25th May 2020, 18:47 | #6901 | Link | |
Here is the log with out the fix I did. https://pastebin.com/KHaiZ5ZU Sent from my SM-G986U1 using Tapatalk Last edited by jlw_4049; 25th May 2020 at 19:14. |
26th May 2020, 14:27 | #6902 | Link |
It seems 64bit version of "msvcr100.dll" is needed:
https://www.microsoft.com/en-us/down....aspx?id=14632 "redist-5-64" wasn't downloaded at all in my case. |
28th May 2020, 18:37 | #6903 | Link | |
Thank you, Zathor. |
5th July 2020, 14:09 | #6907 | Link |
New D2VSource, can megui's author replaced dgindex with it??
Edit: Link https://github.com/Asd-g/MPEG2DecPlus |
7th July 2020, 17:19 | #6911 | Link |
Seems the MPbox package is incomplete, until a new version in MeGUI server you can download MP4Box 1.0.0 Windows 64-bit from https://www.videohelp.com/software/MP4Box, if your SO is 64 bits (if not the Download MP4Box 1.0.0 Windows version)
and extract some dll's to the ...\Megui\tools\mp4box or/and ...\Megui64\tools\mp4box I can do the mux with at least these dll's: avcodec-58.dll avdevice-58.dll avfilter-7.dll avformat-58.dll avutil-56.dll OpenSVCDecoder.dll postproc-55.dll swresample-3.dll swscale-5.dll
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 7th July 2020 at 17:37. |
14th July 2020, 12:43 | #6913 | Link |
Script generator for audio upmix using SuperEQ:
AviSynth+ does not implicitly convert any other sample format to float samples, so a ConvertAudioToFloat() should be added after opening the audio source and before using SuperEQ calls. |
15th July 2020, 14:15 | #6914 | Link |
I tried to build MP4Box in MABS. That worked, in general ... and then I discovered a mess: The help output is sent partially to stdout as well as stderr. Would not be surprised if there is more nonsense under the pressure of releasing a v1.0.0
MP4Box - GPAC version 1.0.0-rev115-g502bae149-ab-suite (c) 2000-2020 Telecom Paris distributed under LGPL v2.1+ - http://gpac.io GPAC Configuration: --prefix=/local64 --disable-shared --enable-static --static-mp4box Features: GPAC_CONFIG_WIN32 GPAC_64_BITS GPAC_MINIMAL_ODF GPAC_HAS_QJS GPAC_DISABLE_3D |
19th August 2020, 01:17 | #6918 | Link | |
29th September 2020, 06:28 | #6920 | Link |
MP4Box 1.0.0 rev236
http://www.mediafire.com/file/8ki8dm...GCC102.7z/file |
