463 | Link | |
The new AV1 blurs even more than the older ones. I know it's primarily a video encoder, so it's not really tuned for still images, but in its current form it's not really doing a good job as an image encoder. However, PIK is really interesting. It basically behaves like a much more efficient JPEG. It has blocking and ringing artifacts, but preserves much more details than the other encoders. I sure prefer it over the artifactless, but sterile looking and blurry AV1 or HEVC images. |
26th February 2018, 02:11 | #464 | Link | ||
26th February 2018, 11:43 | #465 | Link | |
An AVIF file should be a simplified and conformant version of an [HEIF] file. would imply this is basically HEIF with AV1 as still image codec, which is a sensible choice. Not a big fan of the ringing artefacts in PIK, those bother me quite a lot more. |
26th February 2018, 13:19 | #466 | Link | |
4th March 2018, 12:09 | #468 | Link |
Here is the buglist for the bitstream:
https://bugs.chromium.org/p/aomedia/...mary&cells=ids Presumably once all of those have been fixed the bitstream can be frozen. Looks like everyone is working on weekends to get this thing done. Last edited by bstrobl; 4th March 2018 at 12:23. |
4th March 2018, 15:11 | #469 | Link | |
It is down to 75 bugs, 2.5 weeks ago it was at 215 bugs so probably another 1-2 weeks or so until it is ratified. |
4th March 2018, 18:40 | #470 | Link | ||
It's up there: https://wyohknott.github.io/video-formats-comparison/ I haven't added AV1 yet, I'm waiting for the bitstream freeze. Let me know what you think would be good to add. I put most of the graph I thouqgt would be useful. I wish I could addsome examples videos to plày side by side but I don't know how to do that. |
4th March 2018, 19:47 | #471 | Link |
Each Y4M videos is exported to 4:2:0 10 bits Y4M with FFMPEG: ffmpeg -y -i [input] -pix_fmt yuv420p10le -strict -1 [output] Video compression All videos are compressed over a range of qualities for each encoder: •AV1: ◦between q=12 and q=60, with a step of 4: aomenc --cpu-used=2 --tile-columns=4 --passes=2 --pass=1 --bit-depth=10 --input-bit-depth=10 --end-usage=q --cq-level=$q --fpf=[output].log -o [output] [input(Y4M_10bits)] aomenc --cpu-used=2 --tile-columns=4 --passes=2 --pass=2 --bit-depth=10 --input-bit-depth=10 --end-usage=q --cq-level=$q --fpf=[output].log -o [output] [input(Y4M_10bits)] •VP9: ◦between q=12 and q=60, with a step of 4: vpxenc --tile-columns=4 --row-mt=1 --passes=2 --cpu-used=2 --bit-depth=10 --input-bit-depth=10 --profile=2 --end-usage=q --cq-level=$ -o [output] [input(Y4M_10bits)] •x264: ◦between q=12 and q=40, with a step of 2: x264 --profile high10 --preset slower --input-depth=10 --output-depth=10 --crf $q -o [output] [input(Y4M_10bits)] •x265: ◦between q=12 and q=40, with a step of 2: x265 --profile main10 --preset slower --input-depth=10 --output-depth=10 --crf $q -o [output] [input(Y4M_10bits)] Code:
ffmpeg.exe -loglevel verbose -i "[input(your_colorspace).raw]" -an -f yuv4mpegpipe -vf scale=1920:1080:in_color_matrix=rgb:in_range=full:out_color_matrix=bt2020_ncl:out_range=full,format=yuv422p10le -strict -1 - ffmpeg.exe -loglevel verbose -i "[input(your_colorspace).y4m]" -an -f yuv4mpegpipe -vf scale=1920:1080:in_color_matrix=S_gamut3:in_range=full:out_color_matrix=bt2020_ncl:out_range=full,format=yuv422p10le,lutyuv=val:val:val -strict -1 - Code:
aomenc.exe --bit-depth=10 --input-bit-depth=10 --i4?? --codec=av1 --good --threads=? --cpu-used=? --profile=3 --drop-frame=(0 or 100 depends on fps) --end-usage=q --cq-level=48 --target-bitrate=0 --min-q=?(the problem bitrate of the first frame) --kf-max-dist=GOP --auto-alt-ref=? --frame-boost=? --aq-mode=0 --color-space=bt2020 --verbose --debug --pass=? --passes=? --output="xxx.webm" - (where is range full?) Code:
x264.exe --demuxer y4m --input-csp i4?? --input-depth 10 --input-range pc --output-csp i4?? --threads ? --preset slow --tune grain --crf 28 --fps ??.??? --keyint 60 --nal-hrd none --vbv-bufsize 40000 --vbv-maxrate 40000(use for web or don't use) --colormatrix bt2020nc --colorprim bt2020 --transfer bt2020-10 --range pc --output "xxx.h264" - |
5th March 2018, 08:07 | #472 | Link | |
"x265: https://github.com/google/pik. The version used is built from GIT revision 3cf3839f82bb177c43449ab10792c184c4485d8b" |
5th March 2018, 13:26 | #473 | Link | |
I think XVC encoder could be interesting to see. I know it's a proprietary codec, but quality-wise, in my experience, it competes quite well with x265 and AV1. |
5th March 2018, 23:33 | #475 | Link |
Just for you ... I created a "samples" subdirectory in my AOM MediaFire folder; it contains a WebM clip of "foreman" in PAL CIF resolution, encoded with AOM encoder v0.1.0-8300-g088217b2e (built Feb. 27, I hope that's recent enough) with '--cpu-used 8' (supposed to be a faster preset). Encoding took 3/4 hour on this aged PC with AMD Phenom-II (max. SSE2).
Tomorrow I could try a newer one with faster hardware. |
6th March 2018, 16:13 | #476 | Link |
A few more uploads: AOM v0.1.0-8449-g6471e8bd7 and samples with "--cpu-used [8..4]" to compare speeds (encoded on an AMD FX-6300). Disillusioning...
Pass 2/2 frame 300/300 469809B 12528b/f 313206b/s 769973 ms (0.39 fps) Pass 2/2 frame 300/300 460022B 12267b/f 306681b/s 841144 ms (0.36 fps) Pass 2/2 frame 300/300 449454B 11985b/f 299636b/s 921242 ms (0.33 fps) Pass 2/2 frame 300/300 448798B 11967b/f 299198b/s 1044732 ms (0.29 fps) Pass 2/2 frame 300/300 448035B 11947b/f 298690b/s 1214326 ms (0.25 fps) |
6th March 2018, 23:03 | #480 | Link |
Thanks for the new build.
Despite all the SIMD optimizations and other improvements, this build is actually even slower than build #8039. The quality seems visually very similar, the metrics as well. I was curious what AV1 is capable of with all the compression tools enabled, so i tried --cpu-used=0 on a 50 frames long, 720*288 video. It took almost 6 hours to encode. |
