Old 3rd March 2015, 06:15   #1  |  Link
hbenthow
tsMuxeR giving "Reading buffer overflow" error at 47.4%.
I'm using tsMuxeR to mux an m2ts file from the STREAM folder of a Blu-ray folder I authored with BD-Rebuilder into another Blu-ray folder. I'm doing this because BD-Rebuilder gives me no control over the subtitles. I BD-Rebuilder to author the Blu-ray from non-Blu-ray compliant files, then use tsMuxeR to create the final Blu-ray with the subtitle size, offset, etc, adjusted to my liking. I've already done with multiple times, without a hitch.
But now, with my latest Blu-ray project, tsMuxeR always stops at 47.4% and gives the following error:
Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps
I've never had this problem before, and have no idea how to fix it.
hbenthow is offline   Reply With Quote
bd-rebuilder, blu-ray, m2ts, reading buffer overflow, tsmuxer
