Old 14th May 2013, 02:29   #81  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Originally Posted by Rumbah View Post
Photoshop saves jpegs automatically with subsampling depending on the quality you choose (if I remember it correctly 4:2:0 with quality <=6 or 50% with save for web, 4:4:4 above).
this is true. but at this point you don't care much about quality so you won't benefit from having no subsampling anyway. I don't remember the case when had so save jpeg with something other than high quality. In fact most of the time I use 10-12. Most of the images I save have gradients of some sort.
The point is that after I saved gradient in webp with max quality, cause of subsampling or some other thing it looks bad compared to jpeg.
This is exactly my thoughts too:
Originally Posted by Glenn Maynard@google groops
don't believe a niche image format like this will ever be widely-adopted. I hope it isn't, because adoption of a niche format designed solely to save bandwidth will slow the creation and adoption of the *real* successor to JPEG.
Old 14th May 2013, 11:55   #82  |  Link
dapperdan
Originally Posted by mandarinka View Post
My results were much more modest (webp lossless filesizes were pretty unimpressive). Try if you don't get better compression with lossless jpeg 2000 or jpeg-XR (the former achieves better ratios). Make sure though that your software uses the reversible transform and yuv conversions. Jasper (also used in imagemagick) apparently fails to.
WebP lossless is basically a different file format from WebP. It's much more PNG-like rather than a lossless version of JPEG.
So you'd expect it to do better on typical web icon type images rather than photos (and it does: http://extrememoderate.wordpress.com/2011/11/28/a-web-centric-image-compression-benchmark/).
This is a fairly direct consequence of WebP in general being designed around making web images smaller and faster. If you've got a photorealistic image then the fastest, most efficient way to deliver it in a webpage is using lossy compression.
dapperdan is offline   Reply With Quote
Old 14th May 2013, 17:41   #83  |  Link
IgorC
Originally Posted by Keiyakusha View Post
Even on official WebP presentation page all images converted to png for display. What joke is that?
Provide a link where only .png were posted.
IgorC is offline   Reply With Quote
Old 14th May 2013, 18:04   #84  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
I never said that "only png were posted". webm is there too, one of them even embedded in one of my posts. Here is a link for you, but I suggest to re-read what I said about png and browsers support.
Old 14th May 2013, 18:52   #85  |  Link
filler56789
SuperVirus
filler56789's Avatar
Hummm, I use Opera 11.64, and it supports only "normal" WebP. Lossless and lossy-with-alpha-channel get replaced with a placeholder : - /
And no, "full WebP support" is not a good reason for switching to Chrome/Chromium.
filler56789 is offline   Reply With Quote
Old 14th May 2013, 19:53   #86  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
The lastest Opera is 12.15. And it supports both webp lossless and lossy with alpha.
vivan is offline   Reply With Quote
Old 14th May 2013, 20:26   #87  |  Link
filler56789
SuperVirus
[OT]
Opera 12.xx dropped the "Windows Native Skin"
[/OT]
Old 14th May 2013, 20:27   #88  |  Link
benwaggoner
Originally Posted by tuqueque View Post
@mzso... Boy, WebP is not only superior to JPEG in 95% of cases, but in Lossless mode is superior to PNG in 99% of cases... I'm already switching all of my "raw" lossless data to WebP and have saved around half the space. And considering that I work with PNG sequence animations, that's GBs of information I've saved!
I think there's a lost opportunity to use H.264 High Profile IDR frames as a still image format. Efficiency is better than WebP, and we'd get hardware decode support on most devices.
HEVC promises to be a very good still image format, particularly at high resolutions.
Getting support for arbitrary bit depths and channels would be great for all these formats, of course, so they could be used for RAW Bayer pattern and that sort of thing. I wish JPEG XR had taken off...
Ben Waggoner
My Compression Book
benwaggoner is online now   Reply With Quote
Old 14th May 2013, 22:56   #89  |  Link
pieter3d
HEVC even has a special profile just for still images.
pieter3d is offline   Reply With Quote
Old 14th May 2013, 23:06   #90  |  Link
pieter3d
Here's what I know about VP9 coding tools.
64x64 "superblocks". Each divisible vertically, horzontally or quad. Quad divisions are recursive, so you can have any shape NxM, where N and M are 2^(2..6), and never more than 1 power apart (e.g. 4x4, 16x32, 8x4, 64x64 ... etc).
128x128 support is on the table, but undecided.
4 supported transforms: 4x4, 8x8, 16x16, 32x32. Yes this is the same as HEVC.
10 intra modes at any square size. 6 of these are directional.
1/8th pel motion comp, 8-tap filters. 3 filters (normal, blur, sharpen), selectable per prediction unit or frame.
3 ref pics per pic, but up to 8 pics to hold on to.
Discrete sine transform for intra blocks.
A second loop filter (analogous to SAO in HEVC) is under experimentation.
Bitstreams are still "data paritioned" like vp8, which is a pain for HW designs.
Entropy coding is similar to vp8.
Support for tiles, like HEVC, for parallel decode. Mandated above 2k resolution.
Support for lossless coding, as well as 4:4:4 with alpha.
The picture is still single-loop decodable to make HW implementations simpler.
Old 15th May 2013, 03:26   #91  |  Link
tuqueque
http://www.androidauthority.com/webm...outube-209088/ (Let's try to keep this thread WebM-wise and not another H.26x one.)
tuqueque is offline   Reply With Quote
Old 15th May 2013, 18:15   #92  |  Link
GTPVHD
http://i.imgur.com/cqIQh6y.jpg
From Google I/O 2013.
GTPVHD is offline   Reply With Quote
Old 16th May 2013, 08:52   #93  |  Link
kypec
User of free A/V tools
kypec's Avatar
Awesome comparison! (Not!) If only they published what settings were used for H.264: Profile, Level, CABAC/CAVLC, ref-frames, B-frames, frame resolution, rate etc. etc.
Otherwise it's plain marketing rubbish, nothing more.
kypec is offline   Reply With Quote
Old 16th May 2013, 09:11   #94  |  Link
nevcairiel
It was a quick video show in a keynote, of course its marketing. There is no time in such an event for technical details.
Old 16th May 2013, 09:16   #95  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Originally Posted by kypec View Post
Awesome comparison! (Not!):mad
They won't benefit from showing something like this Looks like On2 guys taught them how to do the marketing.
Old 16th May 2013, 09:49   #96  |  Link
dapperdan
The had a VP9-focused session directly after the keynote:
https://developers.google.com/events/io/sessions/325741299
But it's not one of the sessions being broadcast/recorded.
I assume they'll post the slides though.
edit: a news story based on the presentation
http://news.cnet.com/8301-1023_3-57584706-93/google-urges-fast-adoption-of-vp9-video-compression/
Best bits:
They claim VP9 saves ~50% bandwith compared with H.264 and is ~1% worse than H.265
There's a VP9 test channel:
http://www.youtube.com/user/WebMVP9/videos
And apparently you can turn on VP9 in Chrome today to view them.
Old 16th May 2013, 11:05   #97  |  Link
dapperdan
The actual bit of the keynote when they talk about VP9 vs H.264
http://youtu.be/9pmPa_KxsAM?t=1h11m47s
They repeat the ~50% figure given above, the slightly larger figure is only for that particular video.
Old 16th May 2013, 13:28   #98  |  Link
cogman
The Crazy Idahoan
Best bits:
http://www.youtube.com/watch?v=thtvQi6fEug&list=PLElsSrqQYMoHPY5k1l-X49OkW6Gz-9_zP&index=1
Ummm... wow, that is pretty terrible quality.
Grass is just one giant blob. Everything is VERY blocky, reminds me of the old xVid days. It is just really, well, terrible.
IDK, maybe the source video was this bad, but man, if they were trying to sell VP9 this video does them no favors.
cogman is offline   Reply With Quote
Old 16th May 2013, 13:42   #99  |  Link
mk.2
Wikipedia says that WebP only supports 8-bit YUV 4:2:0 Is it true?
I think it's true.
I just tried converting Dark Shikari's avatar to WebP with XnView.
Here is the result:    This is original:
And that was converted with the best quality setting which suppose to be lossless. I also tried converting with WebP plugin for Photoshop. It produced the same result with slightly smaller filesize.
mk.2 is offline   Reply With Quote
Old 16th May 2013, 16:33   #100  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
That just means that plugin doesn't support 4:4:4...
google, ngov, vp8, vp9, vpx, webm
