Old 1st December 2004, 04:19   #101  |  Link
tritical
Yeah, you should be able to replace it, but I'm not sure exactly what your script is suppose to do. Cause IsCombed and IsCombedTIVTC each only return true or false, but in your script you are testing if the result is less then 14 which it always will be since it can only be 0 or 1.
The number of parameters doesn't really make a difference, to call it with multiple parameters just do:
conditionalfilter(X,X,Y,"IsCombedTIVTC(MI=32,blocky=8,blockx=8,chroma=false)", "=", "true")
as an example.
tritical is offline   Reply With Quote
Old 1st December 2004, 14:05   #102  |  Link
Chainmax
Huh?
Chainmax's Avatar
This script portion is supposed to reduce jumpy lines on combed frames and was suggested by scharfis_brain to BoNz1 a long time ago in this thread. I'm guessing that the 14 in the conditionalfilter line is related to the threshold parameter in IsCombed.
Chainmax is offline   Reply With Quote
Old 2nd December 2004, 03:09   #103  |  Link
tritical
I think he probably meant something like this:
x=mpegsource("trallalaa")
y=x.trim(1,0)
conditionalfilter(x,x,y,"iscombed(threshold=14)","=","false")
Cause you can test the original version:
y=x.trim(1,0)
conditionalfilter(x,x,y,"iscombed","<","14")
And it will always return x, since the result of iscombed is always less then 14.
Old 2nd December 2004, 17:19   #104  |  Link
Chainmax
Huh?
Chainmax's Avatar
I don't think so because he said this as well:
you'll maybe have to replace < with > and adjust 14 up or down.
Maybe he can explain it himself? I'll PM him and ask what he meant.
Old 2nd December 2004, 17:48   #105  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
y=x.trim(1,0)
wherever this script snipplet is from, I can remember it was questioned for a functionality, that replaces a combed frame with its predecessor. (maybe useful for low-fps telecined anime, not suited for 24fps or so footage)
that's all the magic behind.
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 2nd December 2004, 18:30   #106  |  Link
tritical
I am not questioning the functionality of this line:
but this line:
That line is nothing more then a slow way to return all the frames from the "x" clip. The operator and value strings "<" and "14" have nothing to do with any parameters the function takes. They are used only in conjunction with the return value from the function to see if the statement is true. And in the case of IsCombed the return value is only false or true (0 or 1). So testing if the return value is less then 14 will always return true and that line will always return the frame from source 1 (x). You can test it yourself, any "<" or ">" test won't make a difference (it will always either return all source "x" frames or all source "y" frames) for IsCombed unless it differentiates between 0 and 1 (true or false).
Old 3rd December 2004, 08:45   #107  |  Link
scharfis_brain
brainless
the line
is pretty much useless, cause iscombed does not return comb-amount-values.
it only returns true/false if the current frame reaches the given threshold.
the threshold has to be set within iscombed, not outside.
Old 3rd December 2004, 15:36   #108  |  Link
Chainmax
Huh?
Chainmax's Avatar
That's exactly the line you recommended in the thread I linked to...what did you mean to recommend then?
Old 3rd December 2004, 16:04   #109  |  Link
scharfis_brain
brainless
which thread?
Old 3rd December 2004, 16:23   #110  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
http://forum.doom9.org/showthread.ph...ht=jumpy+lines
that one.
you also said you hadn't tested it...
Old 3rd December 2004, 16:32   #111  |  Link
Chainmax
Huh?
Chainmax's Avatar
You posted the answer before I could...bad, bad Mud Funky :P . This goddamned computer keeps hanging up constantly. I'm gong to have it checked, I swear.
scharfis_brain: the link to that thread is nine posts above this one.
Old 3rd December 2004, 21:14   #112  |  Link
scharfis_brain
brainless
WTF....
Did I really wrote this?
hmm...
This occurs, if one is doing direct stream copy form brain to keyboard without AVS-Check
obviously the condfilter-line I posted about one year ago is WRONG. Stupid me...
Old 5th December 2004, 10:17   #113  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
I was wondering - will you be adding MMX or SSE code to this plugin?
This would be a great way to make it waaay faster than Decomb, and I guess that the parts which do the frame metrics calculation and blending (where the filter most likely spends the most time in) aren't gonna change much anymore, right?
If you want, I can give it a try.
np: Yasushi Ishii - Musical Play Smiling Rebellious Flower (Hellsing Original Soundtrack Raid)
Leak is offline   Reply With Quote
Old 5th December 2004, 20:38   #114  |  Link
tritical
I wasn't planning on it. If you want to take a look and try speeding parts of it up be my guest . Assuming normal processing (non-combed frames, etc...) the majority of the time is spent in only three routines:
match comparison (TFM)
combed frame detection (TFM)
diff metric calculations (TDecimate)
TDecimate is usually slower then TFM by a good bit when there aren't a lot of frames that need deinterlacing or need extra matches tried. The frame blending routine in tdecimate is also ridicously slow... I didn't spend any time on it cause I never use blending, but it would be by far the easiest one to make an mmx version of, and could probably give a good speed up if a lot of blending is taking place.
Old 8th December 2004, 06:03   #115  |  Link
tritical
Said I wasn't going to, but the frame blending routine was very simple to make an mmx version of so I went ahead and did it. I'm definitely not gonna try to do mmx or isse versions of the other main functions though. This version also includes a few minor fixes to TDecimate having to do with incorrect mkv timecode v2 format output in modes 3 and 5. Here it is... [link removed, look farther into the thread]. Changes:
TDecimate:
    - fixed outputting of a few extra timecode entries when using
         tcfv1=false (v2 format) in mode 3 or mode 5 and the last
         frame was not a cycle boundary
    - fixed incorrect formatting of the first 2 lines of the
         mkvOut file when in mode 3 and using tcfv1=false (v2 format)
    + added mmx and sse2 blending routines (used when hybrid = 1)
Old 8th December 2004, 12:51   #116  |  Link
Leak
Leak's Avatar
Whoa - that would have been the first thing for me to do come this weekend...
Well, I'll do that, then...
Also, would you mind me adding a "forceCPU" parameter as seen in my plugins? If I manage to introduce bugs into the MMX or SSE code (and I know I will, at least at first... ) it would let everybody and their dog fall back to the plain C++ versions.
np: K-Taro Takanami - Love Of Babble (Chobits Original Soundtrack 001)
Old 9th December 2004, 05:14   #117  |  Link
tritical
Nope, I wouldn't mind... you can add whatever you feel like .
Old 13th December 2004, 23:52   #118  |  Link
Leak
Leak's Avatar
Ugh. Well, I would have already done something if I hadn't underestimated the time marking 24 MicroJava-compilers for my part-time tutor job at the university takes...
I'll try to start on it this weekend even though I have to come into work on Saturday.
Anyhow, I just tried TIVTC on the first episode of Ghost In The Shell: Stand Alone Complex and found that there was a duplicate frame causing a stutter after a few scenechanges, just as it happened with Decomb on other sources.
I'm wondering - since you're already doing scene change detection for the video parts, would it be possible to detect them for the film parts as well and treat them specially?
I was thinking about something like this:
If you find a scenechange and on one side of it there are more than <cycle> dups in a row, look for a frame to drop on the opposite side of the scenechange first and drop a frame there if you can find one - this would take care of scenechanges that go from a still scene to a moving one.
On the other hand, if the scenechange is badly edited so you'd have to drop a duplicate on both sides (which might be detectable by looking ahead and back a bit and finding out the used pattern, or just by checking if there's 2 or more candidates within <cycle> frames of the scenechange in both directions) you could drop the one closest to the scenechange on each side and insert a new frame at the scenechange's position that blends the 2 neighbouring frames so audio & video stay in sync. IMHO that would be much less noticeable than a sudden jerk in a pan that just started or ended.
I tried cutting out a scene or two to illustrate this, but everytime I cut out a part with Cuttermaran, run it through DGIndex and load it in an AviSynth script, I get different metrics in TDecimate due to different combing... (and yes, I did cut at an I-frame and chose starting points that didn't cause a shift of the cycles that TFM gets...)
Well, this is just a suggestion; I'll see if I can find a way to cut out parts reliably (help, anyone?) and upload you an example or two if I manage to do it - if you want, of course.
np: Autechre - Latent Quarter (Envane)
Old 14th December 2004, 16:24   #119  |  Link
tritical
Well, a few minutes investigation into Leak's observation revealed that longest string decimation mode in v0.9.4 and before has a couple bugs causing it to not work correctly (i.e. not at all for what it is intended to do)... There is a reason why this filter isn't 1.0 yet . Anyways, I've fixed the above mentioned bugs, but am gonna wait till I get a chance to check out Leak's sample before posting a new version. So I would recommend no one use longest string decimation in TDecimate for the time being.
Old 14th December 2004, 18:44   #120  |  Link
BangoO
Hi tritical and the others.
First of all, thx for these great filters.
TFM() works like a charm, a lot better than Telecide() from what I tested.
TDecimate() works also better than Decimate(), but it's awfully slow, I don't know whether it's normal or not.
The source is an HDTV 1080i file that I'm trying to IVTC.
With a TFM() followed by a Decimate(), I encode in WM9 at around 8fps.
Just replacing the Decimate() with a TDecimate(), I encode in WM9 at around 2fps.
Both Decimate() and FDecimate() use the default values.
Is this normal ?
If not, what should I do ?
Thx a lot
PS: I use this version TIVTCv094-1.zip
PS2: I have a P4 3.2
BangoO is offline   Reply With Quote
tdeint, tivtc
