Old 28th August 2019, 06:27   #57241  |  Link
pkerts
flat colors
I'm having a weird issue with flat colors, and wondering if someone can help. I'm using Asmodian max settings, a tuned 1080TI, a Samsung chg90. The colors seem noticeably flatter than VLC, the preview pane, and even an iphone. Here's the same clip in vlc, the windows preview pane, and mpc. And OSD
pkerts is offline   Reply With Quote
Old 28th August 2019, 07:26   #57242  |  Link
Siso
Soul Seeker
Siso's Avatar
Originally Posted by toki View Post
Does anyone know how to show chapter marks using mpc-be?
Options->Player->Interface->Use chapters marker.
Old 28th August 2019, 12:20   #57243  |  Link
toki
Thank you very much.
toki is offline   Reply With Quote
Old 28th August 2019, 16:22   #57244  |  Link
Siso
Soul Seeker
Siso's Avatar
No problem
Old 28th August 2019, 17:43   #57245  |  Link
cork_OS
cork_OS's Avatar
Originally Posted by SamuriHL View Post
Ewwww I've zero desire to integer scale. I'm sure that's a neat trick for ancient games or whatever but for video we have far more useful scaling in madvr.
I've not seen any comparisons, but I can assume that the Integer scale sucks compared to NNEDI3/NGU AA.
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 28th August 2019, 18:01   #57246  |  Link
it's by far the best scaler for the type of content it is added for.
if you want to try it madVR can do for like ever.
it's currently removed from the option but you can still find an option to use it with a hot key. it's "nearest neighbor".
Old 28th August 2019, 18:01   #57247  |  Link
Asmodian
ok, 2 things. Does anyone know how to show chapter marks using mpc-be? The next thing is, has anyone tried interger scaling on an Nvidia graphics card?
That is the same as "Nearest Neighbor" in madVR. The one that says "not recommended. It really is a very bad scaler for anything but pixel art.
Edit: It is hidden for image upscaling as huhn mentioned, but you can still see it under chroma upscaling or downscaling.
madVR options explained
Old 28th August 2019, 18:30   #57248  |  Link
cork_OS
cork_OS's Avatar
What a pity that madVR can't be used with old games!
Diablo 1 doubling Nearest Neigthbor vs Bilinear vs NGU AA High vs NGU Sharp High (Source).
Old 28th August 2019, 21:39   #57249  |  Link
Asmodian
An Envy might have more uses than simply video playback. A customizable hardware scaler for putting NGU AA (or Sharp, if you prefer) between a NES and the TV would be pretty cool.
Edit: of course, it will probably add at least one frame of input lag so it may not be a great option.
Old 28th August 2019, 23:06   #57250  |  Link
SamuriHL
SamuriHL's Avatar
Plus several grand to upscale a video game that didn't come anywhere near that in cost.....seems, I don't know.
Old 28th August 2019, 23:33   #57251  |  Link
ryrynz
ryrynz's Avatar
There are more suitable hardware upscalers for this scenario out in the wild, optimized for gaming. Keep NGU for video IMO.
Old 29th August 2019, 01:28   #57252  |  Link
even my TV can do that.
and if you missed it a PC too.
Old 29th August 2019, 13:49   #57253  |  Link
ashlar42
Several grand? Is that what the Envy is expected to cost? It would surprise me, considering GPU's prices.
Also... it's not as if movies are more expensive than videogames. Quite the opposite is true and has been for a very long time.
Old 29th August 2019, 14:13   #57254  |  Link
SamuriHL
SamuriHL's Avatar
You should check out the Envy thread on AVS Forum. They've discussed the *POTENTIAL* price range for Envy "quite a bit".
My comment was very much sarcastic on cost. However, presumably you have a lot more videos than games, potentially. Buying the Envy to upscale a few old video games probably doesn't make a whole lot of sense especially given it's not really designed around that use case. It iS, however, designed around video from many different sources. I'm not saying you COULDN'T use the Envy for this, but, it's probably a bit overkill.
Old 29th August 2019, 15:25   #57255  |  Link
i just throw input lag in the room so not sure why you would ever use something like that for gaming.
Old 29th August 2019, 16:22   #57256  |  Link
SamuriHL
SamuriHL's Avatar
That's true, too, I didn't even consider that factor. Yup, use the proper tools for the job.
Old 30th August 2019, 15:17   #57257  |  Link
cremor
Does anyone already know if "Filmmaker Mode" (https://www.experienceuhd.com/filmmakermode) is something that could help us with madVR once the TVs support it? E.g. is it additional data in the video stream or "just" a new picture mode?
cremor is offline   Reply With Quote
Old 30th August 2019, 15:36   #57258  |  Link
we already have something like that it's content type with can in theory at least be used with HDMI.
it's pretty much not used at all and a new version of this will take years to spread enough and the next problem we don't even know if it is possible to change that on the fly.
in theory i could be used in the future but for now it's just a marketing gag to boost sales we don't even know hard hard TV producer have to follow it to add it and what exactly it will do in the end.
and if you really really care you will calibrate your screen anyway which is far better then this new "feature" will ever be.
Old 30th August 2019, 16:04   #57259  |  Link
cremor
I might have misunderstood it, but isn't that "Filmmaker Mode" meant to overwrite your settings/calibration? E.g. brightness, white point, ...
Old 30th August 2019, 16:27   #57260  |  Link
sounds like it just like content type so what?
